Mine seems to match the first card shown here:
http://www.amoretro.de/2015/05/creative-sound … amaha-opl2.html
or for English translation:
https://www-amoretro-de.translate.goog/2015/0 … &_x_tr_pto=wapp
revision seems to be ambiguous. There's no "Rev" marking on the front that the other versions apparently have. Author of the 'amoretro' site believes it's the "final" revision (no number).
My card has the same 069142 marking in one of the corners - so maybe this is the 6 digit number Tiido mentioned.
The PCB has a 0592 date code on it.
The OPL2 chips are socketed - article says some were soldered, I've never seen that in any pictures before.
The OPL2 chips are both dated 9205
It's different from the Rev 6 that was just posted because U1 is different - the chip there (CT1341V301 - dated 9149) is turned in a different orientation. So maybe this is what we're calling Rev 7? It's odd that it doesn't say that anywhere.
The pictures are terrible because I took them through an ESD bag, which I sealed when I moved a few years ago. I can open it if there's something worth seeing but I think this is probably the same card that was posted in that article above.
So I guess the story is that for some strange reason, Creative removed the revision marking on the last version of these cards. Very weird, seems backwards, but the date codes imply this is a late card, not an early one.
I'm curious about that "L" logo in a triangle that appears next to the PCB date code. Is that the PCB manufacturer?
