First post, by Ozzuneoj
- l33t
Is there any way to remove this fan? I have taken off my fair share of video card fans, but I cannot seem to find any way to remove this one from the heatsink (I do not want to remove the heatsink). I don't want to pry too hard on it because it DOES work, and the card is basically pristine... but it makes quite a bit of noise and oiling the bearing (which is accessible from the top) doesn't improve things.
On one hand I am thankful that it isn't one of those stupid designs where the screws are coming up from the bottom of the heatsink (I checked) so that you have to remove the glued-on heatsink to replace the fan, but I am afraid that the fan just doesn't come off at all.
Any suggestions? Or, if anyone has a picture of one of these with the fan removed from the heatsink that would be fantastic, as I cannot picture in my mind how it is attached.
