First post, by EvieSigma
I purchased an IBM 5170 AT today and among the cards was this mystery EGA card. Unfortunately "Video Seven Inc" and the "G2" Gemini branded video chip aren't things I recognize, can someone help me identify this card so I can locate the DIP switch settings?
The attachment PXL_20250509_211659692.jpg is no longer available
The attachment PXL_20250509_211706845.jpg is no longer available
Reply 1 of 6, by dionb
Video Seven was one of the bigger early video card vendors. Later changed its name to Spea.
There are a bunch of 8b EGA cards of theirs on TheRetroWeb: https://theretroweb.com/expansioncards/?manuf … itemsPerPage=24
Yours doesn't match any exactly, but EGA jumper & switch settings tend to be pretty standard. In particular, the first four switches are almost always the same as on the IBM EGA card, so yours set to off-on-on-off are for EGA enhanced (high-res). Don't hook this up to CGA monitor with these settings...
Reply 2 of 6, by wbahnassi
It's a variant of one of those two:
http://www.uncreativelabs.de/th99/v/C-D/50009.htm
http://www.uncreativelabs.de/th99/v/U-Z/50790.htm
Try the switches from each case and see which one matches the behavior.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 3 of 6, by EvieSigma
wbahnassi wrote on 2025-05-10, 05:01:
It's a variant of one of those two: […]
Neither of those have the 16K/64K jumper so they're not a match.
Reply 4 of 6, by wbahnassi
Yes, it's neither, but there is a good possibility the switches match. It's worth trying IMO. Hopefully you find the exact model's manual, but good luck either way.
Reply 5 of 6, by Kittyboy
Congratulations with the new toy. Just reading the words "Video 7" and "EGA" conjures so many memories. I recall how exciting and future forward it was upgrading from EGA to VGA at the time.
Pentium III 1.4GHz-S (SL6BY), Asus TUV4X, Plextor 760A, ATI 9800 Pro, MS-DOS 6.22/Win98se dual boot
Reply 6 of 6, by Kittyboy
Out of curiosity, what is your method of cleaning? Your new board is definitely a candidate for a good bath. To what degree is it good practice to clean prior or after functional testing? I assume at least the terminals prior to firing up the first time.
