Reply 2080 of 3376, by sharangad
tincup wrote on 2024-11-26, 15:40:
@sharangad - may I just say I'm blown away by this Rendition wrapper - at last! I just tested your alpha release and my old CART Rendition fired right up in all it's primal 3D glory. One of the reasons I got into retro PCs was to run this old beauty so I know what it looks and feels like on original hardware. Now, the wrapper finally weds the advantages and convenience of modern systems as a good wrapper should- perfect - nGlide/dgV2... and Rendition.
Besides the original Rendition tracks I also tested my stable of new and upgraded ICR2 tracks and 6 of 30 loaded and ran. Not bad ...I had assumed none of it would. But it's clear that while some community created and upgraded content runs as-is, modellers still need to tweak a lot of it to run the wrapper. I see that they (and you) are discussing tech over at the ICR2.net forum - seems mip count and size are the challenge. But phew! Finally a Rendition wrapper - and smooth as silk... Cheers!
You're welcome!
The issue with the custom tracks and carsets is there with the original game on real hardware, at least on the ones I tested. For some reason the accelerated version of the game has some bizarre memory restrictions.
[EDIT] I take it you're running on a quad-core or better cpu with a discrete gpu? For dos apps that's the minimum. For Windows apps, you can get away with a fast dual core and in some cases integrated graphics. [/EDIT]
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 2081 of 3376, by tincup
sharangad wrote on 2024-11-26, 16:23:
You're welcome!
Correct - running RR on my daily driver; W10/i5-8400/GTX1060 rig. I've only ever run custom tracks/carsets on a modern system via dosbox. The retro Pentium builds are just for vanilla dos, Win and Rendition releases. I don't think I tried modding those.
The hope is the dedicated modeller community will find an easy way of converting existing mods to run RR. Right now it's a lot of fussy mod-specific drudge work - but with luck they'll hit on a streamlined solution. Regardless, having what we have now is great. Rendition was one of the last major proprietary 3D engines to remain unwrapped. I'll test other games as well; Grand Prix Legends, Tomb Raider 1 , Quake and Hexen. But ICR2 was the BIG ONE since there was no alternative to original hardware until now...
EDIT: I haven't used RLauncher yet - I just made a .bat file to start the RRwrapper/dosbox. Maybe I'll find some helpful tweaks to run a few more mods.
Reply 2082 of 3376, by Myloch
Oh gosh I wish something like this exists for S3D (Destruction Derby for S3 Virge).
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 2083 of 3376, by sharangad
tincup wrote on 2024-11-26, 19:40:
Correct - running RR on my daily driver; W10/i5-8400/GTX1060 rig. I've only ever run custom tracks/carsets on a modern system vi […]
You're welcome!
Rlauncher can configure upscaling resolutions, an optional central mirror for icr2 and linear frame interpolation for 60 fps icr2. If you use the store based version rlauncher is the way to go as it updates the execution folder of dosbox with the latest version. Dosbox is run (through rlauncher) from an execution folder separate to the store based installation.
Also rlauncher's aspect ratio and upscaling won't work for gpl and "myth - the fallen lords" because they have a mouse lock. Gpl can have its resolution set in game (up to 1280x1024).
You can see Dosbox's Rendition settings and vQuake 2/vHexen II's app specific settings in these two dialogs.
Reply 2084 of 3376, by sharangad
Myloch wrote on 2024-11-26, 20:34:
I think somebody's working on S3D support.
Reply 2085 of 3376, by BEEN_Nath_58
sharangad wrote on 2024-11-27, 00:34:
If I am not mistaken you are working on another non-Rendition card too, right?
Reply 2086 of 3376, by sharangad
BEEN_Nath_58 wrote on 2024-11-27, 10:35:
Creative Graphics Library (CGL), used by a number of Creative Labs cards, but at the moment I'm restricting myself to the Rendition V1000P based 3d Blaster PCI. There were a few other cards (non-Rendition) which supported the API, including a few non-Creative boards.
