First post, by clownwolf
UPDATE: Found a post by user gerwin from 2009 that actually has a list of chipsets I can use as data! I believe its a single chipset solution if the chip is listed as having Controller+Codec+OPL3 Clone Sound cards - from best to worst
Would any audiophiles/collectors be able to help me compile a list of single-chipset ISA sound cards? These are mostly used in budget cards, with Crystal's CX4235 and ESS' ES1868F being some of the most common examples.
I am hoping to get a definitive list as I start collecting them all. I pair these cards with GUS/PAS/Soundscape, so their FM synth performance is secondary and not a dealbreaker for me.
Analog Devices:
- AD18max10JS - card model owned: 2x Digitan DSAC-300
- AD1812JS - card model owned: 2x Action Well Development AA-1812
- AD1815JS - card model owned: 1x Analog Devices AD15-3DS, 1x [Unknown] Audio-1815, 1x Action Well Development AA-1815B
- AD1816JS - card model owned: 2x AOpen FX-3D Rev. A, , 1x Terratec Promedia BASE-1 V1.01
- AD1816AJS - card model owned: 2x AOpen FX-3D Plus REV.C, , 1x Terratec Promedia BASE-1 V1.01
- AD1821JS - card model owned: 1x Action Well Development AA-1816
Avance Logic:
- ALS 120-based:
- ALS 120 Datasheet
- ALS120 - card model owned: 2x LABWAY CORPORATION A381-F20
- ALS 120 Datasheet
ALS100Plus+-based:Not a true single-chip solution. Uses an undisclosed OPL3 clone somewhere on the PCB. Examples of OPL3 clone disguises are: LS262, LS245, DSP245- ALS100Plus+ User Guide
- ALS100 Plus+ - card model owned: 2x Procomp Informatics REV 2.1
ALS200-based:Not a true single-chip solution. Uses an undisclosed OPL3 clone somewhere on the PCB. Examples of OPL3 clone disguises are: LS262, LS245, DSP245- ALS200 Datasheet
- ALS200
- ALS200 Datasheet
AZTech
- AZT-2320 - card model owned: 1x AZTech Sound 16B SRS 3D V1.0, 1x AZTech Sound Galaxy Pro 16 III-PnP
- AZF3318 - card model owned: 1x AZTech Multimedia PRO16SD-3D PNP BP
C-MEDIA
- CMI8330 based:
- CMI8330A/C3D Datasheet
- CMI8330- card model owned: 1x [Unknown] Generic Card
- CMI8330A - card model owned: 2x Audio Excel AV310
- CMI8330A/3D
- CMI8330C/C3D - card model owned: 1x [Unknown] Generic Card
- HT1869V+ - card model owned: 1x Elpina Generic Card, 1x Aristo Generic Card
Creative:
- CT2505 - card model owned: 3x Sound Blaster 16 Prelude CT2960
- CT2508 - card model owned: 2x Sound Blaster Vibra 16 CT4100
- CT2511 - card model owned: 2x Sound Blaster 16 WavEffects CT4170
- CT8920 - card model owned: 1x Sound Blaster 16 WavEffects CT4525 *NOTE* might be considered a single-chip card based on your own definition/use-case. See discussions below.
