First post, by Choppo51
Hi, I'm currently trying to get my 486 build up and running, but running into an issue with the PC locking up after 20-30 seconds of being turned on.
PC Specs:
Motherboard:ASUS VL/I-486SV2GX4.
Memory: 8mb FPM 72pin SIMM.
CPU: Intel OverDrive 486DX266.
Video: Cirrus Logic CL-GD5429 VLB
Hard Drive: 3.5" Maxtor 512mb IDE
I/O Controller: Tyan/Winbond VL400GW V1 VLB
Whats happening is I can turn the PC on, it runs through the POST process and boots into MS-DOS. But after 20-30 seconds of being turned on, the PC just locks up. This occurs, whether you're just in the BIOS, during the POST process, or once MS-DOS is loaded. Once it gets into this locked up state, the PC will no longer boot up or POST, whether you reset the PC or turn it off or on. You can hear the hard drive spin up and run through the checks like it would on a normal POST process, but there is nothing displayed on the monitor.
The only way to get the PC to turn on and POST normally again, is to either unplug the power cord from the PC for 10-15 seconds, then plug it back in, or to remove the Tyan/Winbond VL400GW V1 VLB card. If I remove the card, the PC turns on and POSTS immediately.
If the Tyan/Winbond VL400GW V1 VLB card is not inserted, the PC runs without issue, doesn't lock up after 20-30 seconds, nothing...
Is it a case of the Tyan/Winbond VL400GW V1 VLB card being broken/dead or could it be a simple config error/jumper setting?
The Motherboard is configured the following way:
Configured for a 486DX2 OverDrive processor as per the jumper settings in the manual.
CPU External Clock Speed: 33MHz
VESA Clock Delay: Delay
VL-Bus Clock & Wait State: 0 Wait State, <= 33MHz (Only other option is: 1 Wait State,> 33MHz)
Tyan/Winbond VL400GW V1 VLB card configuration:
Wait State: 33MHz VL Bus Clock
I/O Channel Ready signal disabled
Uses VL Ready (Other option is Use CPU Ready)
Have I misconfigured the I/O controller or the motherboard VLB settings?? or is it just a case of the I/O controller card being dead??
Thanks in advance
Reply 1 of 8, by dionb
This could be an IRQ or memory conflict between the card and something else, but the fact that the problem doesn't go away immediately after power off makes me suspect something more hardware-related.
Do you have another I/O card (ISA is fine for these purposes) to test with?
If you do, swap it out and see what happens.
If you don't, consider that a multi I/O controller like this is just a couple of independent chips on one card. Start by disabling all functionalities and see if behaviour continues. Then activate components (IDE, floppy, serial/parallel/game) one by one and see where it fails. When you know which component causes it, take a look at the settings of that.
It would be useful to know what else is in the system that could use memory addresses or IRQs (i.e. which other cards).
Also, never underestimate how weird the symptoms can be of a failing PSU; if messing around wiht settings on the card hasn't fixed it, testing with a different PSU could.
Reply 2 of 8, by Choppo51
dionb wrote on 2025-02-13, 09:22:
This could be an IRQ or memory conflict between the card and something else, but the fact that the problem doesn't go away immed […]
Unfortunately I do not have another spare controller 🙁
I'll try disabling the individual functions to see if anything changes.
No other cards in the PC, just the CirrusLogic VLB Video card, and the I/O Controller VLB card.
Have another PSU that I can also test
Reply 3 of 8, by Choppo51
Have disabled all functions on the I/O Controller, issue still exists. I guess its just a busted card...
Cheers,
Reply 4 of 8, by DaveDDS
Agreed ... simple/quick test - reset the system without power-off... Does it stay hung, or start POST again...
Always worth checking, but I think unlikely ... how much "extra" load does this card make?
The fact that it runs perfectly without the 1 card doesn't seem like possible PSU to me.
(although at one time I did have a PSU fail in such a way that the system would die after a
few seconds with a hard-drive installed, but would boot/run from floppy just fine...
so you never know)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 5 of 8, by Choppo51
DaveDDS wrote on 2025-02-13, 12:28:
Agreed ... simple/quick test - reset the system without power-off... Does it stay hung, or start POST again... […]
so you never know)
Reset without power off did nothing, it remained in that locked up state with no POST.
swapped out the PSU with one from my working Pentium system and no change...
Reply 6 of 8, by Deunan
The fact that it doesn't die right away but needs 20-30s of warmup, and that it stops responding to reset afterwards, would suggest to me a thermal issue. There's usually 3 things that react to temperature and can cause that:
- solder joints, and possibly micro-cracked traces and vias
- the chips themselves
- capacitors
My money is on the first item on this list. First clean the edge connector as VLB is notorious for having bad contact. Also make sure the is no corrosion or dust (or any other unwanted stuff) in the slot as well. Use compressed air, perhaps along with some IPA to wash it first, to clean it. Do not use any abrasive methods to clean the contacts in the slot, the gold plating on these can be very thin and easily damaged.
If cleaning does nothing start looking for scratches and other damage on the card. Especially the main chip(s) - any bent pins and/or corrosion (dull, grey solder) is suspect.
Reply 7 of 8, by BitWrangler
I've had a few instances of I/O chips going flaky and on inspection the pins and solder looks rough and dull grey or even white powdery corroded. Reheating the solder has fixed them. Maybe some metallurgical imbalance between factory "tinning" and assembly solder that shows up in decades.
Reply 8 of 8, by Choppo51
Finally got a replacement I/O card, PC now working without any issues 😀
Thanks all 😀
