First post, by Grzyb
- l33t
I'm experimenting with DIS_PKT9.DOS, an NDIS to Packet Driver converter.
The procedure described on this page - https://web.archive.org/web/20170816111631/ht … er_installation - works fine, tested it with mTCP's DHCP.EXE and FTP.EXE.
But there's this inconvenience: can't load it whenever I need it - it's loaded from CONFIG.SYS.
I believe there's no need to use CONFIG.SYS for NDIS stuff - in Microsoft Network Client it's all loaded later, via "net initialize".
But I don't know how to make "net initialize" to load the stuff I need - it seems to ignore PROTOCOL.INI, and uses SYSTEM.INI instead?
Any ideas?
Ideally, I'm looking for the minimum set of files to use as a replacement for Packet Driver...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
