First post, by 9646gt
So I picked up an AST Bravo LP 4/50s. I’ve already bought a DX2 66 for it and 16mb of RAM. It only has two ISA slots and it’ll be my DOS machine for more speed sensitive games that wont run on my Pentium 233 or that I just feel like are more appropriate to the 486 nostalgia!
I plan to run DOS 6.22 and Windows 3.11. It has MACH32 graphics by ATI built onboard. Is it safe to assume that this will be faster than any ISA card I could add due to the possibility of it having fast than the 8mhz bus speed? I’ve included a link to the PC and also the motherboard info at the bottom of my post.
I would prefer to upgrade it to 2mb of video RAM but all the manual mentions is using 256x16 memory and it looks like 20 pin sockets on the board? Anyone know which specific chips I’m looking for?
I’ve also heard I may need special drivers for DOS games that are 640x480 and up. What the best solution to use when running DOS and windows? Is it something I can just launch only when playing the specific games?
Am I better off sacrificing my only remaining ISA slot for a particular video card? I’d want something less than $50 for sure and would prefer just straight compatibility with any games I may run but also must have Windows 3.11 acceleration.
Thanks for any help fellas!
https://www.ebay.com/itm/226549285473? ... media=COPY
https://theretroweb.com/motherboards/s ... 202536-0xx
Reply 1 of 9, by bertrammatrix
Mach 32 will probably be as good as anything. Look up card versions of the mach32 that may have the same memory sockets already populated and note the IC.
Usually you need no special drivers, unless you run in to a game in particular that has some known issues on that chip. As for "over 640x480" - for the most part that concern is moot on a 486 of that speed 😁
Reply 2 of 9, by 9646gt
bertrammatrix wrote on 2025-05-04, 01:43:
I should have said at 640x480 haha that’s my mistake. I’ve attached a picture of a similar AST board I found on this forum with the same video chip and it shows the default soldered RAM chip better but still kind of hard to read and although I’m familiar with computer hardware I still don’t know what I’m looking for when shopping that same type of chip
Reply 4 of 9, by bertrammatrix
9646gt wrote on 2025-05-04, 01:58:
I should have said at 640x480 haha that’s my mistake. I’ve attached a picture of a similar AST board I found on this forum with […]
That's more then 20 pin, I thought you had a different style in mind... For obtaining those ic's an old mach32, s3trio, virge, etc that have the expansion sockets populated may be your best bet. If you get a 4mb virge you'd usually get 4 in sockets leaving you 2 spares. They don't necessarily have to be identical, for instance the speed rating (those look like 70ns), you could toss 60 or 50ns from another card in there with no ill effects
Reply 5 of 9, by dionb
The Mach32's DOS VESA compatiblity is a bit hit and miss, see here for a list of test results:
https://gona.mactar.hu/DOS_TESTS_VLB/
Look up games you might specifically be playing; if the Mach32 isn't great, you'll see what is.
Note however that your Mach32 is hooked up via VLB whereas the expansion slot on this LPX board is ISA. That means that anything else you add will be much slower. So only consider something else if you have more than enough performance to spare and whatever SVGA issues there are are severe.
Mach32 is an excellent Windows accelerator, so for Win3.1 nothing else makes sense.
Reply 6 of 9, by chinny22
My 486 has a very similar VLB Mach 64 onboard, I've never had a need to replace it.
especially if you have a P233 as "backup" for the few games that do have compatibility issues.
Reply 7 of 9, by 9646gt
bertrammatrix wrote on 2025-05-04, 16:05:
Yeah that’s what I get for going off blurry pics before getting the hardware in hand haha. 40pins sounds more appropriate haha. And yeah those are good points. The CAS and cycles ratings and stuff are what confused me as to what will work and what won’t work
Reply 8 of 9, by 9646gt
dionb wrote on 2025-05-04, 16:15:
The Mach32's DOS VESA compatiblity is a bit hit and miss, see here for a list of test results: https://gona.mactar.hu/DOS_TESTS_ […]
Thank you for confirming my suspicions on it being VLB! That makes the decision to stick with it make much more sense especially given what you mention about the Windows 3.x performance. If I upgrade it to 2mb and avoid the troublesome games from that link (I don’t think I’d be playing any of those specific ones) I’d probably be set for up to 640x480 and anything that requires better hardware but isn’t speed sensitive I’ll have my P233 machine for!
Reply 9 of 9, by 9646gt
chinny22 wrote on 2025-05-05, 01:04:
That’s great to hear!
