Canadair wrote on 2025-01-12, 08:06:
sharangad wrote on 2025-01-12, 07:35:I'm sorry about that. […]
Canadair wrote on 2025-01-12, 06:52:
I understand an updated version is on the way
I tested demo alpha builds and they seem ok, but how to update?
I'm testing the next build. Unfortunately I've been sidetracked a bit. I'm planning on releasing it to the store in another 18 hours roughly. The store takes between a few hours to 3 days to actually release stuff, but usually just a few hours. I've actually been repeating my testing the dos stuff a few times because of a few problems.
[EDIT] Most of the tests have passed, multiple times. I should be able to push it out to the store this afternoon.
actually never bought anything form MS store, so I am not familiar. How to update?
I've submitted it to the store. I've repeated the whole test suite 3 times last week testing minor changes, I don't think it needs anymore testing.
The store has to certify the release and that can take between 3 hours to 3 days.
I'll post here and on youtube when the update gets pushed out. It might still take short while for the update to actually get pushed out to their deployment servers and be actually available to you.
To update it:
Run the Windows Store up and click on the downloads button (cloud icon) at the bottom of the bar on the right. Check that the update has installed or click the "Update now" button next to RReady Rendition Verité.
Once this is done run the store based RLauncher (RLauncher.exe icon on the desktop, I think) and launch dosbox (or dosbox staging if that's what you're using) from there. This should update the dosbox execution folder (If you followed @gplaps guide, this is the ICR2 folder). The game should run. The next time you run this, the updated version should be in the ICR2 folder, where you installed it. If you're using Dosbox-Staging-Rendition to update the folder that version runs from you need to launch it from the RLauncher.exe icon on the desktop (the store based RLauncher).
It might take a while for the update to be certified. It's Sunday afternoon here and I don't know where the Microsoft testers are based. They do sometimes certify stuff on Sunday. I've had updated roll out on Sundays before.
Once the update has installed the RLauncher icon's info page should show something like this:
