First post, by Choppo51
Hi, I'm currently trying to get my 486 build up and running, but running into an issue with the PC locking up after 20-30 seconds of being turned on.
PC Specs:
Motherboard:ASUS VL/I-486SV2GX4.
Memory: 8mb FPM 72pin SIMM.
CPU: Intel OverDrive 486DX266.
Video: Cirrus Logic CL-GD5429 VLB
Hard Drive: 3.5" Maxtor 512mb IDE
I/O Controller: Tyan/Winbond VL400GW V1 VLB
Whats happening is I can turn the PC on, it runs through the POST process and boots into MS-DOS. But after 20-30 seconds of being turned on, the PC just locks up. This occurs, whether you're just in the BIOS, during the POST process, or once MS-DOS is loaded. Once it gets into this locked up state, the PC will no longer boot up or POST, whether you reset the PC or turn it off or on. You can hear the hard drive spin up and run through the checks like it would on a normal POST process, but there is nothing displayed on the monitor.
The only way to get the PC to turn on and POST normally again, is to either unplug the power cord from the PC for 10-15 seconds, then plug it back in, or to remove the Tyan/Winbond VL400GW V1 VLB card. If I remove the card, the PC turns on and POSTS immediately.
If the Tyan/Winbond VL400GW V1 VLB card is not inserted, the PC runs without issue, doesn't lock up after 20-30 seconds, nothing...
Is it a case of the Tyan/Winbond VL400GW V1 VLB card being broken/dead or could it be a simple config error/jumper setting?
The Motherboard is configured the following way:
Configured for a 486DX2 OverDrive processor as per the jumper settings in the manual.
CPU External Clock Speed: 33MHz
VESA Clock Delay: Delay
VL-Bus Clock & Wait State: 0 Wait State, <= 33MHz (Only other option is: 1 Wait State,> 33MHz)
Tyan/Winbond VL400GW V1 VLB card configuration:
Wait State: 33MHz VL Bus Clock
I/O Channel Ready signal disabled
Uses VL Ready (Other option is Use CPU Ready)
Have I misconfigured the I/O controller or the motherboard VLB settings?? or is it just a case of the I/O controller card being dead??
Thanks in advance
