First post, by Maryoo
- Member
Does A-Trend ATC-6310M motherboard support P-III coppermine CPU's?
not officially, but should run with appropriate slotket and maybe a biosmod
https://github.com/raszpl/440BX Reference Design adapted to Kicad
The spec page says it supports PIII -> https://web.archive.org/web/20010215155208fw_ … d/atc6310M-.htm.
But if it supports Coppermine!? Does it support the voltage for it? If so, flash the latest BIOS and try out!
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Maryoo wrote on 2024-10-18, 13:21:Does A-Trend ATC-6310M motherboard support P-III coppermine CPU's?
Apparently yes (with a slotket and likely latest standard / modded BIOS mentioned by rasz_pl)
https://theretroweb.com/motherboards/s/a-trend-atc-6310m
The Retro Web says no.
The Retro Web unfortunately gets it wrong very often.
Maryoo wrote on 2024-10-22, 17:39:The Retro Web unfortunately gets it wrong very often.
Well pop one in and report back!
For example, PCChips M726 on The Retro Web does not support PIII at all, but it supports it without any problems, including Coppermine. Zida BX98-3D similarly, no problems with Coppermine support up to 1000MHz.
P.S.
Today I received this board and I can confirm that it handled coppermine P-III 900MHz without any problems.
