PCMCIA Sound Cards
Reply 660 of 754, by Bondi
Kahenraz wrote on 2025-02-25, 17:05:
I had problems with one of my cards in a 486 too. It turned out that the MIDI portion was actually a software synthesizer and the CPU was too slow to emulate it quickly enough for smooth playback.
Try putting it in a faster machine to see if that makes a difference.
Guess you mean the Turtle Beach card. It comes with a software synth. But Yamaha is a different story, it's a hardware synthesizer. Shouldn't be to heavy on the CPU. Roland and TDK cards work perfectly on this laptop.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 661 of 754, by Kahenraz
I can't remember exactly. I think it was the Sound Advantage or some other funny name.
Reply 662 of 754, by Kahenraz
I pulled it out to confirm. You're right, it was the Turtle Beach Audio Advantage. I remember being very disappointed that it didn't work well in my 486.
The attachment 20250226_135629.jpg is no longer available
This card only came with a small dongle for speaker and microphone. The box advertised a larger dongle with MIDI ports, but that had to be ordered separately, so it's very much unobtainium now.
The attachment 20250226_140508.jpg is no longer available
Here's a photo of my PCMCIA sound card collection. I'm missing dongles for the CF-VEW212, but it doesn't need it, since it can leverage the PC Speaker for output. I didn't receive a dongle for the .WAVjammer or the IBM 3D Sound Card when I purchased them and haven't been able to find a replacement.
The attachment 20250226_135949.jpg is no longer available
Reply 663 of 754, by MAZter
Kahenraz wrote on 2025-02-26, 19:03:
I am in a similar situation, can't find the TDK MAB101 dongle, Axonix pcmcia sound cards and/or cables (have CD-ROM/audio external module only), Ego sys Wami pcmcia sound card (have external box only)
Reply 664 of 754, by Kahenraz
I'm very curious about the IBM 3D Sound Card. It's not the same as the IBM Audio Adapter. I haven't been able to find any information about it, including drivers, so the cable is kind of moot anyways.
Reply 665 of 754, by Bondi
I'm really surprised you don't have the dongle for the IBM 3D Sound Card as you were the one to probe it to figure out the pin-out Re: Pinout of IBM 3D PCMCIA Sound card audio cable 😁
Reply 666 of 754, by Bondi
Kahenraz wrote on 2025-02-26, 19:15:
It's a very well known and documented card. Here is official IBM page http://ps-2.kev009.com/pcpartnerinfo/ctstips/3bc2.htm
You can also check the link in my signature for drivers and the manual for it.
Reply 667 of 754, by Kahenraz
Bondi wrote on 2025-02-27, 06:10:
My memory is not the great, but I seem to recall that you've called me out on it, even in this thread, more than once. I appreciate that someone remembers the time I put into researching these things, even if it's not myself, 🤣. I think I mixed up the cards. It must be the IBM Audio Adapter then that is missing the dongle.
Reply 668 of 754, by Bondi
Kahenraz wrote on 2025-02-27, 06:30:
Ah, okay, that's what I thought 😁
I have two clones of this card Re: PCMCIA Sound Cards
These are not particularly useful cards. In DOS they work only with the audio player that comes with the cards, no games support whatsoever. The player supports wav and mid files playback. Midi samples are embedded into the driver and are of very low quality. In WIndows they support WSS and MIDI. The samble set for windows is of better quality, but still sounds not so great.
Drivers are also available on my page on archive.org
Reply 669 of 754, by MAZter
Media Vision Pro Audio card comes bundled with a variety of software applications including ExecuVoice speech recognition software from Dragon Systems; a text-to-speech synthesiser called Monologue for Windows; and a set of applications that can be used for recording and editing digital audio and controlling the playback of audio CDs in a connected CD-ROM drive.
Here is floppy image of Dragon Systems ExecuVoice 1.0:
https://archive.org/details/media-vision-execuvoice-1.0
Reply 670 of 754, by Bondi
Another quirk with my DMC9000. It now doesn't want to work on a Thinkpad 560. The system bluescreens instantly when the device tries to start.
FAQ specifically mentions this laptop, and suggests to change the I/O port address. But it doesn't help. https://web.archive.org/web/19991013153624/ht … cab11100.htm#07
Spoiler
After installing the DMC9000 driver, a "chip time communication timeout" error appears, and when you press the OK button, the system freezes. Because the system freezes, you cannot change the resources as described in the manual.
A This is probably because the resource I/O 260-2F0 does not appear to be in use in the Device Manager on the ThinkPad 560, but is actually assigned to some device, causing a resource conflict. Please shift the resource using the following method.
*This assumes that the card driver has hung after installation and has not been uninstalled.
Start the PC without inserting the card, and when the "Starting Windows 95" message appears, press the "F8" key.
Select "Safe Mode" (3) from the "Microsoft Windows 95 Startup Menu" and start the system.
After Windows starts in Safe Mode, open "My Computer" >> "Control Panel" >> "System" properties and click the "Device Manager" tab.
Select "Sound, video and game controllers" and click the "Properties" button.
Select "TDK MW8432" and click the "Properties (R)" button.
Select the "Resource" tab, click "Registered Setting (B)" and select "Basic Setting 0001".
Cancel "Auto Setting (U)".
Select the top "I/O Port Address 0260 - 026F", click the "Change Setting (C)" button, change "Value (V)" to "260-26F" >> "270-27F", and click the "OK" button. Do not set it to automatic setting at this time.
Click the "OK" button several times to close "System" properties.
Restart Windows in "Normal Mode".
Insert the card after Windows starts.
Note: If another device is assigned to 270-27F, you can change it to 240-24F, 250-25F, etc.
Anyone tried this card on this laptop? Just for reference, it uses Cirrus Logic CLPD6729 pcmcia controller
Reply 673 of 754, by lolo799
Are you using win95 or 98?
I suppose you tried uninstall/deleting the drivers and reinstalling them? Whichever version is available...
Reply 676 of 754, by Kahenraz
I have one of these (with the dongle). Very disappointed with the MIDI synthesizer. It's also not great for slower CPUs, like a 486, due to it using a software synthesizer. It would probably be fine on an early Pentium, but then there is probably a sound card already built into your laptop.
You could argue that there is the added advantage that it has a dongle for MIDI IN/OUT, but this wasn't included in the box, and is probably unobtainable. Instead, it shipped with a much smaller dongle with support for stereo speakers and a microphone.
If it had a hardware synthesizer, then I think it would have been more interesting.
I've mentioned a lot of this information already a bit further up in this thread:
Reply 677 of 754, by MAZter
I'm looking for TDK MAB101 dongle and Axonix pcmcia card/cable
Reply 678 of 754, by MAZter
lolo799 wrote on 2012-01-01, 19:04:
-EXP Soundnote, ESS ES688P Adlib/SB FM and MPU-401 in DOS + digital audio in Win3.x/Win9x […]
-EXP Soundnote,
ESS ES688P
Drivers: http://www.expnet.com/know.nsf/a87c96fe8c9775 … 66?OpenDocument
or http://www.expnet.com/know.nsf/a87c96fe8c9775 … fc?OpenDocument
Unfortunately both links in the first post are dead.
https://www.helpdrivers.com/sound/Exp/Soundnote_S-16/
