First post, by Maryoo
Does A-Trend ATC-6310M motherboard support P-III coppermine CPU's?
Reply 1 of 7, by rasz_pl
not officially, but should run with appropriate slotket and maybe a biosmod
Reply 2 of 7, by soggi
The spec page says it supports PIII -> https://web.archive.org/web/20010215155208fw_ … d/atc6310M-.htm.
But if it supports Coppermine!? Does it support the voltage for it? If so, flash the latest BIOS and try out!
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 3 of 7, by PC Hoarder Patrol
Maryoo wrote on 2024-10-18, 13:21:
Apparently yes (with a slotket and likely latest standard / modded BIOS mentioned by rasz_pl)
The attachment A-Trend Mainboard CPU Support.jpg is no longer available
Reply 5 of 7, by Maryoo
The Retro Web unfortunately gets it wrong very often.
Reply 6 of 7, by pete8475
Maryoo wrote on 2024-10-22, 17:39:
Well pop one in and report back!
aka pete4237.5
Reply 7 of 7, by Maryoo
For example, PCChips M726 on The Retro Web does not support PIII at all, but it supports it without any problems, including Coppermine. Zida BX98-3D similarly, no problems with Coppermine support up to 1000MHz.
P.S.
Today I received this board and I can confirm that it handled coppermine P-III 900MHz without any problems.
