386 battery issues?
First post, by JayAlien
Hello, hoping somebody could point me in the right direction with my 386. It's having trouble booting.
So the symptoms are:
1. Upon boot there is a memory check, and reports '1664 kb ok' - I have 2 x 1mb simms in there, so this seems off
2. After the memory check I get 'CMOS battery state low' - this is a barrel battery I replaced about 18 months ago - multimeter gives a stable 4 volts (battery is a 3.6v 80mAh)
A couple of other data points:
1. 'did it ever work?' yes - I have used this PC without issue many times
2. There is some mild marking around the battery area from a previous battery that I removed when I received the motherboard. It was cleaned up and I don't see any damaged traces.
3. No BIOS settings will stick, even on a soft reset
I'm going to see if I have any other simms around, or remove them completely to see if I get different behavior.
Thanks!
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700 A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 22, by TheMobRules
JayAlien wrote on 2024-11-21, 23:08:
This is probably OK, sometimes the BIOS does not report the 384KB of memory between 640KB and 1MB (High Memory Area) depending on how certain settings are configured (such as ROM shadow and the like). If the BIOS settings on your PC got reset to defaults, that's probably the cause.
Since you mention that the settings don't stick even after a soft reboot, the RTC chip may not be getting power at all. Does the clock tick properly when you are in the BIOS setup? A photo of the motherboard would be useful to identify the chip and troubleshoot further.
Reply 2 of 22, by JayAlien
Thanks for the reply. I've attached some images below.
Yes, the clock ticks in the BIOS settings. Interestingly the clock settings are retained on soft-reboot, but if I add my disk B: as the 1.44mb 3.5 inch, that isn't retained. Nor are any settings for the HD that is in there. My 5.25 inch A: drive settings are retained though.
The attachment IMG_4230.JPG is no longer available
The attachment IMG_4231.JPG is no longer available
The attachment IMG_4232.JPG is no longer available
The attachment IMG_4233.JPG is no longer available
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 3 of 22, by DaveDDS
Odd, normally you see something like a CR2032 - non-rechargeable and they do "go bad" every few years...
But I don't see one here ... I guess the green 3-cell rechargeable is the RTC/CMOS offline power.
Assuming the systems been in regular use, this pack should be charged.
There may be a jumper to disable charging, but if you've had the system for some time, you should have seen problems...
If you have a multimeter, check the pack (each end should be a pole) with both power-on and off...
It should be around 3.6v (each cell is 1.2 x3 = 3.6)
If not, and you've left the system power-on for 5-10 mins (should be enough to
charge close to rated voltage) the pack itself could have gone bad.
If you are ok working on stuff like this, there are some techniques which
sometimes recover nicad or nmih packs ... let me know if you want more details.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 4 of 22, by TheMobRules
JayAlien wrote on 2024-11-22, 00:43:
I think that 5.25 inch setting for the drive A is just the default, so it's definitely not remembering any settings.
I found your board on TheRetroWeb. It's a Biostar MB-1316VST-SX:
https://theretroweb.com/motherboards/s/biostar-mb-1316vst-sx
I have marked in red the chip that has the RTC and the memory where the CMOS settings are stored. Can you check if yours is similar to the one in this picture? I have a suspicion your board may be using a Dallas/Benchmarq RTC chip with a built-in battery, in that case the barrel battery isn't even being used, instead you must replace or mod the RTC chip itself.
The attachment bestek-mb386sx-25spb-mb-1316-20-25vst.jpg is no longer available
Also, I see some corrosion from the old battery under the keyboard connector area. I don't think that is causing the problem but it will have to be checked out at some point or it may continue to eat the PCB.
Reply 5 of 22, by JayAlien
Thanks for the replies so far!
Looks like I have a different rom in there
The attachment IMG_4235.JPG is no longer available
The attachment IMG_4234.JPG is no longer available
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 6 of 22, by jakethompson1
Poor battery is from 1992
Reply 7 of 22, by JayAlien
How dare it die now after 32 years of loyal service!
So if this is the issue, is it repairable, or just new new old stock from the 90s 😂
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 8 of 22, by jakethompson1
If it's compatible with one of the DS12[C]887[A]+ variants, it's still being made
Alternative is to modify the chip by drilling into it to expose the contacts and disconnect the internal battery, then connect an external one directly to the chip
Reply 9 of 22, by Aui
The first thing to check is if it is in a dip socket. After that you can google for "Dallas RTC mod" for a DIY fix or get an old stock (not recomended) or aftermarket variant (e.g. monotech). If thats the fix, I recommend ripping this awefull green barrel off the board again (notice how I get emotional at this point)
Reply 10 of 22, by JayAlien
Thanks all, I’ll take another look tomorrow.
One thing I’m not clear on - if this chip has its own battery, what is the purpose of the barrel battery on the motherboard?
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 11 of 22, by DaveDDS
If that's an "internal battery" chip (like the Dallas) then the question is..
whats the green rechargeable doing there?
Did it die "years ago" and if so is there a jumper to remove it from the
circuit?
I've repaired a deal Dallas chip - ground the top down to expose the internal
CR2032.. fortunately it was positive side up (full battery width) - There was
no evidence of it having leaked or otherwise corroded...
So I left it in and put a good CR-2032 on top (positive side down to contact).
I also dug down the side to find the negative connection coming out where I
could access it - added a short wire which went to a small plastic disk, passing
though the center and ending in a "solder blow".
Placed that on top (negative side) of the new battery and used some flex
plastic tape (black electrical tape) to hold it in place and give some
pressure to keep everything connected.
(no, I didn't cut the old battery circuit - I have 4.5 digit DVM with lowest current scale 2ma
and I can reliably detect currents of 2ua ... I saw nothing "reverse charging" the old battery!)
This was 32k Dallas RAM inside a home-built 6809 based piece of test equipment
to which I download various bits of software to run various test scenarios.
Often leaving the same test "installed" for days/weeks at a time.
It's been going fine for more than 3 year now!
-- Another options ... replace the "internal battery" chip with a regular RTC,
remove the "green" battery, disconnect whatever charged it (prob just remove a
resistor) and wire in a CR-2032 to power the RTC ... yes, you will have to
replace it every few years (might be worth using a socket).
Reply 12 of 22, by DaveDDS
JayAlien wrote on 2024-11-22, 03:51:
The pic posted by "TheMobRules" which is the same board shows a non-internal-battery RTC ... I'd guess that the
barrel on your board died years ago, and someone fixed it by replacing the RTC.
Reply 13 of 22, by TheMobRules
Those chips with internal batteries are pin compatible with regular RTCs, so it is possible someone did use one as a replacement when the original barrel battery expired as DaveDDS said.
Also, I have a Biostar 486 board from that era that came from factory with a Dallas RTC but the board still has an empty spot for a barrel battery, so Biostar may have provided both options back then.
Reply 14 of 22, by JayAlien
Thanks all. So if I'm understanding correctly, I should be able to pull the RTC (I'm assuming this is a socket rather than soldered to the board) and find one of these non-battery powered chips:
file.php?id=206223&mode=view
and I'll be back to running?
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 15 of 22, by DaveDDS
JayAlien wrote on 2024-11-22, 21:31:
Looks like a socket to me (note how pins go into a raised carrier with copper fingers at the edged rather than into solder
directly on the board).
Assuming your battery is dead (measure and see if it's 3+ volts - if not, make sure there is some voltage when power is ON .. if not
it might be disconnected) - you will need to replace it as well, or use a CR2032 like I described earlier.
Reply 16 of 22, by jakethompson1
Thanks all. So if I'm understanding correctly, I should be able to pull the RTC (I'm assuming this is a socket rather than solde […]
For perspective, Digi-Key has new, genuine DS12C887+ (battery inside) for $16.73 plus shipping. They're in Minn. and you're in Wis...
Reply 17 of 22, by rasz_pl
thats a very peculiar definition of mild 😁 you have corroded pads, corroded components (D1 R8 R9 legs), corroded tracks, and probably even corroded vias under slots.
Start with D1 diode and most likely +5V track (track with R8 printed on it). Edit: oh wait, you got RTC with battery in there 😮
You can cut it open and connect battery https://www.ardent-tool.com/misc/Dallas_Rework.html
https://www.youtube.com/watch?v=IbiczYoVncQ
https://www.youtube.com/watch?v=NdlSfqto_0o
https://www.youtube.com/watch?v=oyNp-u5nl-8
Reply 18 of 22, by JayAlien
jakethompson1 wrote on 2024-11-22, 22:19:
Thanks, is this the correct one?
https://www.digikey.com/en/products/detail/an … DS12C887/956875
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
Reply 19 of 22, by JayAlien
😀 yes I'm a little optimistic
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
A3200 9700 A2 512M
QX9650 3870 Xfi 2G
