First post, by Grzyb
I'm experimenting with DIS_PKT9.DOS, an NDIS to Packet Driver converter.
The procedure described on this page - https://web.archive.org/web/20170816111631/ht … er_installation - works fine, tested it with mTCP's DHCP.EXE and FTP.EXE.
But there's this inconvenience: can't load it whenever I need it - it's loaded from CONFIG.SYS.
I believe there's no need to use CONFIG.SYS for NDIS stuff - in Microsoft Network Client it's all loaded later, via "net initialize".
But I don't know how to make "net initialize" to load the stuff I need - it seems to ignore PROTOCOL.INI, and uses SYSTEM.INI instead?
Any ideas?
Ideally, I'm looking for the minimum set of files to use as a replacement for Packet Driver...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 1 of 4, by dgorski
DEVLOAD allows you to load drivers from DOS that normally need to be loaded in CONFIG.SYS.
You can create a NET.BAT file and load your drivers only when you want them. Something like:
DEVLOAD C:\NET\PROTMAN.DOS /I:C:\NET
DEVLOAD C:\NET\EL3C574.DOS
DEVLOAD C:\NET\DIS_PKT.DOS
(just replace DEVICE= with DEVLOAD)
https://home.mnet-online.de/willybilly/fdhelp … til/devload.htm
https://www.ibiblio.org/pub/micro/pc-stuff/fr … es/dos/devload/
- Darrin
Reply 2 of 4, by maxtherabbit
In general I avoid the use of "net initialize" as we discussed previously here Re: Windows for Workgroups TCP/IP Disk
But that said I think it does use PROTOCOL.INI to know which drivers to load, it would almost have to. It should use the PROTOCOL.INI that's in your WINDOWS directory though, not the one from the MS NET client.
Reply 3 of 4, by Grzyb
OK, tried that DEVLOAD thing - works fine!
I still believe that there's no need for third-party utilities to load NDIS drivers - but I've found a reason not to care:
NET.EXE is 450 KB
DEVLOAD.COM is 3 KB
Size does matter - I'm likely to run that stuff off a floppy...
Reply 4 of 4, by Grzyb
There's some incompatibility between mTCP NetDrive and ODI+ODIPKT.
But it works fine with NDIS+DIS_PKT9.
So, in case of lack (or poor quality) of native PD, this may be the preferred choice.
Anyway, I'm attaching both drop-in replacements for PD - just add the driver for your hardware, and edit CFG/INI and BAT.
