Reply 1620 of 1628, by SquallStrife
- l33t
SquallStrife wrote on 2025-04-04, 22:44:I'm going to split large files into ~32MB volumes on the BBS, since I imagine the use case for the larger files is pretty limited on systems where BBS access is your /only/ option, and large downloads in volumes are kinda period correct anyway 🤣!
I've re-built the file database, including building a file_id.diz for each download. Searching is better than before, listings are much more readable, and adding files to the download queue won't crash your session.
Winning!
