First post, by Major Jackyl
Hey, I want to share what chemical I've been using to clean basically EVERYTHING but myself: Zep AP:
The attachment 20240910_193157.jpg is no longer available
I 've cleaned hundreds of parts with it now and it works like a charm. I literally BLAST it with the sprayer and detail it with a brush and then rinse in HOT water. Then I go out and use my PC duster to blow-dry the whole thing. It can get some serious crap off or heatsinks, fans, cases and almost ANYTHING else. I've went right from the blower to the PSU before, too. No problems. I've made broken things work again cleaning with this. It even restores faded gold.
The attachment Screenshot 2024-09-10 221428.png is no longer available
The attachment Screenshot 2024-09-10 221439.png is no longer available
Bah. The difference is more dramatic in-person
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 2 of 25, by Nunoalex
in my country I never heard of it
Reply 3 of 25, by Major Jackyl
Nunoalex wrote on 2024-09-11, 15:13:
It may unfortunately be North America chemical... Not sure though. It is a global company now. They've done so good these last 20-ish years I've been using Zep prpducts.
Tiido wrote on 2024-09-11, 09:36:
What exactly are the ingredients in the substance ?
The results do look pretty nice
https://docs.rs-online.com/d058/0900766b816864cd.pdf Link to the SDS, but the answer is here:
The attachment Screenshot 2024-09-11 143013.png is no longer available
Yum, chemicals, 🤣
Reply 5 of 25, by Major Jackyl
Before and after cleaning a PCI card:
The attachment 20240913_231143.jpg is no longer available
The attachment 20240913_231512.jpg is no longer available
Reply 6 of 25, by DudeFace
looks like general purpose household cleaner, im not convinced that a good idea, i'm also not convinced washing electrical components in water is also a good idea, tho i have seen people hose down the inside of a crt.
for anyone in the UK pick up a can of electrical contact cleaner from halfords, its good for cleaning sensitive electronics like the mass air flow sensor on your car, it removes stubborn grime that runs off and it doesnt leave a residue, you can find similar products prob whatever country you're in, just dont mix it up with carb cleaner its not the same.
if not isopropyl alchohol (IPA solvent), or methylated spirits for contacts, just dont use acetone it melts certain types of plastic.
The attachment Electrical Contact Cleaner.jpg is no longer available
Reply 7 of 25, by rasz_pl
DudeFace wrote on 2024-09-14, 07:26:
Thats exactly how its done in a factory.
Reply 8 of 25, by DudeFace
rasz_pl wrote on 2024-09-14, 08:05:
🤣 not with general purpose household cleaner and tap water, i should have been more specific, the company i used to work for building rack systems, used to clean parts with an ultrasonic cleaner with specialized cleaner for electronics that was diluted with water, de-mineralised/de-ionised water not stuff straight from the tap.
Zep sell solutions here in the uk through rs-components, this is what OP should be using.
The attachment Zep Elecsol 41 - 600 ml Aerosol Cleaner & Degreaser.png is no longer available
which is the quivelent of the stuff i posted, should be something safe for electronics, that doesn't leave a film or residue, if people are given the wrong impression it could cause more harm than good to our precious components.
Reply 9 of 25, by AlessandroB
I simply use water with a very low percentage of substances inside and a soft brush. If it is too dirty I use soap to wash the dishes, then leave it to dry for 2/3 days and turn it on. The circuits have always come as new and in perfect working order
Reply 10 of 25, by Joseph_Joestar
My preferred cleaning method for very dirty hardware is liquid hand soap (small amount) and regular tap water, with some gentle scrubbing using a soft toothbrush or paint brush.
Afterwards, I rinse everything with clean water and leave it to dry for about 3-5 days, depending on room temperature.
Reply 11 of 25, by Major Jackyl
DudeFace wrote on 2024-09-14, 08:50:
I haven't seen that one around here. I do a lot of service (on everything) and this Zep removes the need for carrying 15 different chemicals. I typically pack Zep AP, Deoxit Gold, and 95-99% alcohol, since I sometimes don't know what exactly I'm going to be fixing/cleaning.
