First post, by butjer1010
i need help from geniuses here!!
I have one VLB card i bought few days ago that has some weird problem. Cards works ok until it starts to load DOS. Than the picture starts to blink (maybe every second or two). I tried to enter Prince of Persia, and i played game for almost 15 minutes, and it has blinked maybe every minute or so, but no freezing or artefacts?!? It is AMD DX4-120MHz computer with 16MB FPM RAM, and Abit AB-PW4 board. Other VLB card (Cirrus GD5428) works fine.
What could be the problem? I have changed 4 small 10uf capacitors, but the problem remained. Could it be some logic chip or memory, or even oscillator?
Thanks in advance
Reply 1 of 11, by Horun
My guess: incompatible video ram is creating the issue. The main/soldered ram chips are TC514256AJ-70 standard DRAM but those ram upgrade chips AS4C256K16E0-50JC are EDO.
Try this: remove the upgrade chips and see if you still have an issue. If you do still have the issue it is something else, use a pink end of pencil eraser and gently erase clean the contacts, then use some 99% IPA and wipe them clean again.
Then try again (without the EDO ram installed)....am fairly sure EDO was not supported until the S3 Trio chipsets iirc and yours is a 805....and mixing types is always bad
Reply 2 of 11, by butjer1010
Horun wrote on 2024-12-08, 05:22:
Hi, thanks man, but i forgot to add that those RAMs weren't there until last night 😀 I tried to add them from one S3 i found it doesn't work at all, so i tried to see if there is any change. So, it is same without them. But if You think this could be the ram problem (maybe main RAM), could i play game like POP without any artifacts or crashing?
Reply 3 of 11, by konc
Despite the fact than another card works fine on the monitor, have you tried a different monitor just to rule it out? Or are you somehow else confident that it's the card's problem?
Reply 4 of 11, by butjer1010
konc wrote on 2024-12-08, 09:53:
Yes, i tried on 2 computers (one 100MHz AMD 486, and this 120MHz), and few monitors. Any other card i connect on those 2 computers works fine 🙁
Reply 5 of 11, by Unknown_K
Your picture is blurry but the main S3 chip has 2 lines soldered together (could be that way from the factory), and also it looks like top right corner (second down) has a broken lead touching the one below it.
Reply 6 of 11, by butjer1010
Unknown_K wrote on 2024-12-08, 12:15:
I think those are ok, hope this picture is better? Those two connected are "factory connected" 😀
Reply 7 of 11, by butjer1010
One thing i could do now is to reflow all the solder joints, maybe a little bit of hot air with flux on main memory chips.... But if someone has better idea, please help 😀
Reply 8 of 11, by butjer1010
I took another 486 from my collection, and it was Cyrix DX40MHz, and the card works fantastic!!! without any issues??? So the problem could be in some frequencies on faster CPUs (VLB or ISA speeds)?
Reply 9 of 11, by rasz_pl
blinks = screen loses sync. Normally I would blame the LCD screen first, but maaaaybe might also be caused by noisy power to the card.
Reply 10 of 11, by butjer1010
rasz_pl wrote on 2024-12-08, 15:08:
Since You are the second guy who pointed me to the LCD, i tried to connect it to my older LCD, and it works normally!!! Can't believe it didn't work on two LCDs, and it work on third!!!! Thanks a lot all of You, will change this to solved 😀
Reply 11 of 11, by rasz_pl
Open OSD menu while in game that was blinking and check what parameters it is reporting - resolution, refresh, Video clock. Might be something borderline standard like 76Hz Vsync while LCD monitor is specced at 75Hz max. I think some vga chip vendors had utilities for configuring output refresh rates.
Had same problem with my modern 23' Dell blinking maybe once a day when "overclocked" to 85Hz.
