kotel wrote on 2025-03-06, 13:35:
As for the opto coupler I'll just replace it with a new one. Have like 20 of them I forgot about😆
The big question here is what was the old optocoupler and what was the new one that replace it.
There's standard "817", then there's the "817c", and then there are many others too.
The LED inside these may react a little different and require either more or less current to drive... which if not selected right will do exactly what yo saw: output too high.
kotel wrote on 2025-03-06, 16:58:
Actually, on a second thought this doesn't sit right with me...
The PSU after replacing all the bad parts for the first time had spot on 5vsb (~5.17v). Then something screwed up fully and now its 5.8v after replacing the PS106R (mine started with FR10 and the rest was burnt away) with FR107. I don't think its gonna be the voltage increase by 100v.
The change in the voltage rating of the snubber diode is irrelevant. All the snubber diode does is it allows the 5VSB transformer's primary winding to "push out" current "somewhere" when the MOSFET closes up. So when this current is pushed through D5, it then gets stored in C8, and parallel resistor R61 "slowly" dissipates it over the time between the next switching cycle. The whole purpose of the snubber circuit is to protect the MOSFET from the inductive kickback of the 5VSB transformer's primary side, which can generate very high voltages and kill components. Other than that, it play no role in the voltage regulation of the circuit.
Tiido wrote on 2025-03-06, 17:06:
It is possible there's a damaged voltage reference component in the feedback loop or maybe there is a need to adjust one of the feedback resistors due to different replacement components etc.
Agreed.
And I suspect it's the new optocoupler that might be the smoking gun here. Probably needs a higher driving current to turn ON its LED in order to drive the MOSFET on the primary (via small transistor Q7) harder into the OFF state to reduce voltage.
Resistor R13 (looks like 390 Ohms on my PSU) is responsible for limiting the current going to the optocoupler LED. If you compare this to the circuit of the HEC Orion HP585d 5VSB circuit I put several posts above, you will see that one uses a 150 Ohm resistor.
So with that said, you can try replacing R13 with something like 330 Ohms first (orange orange brown gold), and if that still keeps the 5VSB too high, try 270 Ohms (red purple brown gold) or 220 Ohms (red red brown gold) or even 200 Ohms (red black brown gold). See how the 5VSB voltage changes with these and report back.
Tiido wrote on 2025-03-06, 14:53:
You need some big enough load on the output for voltage to get in spec, i.e a few LEDs or something like a 100 ohm resistor. Unloaded SMPS outputs are rarely if ever in spec.
PSU 5VSB circuits doesn't require any external loading (i.e. anything extra that's not already inside the PSU). That said, most include a load resistor on the output to have proper regulation. This resistor is usually in the range of 10 to 470 Ohms... with 10 Ohms being really waaay too low and wasting too much power / producing too much heat. But 47 Ohm to 100 Ohm is acceptable (and what I usually put on my PSUs with 2-transistor circuits.)
kotel wrote on 2025-03-06, 17:21:
Okay with an 1k in the voltages are down to 5.5v. Still to high though.... And besides now there's an funny smell inside. I cannot describe it but it's like plastic melting or something like that but veery light. Maybe it's from the outside but I can only smell it when there's power to the PSU.
OK, here's a simple-ish way to find if anything is overheating.
First, solder wires to the primary side 200V caps so that you can measure the voltage across them without having to poke at them with your MM.
Next, power up the PSU and let run for a few seconds or longer... preferably until you can start to smell the burned plastic smell again.
Now remove AC power from the PSU (via unplugging from the wall) and look at the DCV reading of the primary caps. As soon as the voltage falls below 50V total (i.e. under 25V on each cap), feel free to start probing around with your finger at various parts in the 5VSB circuit to see what's running hot. Only do this with one hand while the other is not touching anything on the PSU, just in case. With the primary caps discharge, there won't be any component to hold energy and shock you, but nevertheless, it's a good safety practice. Now see if you can see what component(s) are running hot.