Crystal:
- CS4235 based:
- CS4235-JQ/KQ Datasheet
- CS4235-JQ - card model owned: 1x Pine Technology PT-2318-20 V3.0, 1x Pine Technology PT231X V1.1 (note: this card can also come with CX4235 chip)
- CS4235-KQ - card model owned: 1x [Unknown] Generic Card
- CX4235-XQ3 - card model owned: 1x Pine Technology PT231X, 1x Pine Technology PT231X V1.1, 1x AOpen AW35
- CX4235-XQ3 EP - card model owned: 1x Pine Technology PT231X V1.0
- CS4239-JQ/KQ Datasheet
- CS4239-JQ
- CS4239-KQ - card model owned: 1x Pine Technology PT2318-4 V2.0, 1x Pine Technology PT2318-4 V1.0
- CS4236 based:
- CS4236-KQ Datasheet
- CS4236-KQ - card model owned: 2x [Unknown] JYS001 V1.1
- CS4236-KQ EP - card model owned: 1x [Unknown] SM423X Rev 3.10
- CS4236B-JQ/KQ Datasheet
- CS4236B-JQ
- CS4236B-KQ - card model owned: 1x Dictaphone Boomerang
- CS4236B-XQ3 - card model owned: 1x Serenade SR-S161-F, 2x TYPHOON KJD-MUSIC16 (card can also be found with XQ3 EP Suffix)
- CS4236B-XQ3 EP - card model owned: 2x TYPHOON KJD-MUSIC16
- CS4237-based:
- CS4237 (datasheet not available)
- CS4237 (Chip still unconfirmed to exist on an ISA sound card)
- CS4237B-JQ/KQ Datasheet
- CS4237B-JQ
- CS4237B-KQ - card model owned: 1x KENTECH COMPUTER KJD-MUSIC16, 1x Tenda Generic Card
- CX4237B-XQ3 - card model owned: 1x AOpen AW35 PRO, 1x [Unknown] FSSC-CS1.1
Diamond:
- DT-0197H - card model owned: 2x Diamond Technologies DT197A30
- DT-0297F - card model owned: 1x Diamond Technologies DT297A40
ESS:
- ES1688-based
- ES1688F Datasheet
- ES1688F - card model owned: 1x Formosa Industrial SC1630, 1x MICRO EQUIPMENT CORPORATION UN-1688 ver. 1.5
- ES1688F Datasheet
- ES1698-based
- ES1698 (datasheet not available)
- ES1698FC
- ES1788-based
- ES1788 Product Brief
- ES1788 (Chip still unconfirmed on ISA sound card)
- ES1868-based
- ES1868 Datasheet
- ES1868F - card model owned: 1x Formosa Industrial SC200, 1x Pine Technology SC1868-3D Rev. 1.10, 1x BEHAVIOR 1853L/1857L REV:B
- ES1868 Datasheet
- ES1869-based
- ES1869F/S Datasheet
- ES1869F - card model owned: 1x LABWAY CORPORATION A111-A20, 1x Formosa Industrial SC202 MPB000078 VER:1.2, 1x Compaq ES1869 Audio Feature Board
- ES1869FC - card model owned: 1x [Unknown] ES186XM3 REV98, 2x Pine Technology PT-233X V1.2
- ES1869S - card model owned: 1x [Unknown] Generic Card
- ES1878-based
- ES1878 Datasheet
- ES1878S - card model owned: 1x [Unknown] SD-18G89 REV 1.00
- ES1878 Datasheet
- ES1879-based
- ES1879S Datasheet
- ES1879S (Chip still unconfirmed on ISA sound card)
- ES1879S Datasheet
- ES1887-based
- ES1887 Preliminary Datasheet
- ES1887 (Chip still unconfirmed on ISA sound card. Can be found in a laptop daughterboard.)
- ES1888-based
- ES1888F Product Brief
- ES1888F (Chip still unconfirmed on ISA sound card)
Opti:
- 82C931-based
- 82C931 Data Book
- 82C931 - card model owned: 1x DataExpert MED3931, 1x [Unknown] OP931-3DIS R0.1
- 82C931 Data Book
- 82C933-based
- 82C933/EV1933 Technical Brief
- 82C933 - card model owned: 2x GoodWell EPC-C933D830
- EV1933 - card model owned: 1x [Unknown] 247 VER 2.0
Rockwell
- RWA010 - card model owned: 1x DCS S717
- RWA011 (Chip still unconfirmed on ISA sound card)
Yamaha
- OPL3-SA1 based:
- YMF701-F/S Datasheet
- YMF701-F (Chip still unconfirmed on ISA sound card)
- YMF701-S - card model owned: 1x Addonics Sound Vision 500 A151-830
- OPL3-SA2 based:
- YMF711-S Datasheet
- YMF711-S - (Chip still unconfirmed on ISA sound card)
- YMF718-S - card model owned: 1x [Unknown] SM718 Rev 2.00, 1x Pine Technology Generic Card
- OPL3-SA3 based:
- YMF715-S Datasheet
- YMF715-S (Chip still unconfirmed on ISA sound card)
- YMF715B-S - card model owned: 1x Atrend ATC-6631 *NOTE* This card can have YMF719 chip instead
- YMF719B-S - card model owned: 1x [Unknown] YAMAHA 3D SOUND CARD MS719
- YMF715E-S Datasheet
- YMF715E-S - card model owned: 1x [Unknown] SM718 Rev 2.00
- YMF719E-S - card model owned: 1x LABWAY CORPORATION A151-A00, [Unknown] SM718 Rev 3.00, 1x [Unknown] YAMAHA 3D SOUND CARD MS719
- OPL3-SA3L based:
- YMF741 (datasheet not available)
- YMF741-S - card model owned: 1x LABWAY CORPORATION A151-A00
