Proprietary 3D API's
Reply 120 of 128, by marxveix
Gona wrote on 2023-12-04, 17:33:
BEEN_Nath_58 wrote on 2023-12-04, 17:04:
Gona wrote on 2023-12-04, 14:03:
I have added. Thanks!
Hi Gona. There seems to be some trouble with the site. It used to work earlier for me. I have to use the Internet Archive to access old versions. Isitdownrightnown says that the site is down.
I tried 3 different ISPs and they have the same result.
Hi, my site provider has blocked full country related IP domains. Write me your country in private and I will try to remove it from blocklist.
Now this site is down for me also, 2-3 days back it was ok. Still i know most of the latest working drivers by name and i have 3dcif files stored.
Edit: Server was not working probably, now site works again for me.
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 121 of 128, by Gona
marxveix wrote on 2023-12-07, 02:58:
Nowadays the site is well available, but sometimes can problems occur.
It seems to me that my provider goes from blocking "black list" to enable "white list".
If someone can't access my page, write your country here or in PM.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 122 of 128, by marxveix
I share 3dcif working ati2drab files or driver soon, still the winme or any other Rage XL PCI compbatible drv is missing from the final puzzle at the moment (faulty colored picture in the game with them).Re: Compaq (HP) original drivers are broken?
Edit1:
Here is one of the Spadina driver , 3DCIF works for Rage XL AGP, just downgrade ATI3DCIF.DL_ to (2692), tested with Assault Rigs and clean Windows. All M6.00.xx and Spadina drivers are working if correct ATID32AB.DL_ (5031.2) is used with downgraded ATI3DCIF.DL_ to 2692, ATID32AB.DL_ 5034 also works, even with ATi Rage XL AGP.
I am miss more recent Ati2drab.dr_ from 4.11.1xxx line and newer ATID32AB.DL_ (5036), latest 4.11.1xxx ati2drab.dr_ i have is 4.11.1027 and sp11141.exe (M6.00.11) ATID32AB.DL_ (5036) file is broken.
Spadina driver (ati2drab.dr_) spb94ej.exe:
https://prius.hitachi.co.jp/support/verup/tool/310ldisp.htm
https://prius.hitachi.co.jp/support/verup/dat/spb94ej.exe
Reply 123 of 128, by marxveix
Newer than 5.38 was available for 5.3x release, i see 5.39 driver, but i cant download it, 5.40 also here.
https://web.archive.org/web/20010406110446/ht … orea/driver.htm
https://web.archive.org/web/20010603090633/ht … /korea/home.htm
https://web.archive.org/web/20010406110446/ht … sk/5391b10e.zip
https://web.archive.org/web/20010406110446/ht … isk/540b01q.zip
Anybody has ATi 5.39 driver?
Reply 124 of 128, by Hoping
marxveix wrote on 2024-10-03, 17:32:
Newer than 5.38 was available for 5.3x release, i see 5.39 driver, but i cant download it, 5.40 also here. https://web.archive.o […]
What is the latest version you already have? For the Rage 2 PRO TURBO AGP I found Fujitsu version 5.35, the newest I know.
https://support.ts.fujitsu.com/indexdownload. … 80-89d9e5a4d4b0
There are already so many versions mentioned in the thread that I get lost.
Reply 125 of 128, by marxveix
Hoping wrote on 2024-10-03, 17:58:
What is the latest version you already have? For the Rage 2 PRO TURBO AGP I found Fujitsu version 5.35, the newest I know. https […]
From latest 5.38.x MACXW4 driver i have 5.38.2 / 5.38.3 / 5.38.6 , as i remember.
I tought that 5.38.x variations where latest MACXW4, now i think 5.39 is latest, just nobody has it. I was looking for Rage XL PCI (4752) / Rage XC (4753) 3DIF driver again.
3D TURBO ACE,3D MULTI EYE, 3D POP (Direct 6.0지원) Version 5391b10e (00/02/14)
https://web.archive.org/web/20000422165828/ht … rea/support.htm
Driver date 14 februrary 2000 - 5391b10e.zip(6,388KB)
https://web.archive.org/web/20000613150221/ht … orea/driver.htm
Reply 126 of 128, by dr.zeissler
There are lot's and lot's of different ATI drivers for my ragePro-PCI but I found 82440 to be the best.
It works in games, works with ATI-DVD 3.10 player and can be used with suitable opengl.dll.
Reply 127 of 128, by marxveix
dr.zeissler wrote on 2024-10-03, 20:02:
I am using MMC 6.30 with XLAGP, it works with RagePro/Rage128P cards @ Win9x, it has ATi DVD 6.2. If someone uses it with AMC connector or AIW Rage Pro then even better.
Most of the sites have ATi Video Player 5.2 / 5.3 available, found ATi Video Player 5.35, possible to use with MMC 6.30 also, some files conflicts @ mmc if both regulary installed.
Just unpacked AVP 5.35 or overwritten with 6.30 again and works for me. MMC6.30 and AVP5.35 need DirectX6.0 or newer + worked with my latest 4.11.2582 dx6 3dcif dirvers.
ATi Multimedia Center 6.30 Win9x
https://hingetee.ee/ftp/?dir=library/Software … Ti/Win9x/MMC630
ATi Video Player 5.35 Win9x
https://hingetee.ee/ftp/?dir=library/Software … /VideoPlayer535
Reply 128 of 128, by marxveix
Working Macxw4 4.11.2611 CIF driver for RageXL AGP, maybe for Mobility AGP as well, Rage2 to Rage3 compatible.
Tomb Raider 3DCIF + Croc 1.0 3DCIF tested@clean Windows 98 SE and Directx 6.1 @ Rage XL AGP and Rage2C AGP.
I share here also my Rage2/Rage3 new beta driver, thats modded 4.11.2611 driver works@RageXLAGP.
Someone with Rage Mobility (Rage3 based) could also test it. Rage XL PCI i have less hopes, this driver
got R3DVD playback imported also from Ati2ddad and 2611 is compatible with Rage2 Direct3D / 3DCIF.
RageXL has 3DCIF/Direct3D/OpenGL/ATiDVD, maybe Brenders and ATi Video Player should also work.
3Dfx emulator added from XGL200 and some more, MPEG1 gamma @menu maybe, d3d 8bit pallete.
OpenGL 8bit palleted textures over D3D->OGL wrapper only, but that also should work if @D3D work.
Macxw4.inf has readme inside, this is not my ideal rage2/rage3 final driver, but its more closer there.
bat file shoul be executed after or before install even with or without 3dfx emulator. Thank you all!
Some testing and tips would be helpful, 90% sure that with more hexedit no need to downgrade R2.
5043 Macxdd32 needs atid3d.dll correcty inputed, made some name changes inside ati2ddad files.
    Mach64w9x538x3D2611.zip
    4.37 MiB
    12 downloads
