Slot2 Intel C440GX+ with Dual Pentium 3 Xeon
First post, by Jackhead
another fun build i want to try out. Still waiting for the parts.
When it comes to server boards of this Area, what i need to look after because the extra power connectors?
My board comes full boxed with this 2 power boards above the IDE ports. What are they for?
And between the IDE slots and RAM there is another power connector looks like an AT like plug? Kind of pre P4 plug?
As OS i plan NT4 or Win2k, depends on NT4 is working with it..
Still have two U160 18GB HDDs for it.
Here some shot from my parts so far:
The attachment 2554.jpg is no longer available
The attachment IMG_8473.jpg is no longer available
The attachment 231.jpg is no longer available
The attachment GpxeDNvWgAAJtcD.jpg is no longer available
The attachment GpxeDNyWwAAdA4-.jpg is no longer available
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 30, by PC Hoarder Patrol
Those are the two processor VRM modules...the AT-style connector will be for extra juice on heavily loaded systems
Reply 2 of 30, by Jackhead
So i deffently need the two moduls installed, That extra voltage connector is there maybe an adapter for a ATX PSU?
Reply 3 of 30, by Intel486dx33
I had a similar computer back in 1990’s
I used the Intel DK440LX motherboard
Specs:
Intel DK440LX
Dual Pentium II @ 333mhz
64mb RAM
Onboard SCSI
Dual Seagate SCSI hard drives
AGP ATI Xpert 98 video card 8mb
3com 3c509 Network card
Sound Blaster 16
Sun Solaris x86
Cost me about $1,000 to build back in 1999
I think these computers would run best with Win2000
Reply 4 of 30, by Jackhead
nice, Intel DK440LX should be Slot1. Im looking long time for a Slot2.
Yes win2k would be the best. But i like NT4 for DOS and multi CPU support.
Reply 5 of 30, by Intel486dx33
Lol.
Looks like an expensive build.
From what I remember back around year 2000 we were using Dell Servers with Dual Xeons in our server rooms running Win2000.
WinNT 4.0 was used around 1997-thru-2000 on Pentium-I thru Pentium-3 CPU’s
We use to teach WinNT 4.0 on Pentium 90 computers with 16mb thru 32mb RAM in our computer education classrooms
Reply 6 of 30, by Jackhead
Intel486dx33 wrote on 2025-05-02, 18:18:
Lol. Looks like an expensive build. From what I remember back around year 2000 we were using Dell Servers with Dual Xeons in our […]
Lol.
We use to teach WinNT 4.0 on Pentium 90 computers with 32mb RAM in our computer education classrooms
Im so ready for this!
Reply 7 of 30, by Intel486dx33
My DK440LX motherboard cost about $300 back around 1999
And that was allot of Money back then for a motherboard.
I think I paid about $150 for each CPU.
I only used 64mb of RAM because it was expensive too.
So were the SCSI hard drives.
How much do you think your motherboard cost back in year 2000 ?
What is the manufacture date on your motherboard and CPU’s ?
This was my personal home file server and webserver.
We were the First to have cable modem high speed internet in our area.
I think we had 50mb or 100mb a second internet service.
Reply 8 of 30, by Intel486dx33
Hey also there is a Memory limit on WinNT 4.0 Server
I think it’s like a maximum of 2gb. of Memory.
You need to install the Service pack first before adding more memory.
You might also only need to use One CPU at initial install before applying the Service pack.
But I am not sure about the limitations so don’t quote me on this.
Reply 9 of 30, by Jackhead
i bought another slot2 pair, SL4XZ 900MHz 2MB L2. Im not sure my board support the 1GHz because of FSB. So SL4XZ should be fine.
What i still dont get, why there was 2 variantes 2,8V and 5V/12V ??
Reply 10 of 30, by Intel486dx33
Jackhead wrote on 2025-05-07, 19:26:
Where do you find these Slot-2 motherboards ?
You can’t find them in USA ?
I have a few Intel Dual Slot-1 server motherboards I purchased when they were decommissioned and being liquidated for cheap.
But I have miss placed my box of Pentium-3 CPU’s so I can’t do anything with them until I find that box.
It’s somewhere in my Garage full of cardboard boxes.
Reply 11 of 30, by Jackhead
i searched from time to time and found one on a local sale. Sometimes 🍀
Reply 12 of 30, by Jackhead
board arrived, installed the Slot 2 mount with the cooling solution.
The attachment IMG_8517.jpeg is no longer available
The attachment IMG_8516.jpeg is no longer available
Reply 13 of 30, by Intel486dx33
Wow that’s HUGE.
What computer case are you going to use ?
Reply 14 of 30, by chinny22
I'm subscribing to this, Slot 2 very nice!
And that cooling setup definitly looks the business
Reply 15 of 30, by luckybob
OK FULL STOP.
Those cpus are NOT going to work in this board. In fact if you power those chips in the board, its likely to damage something.
You are required to use the "retail" 2.8v cpus. The 5/12v cpus are designed for OEM installations like Dell, Compaq, IBM, etc.
The fastest chips for this board are the SL4XY chips: https://www.cpu-world.com/sspec/SL/SL4XY.html
They are also unobtanium. I haven't seen a single one on ePay in the better part of a decade.
Reply 16 of 30, by Jackhead
Yes that are the 133FSB CPUs that dont work. I just put them in for testing if anything fits. 😀
Im waiting for the correct CPUs, SL4XZ. The board itself is able to run 12v/5V CPUs. I have both VRMs. Officially its 550MHz supported, but pretty sure the 900MHz FSB100 will also work. I found all the bios updates, i will see..
For the Case, im not going time correct and use a north xl from fractal.
The attachment IMG_8520.jpeg is no longer available
The attachment IMG_8519.jpeg is no longer available
One question i still dont know is, do i really need the AUX power connector? Manual say i need it when board has heavy load, whatever that means.. But i ordered me some cables to build that connector..
Reply 17 of 30, by luckybob
The SL4XZ is NOT the correct processor for this board. DO NOT INSTALL A 12V/5V CPU into a board unless it EXPLICITLY STATES it is compatible. I looked through the manual, and it makes NO mention of 5/12 processors.
Reply 18 of 30, by luckybob
The 5/12 processors have integrated voltage regulators. the 2.8v cpus do not. If a slot-2 motherboard has separate voltage regulators AS YOUR DOES, it means it is designed for the 2.8V processors.
Reply 19 of 30, by Jackhead
Why is it written on the VRM ports that it is capable to run 12/5V ?
