First post, by Razgriz
- Newbie
So I've bought and restored a 98 machine (Gateway ATXSTF) and have run into some issues with the HDD. The machine didn't come with one, so first I bought a seagate IDE. Worked great for a month before refusing to boot into windows at all and scandisk would crash about 20% of the way through. Bought a brand new, unformatted one and it worked perfectly fine for exactly 2 days. I followed JosephJoestar's instructions for installing drivers for the SBLive! that came with it, installed the Nvidia driver for the Geforce 2 that came with it and went to bed. Wake up this morning and when I tried to copy over BMOUSE from a cd since I intend to play some Build engine games on it, the dreaded BSOD shows up and says disk write error. Press enter, get to use the explorer again and when I swap out the cd with one full of midi samples and try to copy them over, I get the same issue. Deleting files on the HDD doesn't seem to trigger this at all but even copying files on the disk to another directory will. It's also a coin toss if it will allow me to return to windows or if it will suddenly give a full on crash that gives the option to reset or return to windows, but no key combination does anything so I have to hard power it down.
Gateway ATXSTF FED Performance 1000
Nvidia Geforce 2 AGP
Pentium III 1.00 Ghz
512 MB RAM
Sound Blaster Live! 4870
MARANAX INFIRMUX
