Reply 28800 of 32101, by Kahenraz
I pre-ordered and Analogue 3D. The N64 is my favorite games console. I'm really looking forward to playing my old games on a crisp high resolution display!
https://www.analogue.co/3d
Reply 28801 of 32101, by Nexxen
Managed to repair, restore and reboot a 286 board.
Still some issues but it can be solved.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 28802 of 32101, by Ozzuneoj
Kahenraz wrote on 2024-11-23, 23:13:
Looks like a nice piece of hardware, but it seems like they're pretty heavy on the advertising and tugging at CRT nostalgia considering that it isn't physically possible for the vast majority of modern displays to reproduce a CRT-like image. The closest you can get is with a high end LCD gaming monitor that has a well optimized backlight strobing feature (see BenQ monitors with DyAC\Blur Reduction, or Viewsonic's two "Blur Busters Approved" models), or on some level an OLED with black frame insertion... though most do not have BFI built in anymore so black frames have to be inserted by the source (ie, a PC), and strangely enough it seems like the Analogue3D makes no mention of providing BFI for OLED displays, despite all the CRT hype (also, BFI does not work as intended on most LCDs).
I am not a big N64 guy myself, but I can appreciate getting the best quality emulation of original hardware... so, I can see the draw of a system like this if that is your thing and you have the money for it. It just feels pretty disingenuous for them to focus so heavily on how their fancy display stuff will make it nearly INDISTINGUISHABLE* from a CRT, without mentioning that this will be heavily dependent on your display.
*Actual quote from the website:
Unlike its 2D predecessors, the N64 wasn't just about pixels. The original hardware's distinctive approach to rendering polygons […]
Unlike its 2D predecessors, the N64 wasn't just about pixels. The original hardware's distinctive approach to rendering polygons and textures depends on the CRT far more critically than simpler 2D systems. Even game developers had to leverage the interplay between the hardware and a CRT to achieve harmony.
While a very few modern upscalers have transformed the 2D era of video games with pixel-perfect clarity, the N64 demands something far more radical: the unmistakable essence of a CRT.
Analogue3D brings true CRT reference quality to your HDTV in 4K. Experience the N64 with unmatched authenticity and zero lag. It's the N64, reborn.
Analogue3D's Original Display Modes are meticulously reproduced, virtually indistinguishable recreations of CRT displays. Capturing the warmth, depth, and texture in every frame. The soft glow of phosphor and vibrant colors unite with immersive scanlines and shadow masks. This isn't just upscaling — it's an unprecedented transformation.
Also, the marketing seems to imply that games will run internally at 4K resolution, but realistically you're going to be playing games at ~240p upscaled to whatever your display's native resolution is. I believe that modern PCs running an emulator can pretty easily render n64 games at much higher than native resolution.
I think they're trying to differentiate themselves from just running emulators by making claims of features that don't exist in emulators (perfect-CRT-like image? Sounds awesome!)... but these are display limitations, not software\hardware\source limitations.
Reply 28803 of 32101, by douglar
I played with the Tans 2.1 enhanced BIOS.
http://vogonsdrivers.com/getfile.php?fileid=2 … menustate=71,70
The good: doesn’t require a Tans chip, supports LBA28
The bad: doesn’t seem to improve performance at all, even with a Tans VLB controller
Reply 28804 of 32101, by Shponglefan
That looks pretty cool! Any chance it might support dual analog controllers? I know the original N64 didn't have such a controller, but I have found using emulators that dual analog can drastically improve controls in some games.
(I suppose since it's using the original controller ports, it probably would not.)
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 28805 of 32101, by Kahenraz
That's always going to be a function of the controller, not the console. I agree with you though. I map the same controls to dual analogue sticks when playing FF7 on the PC and it's way more enjoyable that way.
Reply 28806 of 32101, by gmaverick2k
Noctua fan modded my PS2 and GameCube (plus inline noctua resistor).
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 28808 of 32101, by Nexxen
Shponglefan wrote on 2024-11-26, 00:26:
Fixing broken traces. Not my prettiest work, but I suppose when soldering a wire barely 2mm long, I'll take what I can get.
286?
This is a lot of dremel and tinning + finishing touch with some solder mask. Boring as boring can get.
Lately I started using transparent nail polish. At least you see what's underneath.
