Reply 40 of 45, by Mondodimotori
- Member
Tiido wrote on 2025-02-27, 12:29:If I still lived in Estonia I could be an option, but now I'm in Norway and since it is not in EU there's all the extra taxes and postal service here is totally insanely expensive too...
But photos of the PCB and knowing of part numbers can go a long way in that detective work I mentioned. But there's still need for someone to actually solder stuff eventually (or at least adapt the wiring).
Well, now that the case with the seller is closed, I can do what I please with the unit, including disassembling it fully and inspect the PCB from all angles. I'll see if I can do it this weekend, if I can slide it in between OCing my XP box.
