First post, by khyypio
A video: https://youtu.be/xkzoRT0c4uE
Download: https://www.thingiverse.com/thing:6879228
Some Intel´s original coolers for socket 478 Pentium 4´s have a very decent heatsink with a copper core but since they´re getting quite old, the fans tend to be worn out and loud. I could just lubricate the bearings of fresh oil but where´s the fun in that? And since third-party coolers are getting a bit challenging to find, I thought an alternative solutions couldn´t hurt.
The attachment 1.jpg is no longer available
So I learned some extremely basic 3D modeling and I came up with this adapter…
The attachment 2.JPG is no longer available
I measured a few key dimensions from the original Intel fans to create this adapter to ensure a firm fit under the retention bracket and this model should be compatible with different cooler variants.
The attachment 3.JPG is no longer available
If you´re going print this model, use material that has high heat-resistance since it will be pressed against the heatsink.
The attachment 4.JPG is no longer available
The attachment 5.JPG is no longer available
Reply 1 of 3, by H3nrik V!
Very nice!
Don't forget to post here too Retro 3D print topic
Reply 3 of 3, by G-X
Looks great! If i had a 3d printer i would try this out for sure (with an older style led fan 😁 though a 60mm variant is probably hard to come by)
I assume the taller fan also flows more than the stock fan and being quieter at the same time.