I'm still chipping away at it. If I can get it going, I might be able to support all the other cgl cards, but promise nothing.
Reply 2087 of 3376, by Myloch
You mean Tuxality maybe? I think he made some significant progress in the past with PowerVR wrapper only.
Reply 2088 of 3376, by sharangad
Myloch wrote on 2024-11-27, 13:06:
@BEEN_Nath_58 mentioned someone was working on it on the dxwnd sourceforge forum.
@BEEN_Nath_58 isn't that the case?
Reply 2089 of 3376, by BEEN_Nath_58
sharangad wrote on 2024-11-27, 13:08:
Tux was working on the SGL wrapper. No idea about S3D honestly.
Reply 2091 of 3376, by sharangad
ntalaec wrote on 2024-11-27, 14:41:
S3D support for DxWnd was discussed here: https://sourceforge.net/p/dxwnd/discussion/ge … ead/824588dc1d/
My bad. I was under the impression someone was handling it.
Reply 2092 of 3376, by robertmo3
http://web.archive.org/web/20180524131118/htt … ub=s3tk_wrapper
S3D Toolkit Wrapper
Created on 2015-01-12 by Tuxality, last modified on 2015-01-12
S3D Toolkit Wrapper is a wrapper for native Windows games written for S3 Virge and compatible devices. This wrapper is in working shape, but rendering is buggy. More work needed.
Myloch have you tried this?:
https://www.youtube.com/watch?v=QYKHfuSVW7c&t=208s
Reply 2093 of 3376, by BEEN_Nath_58
sharangad wrote on 2024-11-27, 15:22:
There is a game which has the S3D dlls with it, Terracide by Eidos. It doesn't run with and DDraw wrapper out there, but DxWnd. However it doesn't seem to use any S3D proprietary functions: the main reason it didn't work is because it sets the palette in an unsupported way by modifying the BIOS registers.
Reply 2094 of 3376, by sharangad
Does anyone know how to get the cutscenes in Scorched Planet to work with dosbox?
Setting cycles=400000 renders cutscenes at 1 frame every 7 seconds. Without it nothing, audio freezes with a black screen.
Reply 2095 of 3376, by Makus
@sharangad - On my system, cutscenes look good at 75000 cycles.
Reply 2096 of 3376, by sharangad
Makus wrote on 2024-11-28, 09:03:
Thanks for that @Makus. I was mistaken about the cycles. I've been testing a lot of things and got confused. The only thing which actually works with the Rendition binary is adding a delay to mem writes and mem reads. The smallest possible delay is 1 millisecond which is too much, hence the slow mo video.
There's some weird thing here I've missed. Maybe it's checking for the vsync pulse. Will test that.
Reply 2097 of 3376, by Makus
@sharangad - If it helps you, in DOSBox-X and DOSBox Staging there is a vmemdelay parameter that allows you to set the VGA memory access speed in nanoseconds.
Reply 2098 of 3376, by sharangad
Makus wrote on 2024-11-28, 11:30:
Is that in the conf file? I'll try that out. Is there also a generic delay setting for all memory access, not just vga. At the moment there's a thunderstorm, so my Dev box is powered down. Surge protectors only go so far. I've lost h/w because of lightning damage, even when it's not a direct hit. Limited to my mobile at the moment. It's been all lightning and rain here for over a week, most of the day and night.
C++ has std::sleep_for which supports nanosecond level delays, but I'm not entirely convinced that it works. It's supposed to use a spin lock for sub millisecond intervals.
Reply 2099 of 3376, by Makus
Yes, in DOSBox-X the vmemdelay option is in the dosbox-x.conf file (in the dosbox-x.reference.conf file there are explanations for all parameters).
I see other options for setting delays on the ISA bus but can't find one for system RAM: you might try asking the author Jonathan Campbell.
For DOSBox Staging, I am not sure if they have already implemented the feature in the latest stable release 0.82.0 or if you have to download a nightly build: it is discussed in this thread https://github.com/dosbox-staging/dosbox-staging/pull/3597.