When it's that short I prefer scratching some more and use a longer wire.
Pre bending the wire. Maybe I'll do a boring video about it.
To me this is good enough. Maybe not factory work but does the job saving time.
Reply 28809 of 32101, by Shponglefan
Nexxen wrote on 2024-11-26, 00:36:
286? This is a lot of dremel and tinning + finishing touch with some solder mask. Boring as boring can get. Lately I started usi […]
286?
It's a 386. It's this board I've been documenting my repair of here: QDI 386-4N-D04A motherboard diagnosis and repair - UPDATE: fixing traces
I'm opting for green solder mask. It hides any bad soldering. 😅
Reply 28810 of 32101, by Major Jackyl
I acquired a few new Lian-Li cases over the weekend and I spent the last few hours preparing to shuffle some computers around.
The attachment 20241124_153245.jpg is no longer available
The attachment 20241124_173937.jpg is no longer available
Re-homing one "old" (DiskWizard) and building two "new" ones. ASUS A7V600 with AMD A-XP3000+ and the Intel D815EEA with a PIII-800EB. I'm putting a 3.2P4 in my 875(DiskWizard), hoping it works. Looks new, but untested. It has a 2.8 right now, but at this speed, it will be slower than my A-XP computers. This was supposed to be my "fastest" retro computer. I've been surprised by the performance of the AMD Barton cores I've been testing lately. HOT little buggers, but nothing an OP cooler can't fix.
The attachment 20241117_220034.jpg is no longer available
The attachment 20241124_205710.jpg is no longer available
The attachment 20241125_183516.jpg is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 28811 of 32101, by Nexxen
Shponglefan wrote on 2024-11-26, 00:38:
You slakkker! 🤣
I so understand your point tho... I've done some bad jobs in the past I won't ever see thanks to green goo 😀
Reply 28812 of 32101, by BitWrangler
Go the whole way, just tape over it completely 🤣 Re: Lowend 486 ISA VGA Graphics Quick Test, Mostly Tridents plus Oak, ATI, Tseng ....
Our version of "Grinder and paint make me the welder I ain't"
Reply 28813 of 32101, by Shponglefan
BitWrangler wrote on 2024-11-26, 02:19:
That's certainly one way to do it. 🤣
Reply 28814 of 32101, by dominusprog
Four days ago I opened the 1505S monitor so I can decrease the value of Screen/G2 potentiometer, but then the flyback start to making this clicking noise. Checking the flyback I've noticed that the most of the varnish/glue on top of the ferrite core was gone, so I've cleaned the core and apply a new varnish and the problem solved.
The attachment IMG_20241126_153527.jpg is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 28815 of 32101, by Ozzuneoj
dominusprog wrote on 2024-11-26, 12:39:
Woa... I would love to see before and after pictures of this.
And did you follow some kind of tutorial online? What did you use for cleaner and for new varnish?
I have lots of CRTs and I have replaced some capacitors to keep them going, but flyback noises have always seemed like end-game stuff to me.
Reply 28816 of 32101, by BitWrangler
Way back, late 90s, I was having some HV flashover near the output of a flyback, and I squirted it with automotive ignition sealer that I had around. Used the monitor for several months after... I don't remember what happened to it after that, think I just retired it in favor of a monitor that did 1024x786 whereas that one maxed to 800x600.
Reply 28817 of 32101, by dominusprog
Ozzuneoj wrote on 2024-11-26, 12:55:
Woa... I would love to see before and after pictures of this. […]
Unfortunately, I didn't take a picture beforehand. For removing the old gunk, I've used IPA and a glue remover spray. Then cover the whole thing with the same varnish I use for woodwork.
https://www.youtube.com/watch?v=92NjC0Noal0
Reply 28818 of 32101, by Tiido
I discovered that a 5€ intel 1Gbit NIC I was gonna use with one win9x machine had suffered a lightning strike and the main chip is shorted... at least I have a low profile bracket and a nifty plastic case to put some other NIC into 🤣.
Maybe the chip is actually not expensive and I can buy one at some point and attempt to revive the card... But I need to see first if the isolation transformers are still intact.
Reply 28819 of 32101, by PcBytes
Having fun with reading the SYSCON of a phat PS3 🤣.