Joseph_Joestar wrote on 2024-09-14, 09:32:
I feel like this method works really well. Some boards I've cleaned were of an unknown color up until that point.
The first motherboard I tested Zep AP on, it cleaned off residues from testing other chemicals; I was impressed and use it on boards/cards/stereo equipment, pretty much anything.(test board works now, has seen various states of function, 🤣) Gets the mold and mildew out, too. I definitely get my hands on some GROSS stuff. No-one wants to buy gross stuff, hence cheap/free.
Reply 12 of 25, by DudeFace
Major Jackyl wrote on 2024-09-14, 14:15:
each to their own i suppose, i use all purpose cleaner on my engine bay to shift grime i wouldnt use it on sensitive electronics especially rare or expensive ones, the 95-99% alchohol is definitely a much safer option as it will evaporate better than water if it gets inside anything, the deoxit is sold here in the uk, never used it but looks like its good for removing green corrosion from contacts or wires, for that i use hydrochloric acid makes it look like new, but i suppose whatever gives the best result.
Reply 13 of 25, by Riikcakirds
looks like general purpose household cleaner, im not convinced that a good idea, i'm also not convinced washing electrical compo […]
I've only cleaned boards using IPA in trays, completely submerged but it doesn't clean really dirty boards that well, even scrubbing with a brush.
Would this be safe to spray all over a mucky motherboard, completely soaking it. I'm guessing you can't just leave it and still have to scrub all the gunk off and then wash this off with IPA.
Reply 15 of 25, by Major Jackyl
Riikcakirds wrote on 2024-09-19, 21:14:
I pulled a board out of the mud on the side of the road and cleaned it with this. Board worked still, which was surprising. I cleaned THIS guy last weekend.
The attachment 20240914_153128.jpg is no longer available
The attachment 20240914_161720.jpg is no longer available
The attachment 20240914_152923.jpg is no longer available
The attachment 20240914_161803.jpg is no longer available
Used only cleaner with a scrub, then hot water, finally the blow-off, using this : (https://xpower.com/shop/a-2-airrow-pro-multip … red-air-duster/)
I'm kinda putting this through some trials, too. I went right from the blow-off, to repasting and power on. Was totally soaked only 10-15 minutes before and ran it all day (installing Windows and some light gaming)
Reply 16 of 25, by Major Jackyl
Cleaned these today:
The attachment 20240921_142552.jpg is no longer available
The attachment 20240921_142520.jpg is no longer available
The attachment 20240921_143921.jpg is no longer available
The attachment 20240921_143855.jpg is no longer available
Reply 17 of 25, by DudeFace
you can completely coat it with this spray no problem thats what its for, its used for cleaning all sorts of sensitive electronics like a mass air flow sensor on your car, you cant just clean them with anything as it can damage the contacts and affect the readings and screwing up the running of your car, the wires on the sensor are so delicate so you cant even touch them with your fingers let alone a brush, the only option is to completely cake it with this spray till its dripping, it usually has caked on grime, and with this spray you will see thick black grime just run off, it will have no problem removing any crud on a motherboard, it also evaporates quickly and doesnt leave a residue, its really good stuff, i highly recommend it.
Shponglefan wrote on 2024-09-19, 21:41:
As long as they aren't plugged in, it's fine. 😉
yeah thats the most important thing 🤣 , i'd still avoid water in anycase as there are better safer alternatives.😉
Reply 18 of 25, by ratfink
the water here is very hard and leaves marks wherever it dries - basically limescale. i saw somewhere to spray with iso-propyl alcohol after washing with water, to drive the water out.
Reply 19 of 25, by myne
My favourite is simply: dishwasher, no soap.
Lazy, good, fast.
Second is sink + toothbrush + Palmolive
Effort, good, slow.
If available and speed necessary/or paranoid, rinse in isoproply or methylated spirits.
Sun dry ~4hrs
Oven ~90c ~15mins+cooling
Inside air ~3 days
I built:
