Maj.Jackyl's Computer Lab
Reply 100 of 239, by Major Jackyl
Random, but I find it satisfying to have just the right thing when doing a job. In this case:
The attachment 20250531_131215.jpg is no longer available
For Distribution ONLY with a new COMPAQ. Good stuff.
It's still installing. I think I'm on the final reboot.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 101 of 239, by Major Jackyl
I've just realized another interesting thing about this Compaq: the power supply. It has +5VSB. It's pretty much ATX but with the AT P8/P9. My Deskpro is weird like this as well, but it doesn't have this strange green one. I checked them and they are all 3.3V
The attachment 20250531_122823_B.jpg is no longer available
Daily Units:
Reply 102 of 239, by Major Jackyl
The Compaq passes and will now be added to the collection. I spent the rest of the day playing on it yesterday and it worked perfectly. Even ran the VCR through it and it works good.
The attachment 20250531_151431.jpg is no longer available
The attachment 20250531_145428.jpg is no longer available
The attachment 20250531_153526.jpg is no longer available
This last "issue" is actually a "sh*tty disc" problem. EVERY computer I've ever tried to install ROTT DW on, it does this. I can copy the game off the disc and play it, but the installer is corrupt.
The attachment 20250531_154039.jpg is no longer available
Daily Units:
Reply 103 of 239, by Major Jackyl
Now, I'm pulling apart a few computers to correct some issues. I jumbled together a computer with ASUS P5QPL-AM and P4 650 and it needs work. It will randomly slow down to the point where I would normally expect a blue-screen, but it troops through it and returns to normal. More frequent in CPU intensive areas. NOT do-able, so I'm going to try replacing/upgrading the CPU to either Core2Duo E6750 or Core2Quad Q6600. Not sure how I want to do it yet, but I think I'm leaning towards the Duo, since I only really need single core performance on that machine.
The attachment 20250601_115554.jpg is no longer available
THIS issue was brought to you by this OTHER issue. My P5N-D computer "DiskWizard 2" crashed while gaming a while back and crashes randomly now. I know it's the motherboard, because it's been on it's last leg for YEARS and it just keeps trooping along. The Pentium D 960 is running at 4.2, so that's probably not helping, but this thing was always doggy and slow without an overclock. The P5QPL was supposed to be the back-up!
The attachment 20250601_115827.jpg is no longer available
What I'm going to do, is steal the GPU out of "DW2" and put it into the P5QPL system along with the CPU upgrade. The P5QPL is running a XFX 9800GT that WAS on ITS last leg, too, but seems to be working normally after I upgraded the cooler, as a test. Since the chipset is actually "modern" I can pair the C2D or C2Q with the GTX 460 and have a decent match. The P4 was indeed a hard bottleneck.
The attachment 20250601_120115.jpg is no longer available
Daily Units:
Reply 104 of 239, by Major Jackyl
The upgrade to the P5QPL went smoothly. I decided to go with the Core2Duo(E6750).
The attachment 20250601_152742.jpg is no longer available
Started right up after the BIOS was done reconfiguring. I did "de-tune" the memory, so I could have 1:1 DRAM/FSB ratio. The difference in latency was nil between 667 and 800. I tightened the timings a little, too; 4-4-4-12. Got 5ns faster. I feel like I should be able to do better, but this is good.
The attachment Screenshot 2025-06-02 174217.png is no longer available
I had to install windows XPx64, since I had 32-bit on it. Pretty much unnecessary, but I wanted to properly gauge performance vs. the AMD counter-part it will be playing with/against and didn't want the OS to be a variable.
I was gaming for hours and it didn't do "the thing" once. It's not belching out hell's inferno, either. The GPU is hot, but it was doing that already; normal. Ready for LAN party again!
Daily Units:
Reply 105 of 239, by Major Jackyl
Wow, so I decided to race these two real quick, since they're both plugged in. VISUALLY 3dmark 2001 took almost the same amount of time. Maybe 5 seconds off. I was expecting the faster computer to go faster, but it was essentially the SAME. The "FPS" readout on the AMD was almost double the other the whole time. Probably going to try racing 03 and 05 next.
The attachment Screenshot 2025-06-02 181457.png is no longer available
Daily Units:
Reply 106 of 239, by Major Jackyl
I ran 2003 and it was pretty much like 2001. Both ran different speeds, but the tests were about the same.
The AMD scored 73381 and the C2D got 47652. I'm guessing this is mostly a difference in GPUs.
And now I ran 3Dmark2005 and woah! Such excitement! The AMD started off good, a few seconds lead with a quicker load time. They also went about the same until it got to the CPU test. The Core2Duo left the AMD in the dust! It was clearly going faster. The Intel finished first with a 21 second lead!
The attachment Screenshot 2025-06-02 195433.png is no longer available
The attachment Screenshot 2025-06-02 195418.png is no longer available
Daily Units:
Reply 108 of 239, by Major Jackyl
I decided to benchmark my ZEOS today and had a few problems.
The attachment 20250604_173145.jpg is no longer available
I just wanted to run SpeedSys and get scores for turbo ON and turbo OFF. It slows it down so hard, I'd like to see the numbers on that. It can "run" duke3d and quake with turbo ON, 🤣 Pretty hilarious turning it OFF while duke is running.
First issue, was needing to bypass my config.sys/autoexec.bat. I think this was the least of my problems...
The attachment 20250604_162042.jpg is no longer available
When I opened speedsys, it reminded me and then crashed anyway. I tried it again, but it crashed again, and then gave me some of THIS sh*t...
The attachment 20250604_163920.jpg is no longer available
Why does it have to give me such guff?! What happened to my memory?! I powered off and back on and it was normal again. I tried opening speedsys again, and it got hung in loading speedsys: "Determining System Contents... ATA/ATAPI device 0 at port 01f0". Ctrl+Alt+Del was dead, Reset is good.
I tried a few different things, but it kept getting stuck there. I disabled the HDD in the BIOS, as I don't really want to open it right now. This time, it actually opened and started running. Did the non-turbo test first and it took a very long time...
The attachment ZEOS_VAN.png is no longer available
Only about 7 minutes with turbo. Probably 20+ without...
The attachment ZEOS_TUR.Png is no longer available
Interesting that the HDD is shown is speedsys still. Not sure why the drive causes it to lock-up. I was checking everything and it runs just fine.
Daily Units:
Reply 109 of 239, by Major Jackyl
🤣 I booted my work computer from floppy and ran speedsys after I changed the .pcx to .png. Astounding, 🤣
The attachment AX2_4600.png is no longer available
In other news, I went back to the ZEOS to enable the HDD and it consistently gives me the memory error and POSTs no memory. Booo. I'll open it, it suppose. It has two different sets of four in it now.
The attachment 20250412_165533.jpg is no longer available
I'll try reseating them. I have a few sticks that need testing, too, so I can do that, since this is my only computer that takes 30-pin SIMMs
The attachment 20250604_184710.jpg is no longer available
Daily Units:
Reply 110 of 239, by Major Jackyl
I opened the ZEOS and turned it on and it did absolutely nothing. I pulled all the memory out and powered it on to more nothing. Not even a beep. I tried the memory I had laying around and it beeped to life again. It just gave me this warning:
The attachment 20250605_200910.jpg is no longer available
The amount of memory has to be set in the BIOS:
The attachment 20250605_203002.jpg is no longer available
Luckily, during the memory check, it counts the memory that is installed, so I just put that in and it was fine again.
This time it ran SpeedSys just fine. Same result. Loading DOS seems a bit faster, though.
The attachment ZEOS_16M.Png is no longer available
If I can find four more of the 4MB modules, I could have a whopping 32MB. I've been wanting to try upgrading the CPU, but it's fun just being a slowpoke. Testing these CPUs, though, would be nice. They all probably work.
The attachment 20250605_220401.jpg is no longer available
My concern is if I would have to take the co-processor out. Would these faster CPUs even need the co-processor, or would that still help? I should run speedsys without it, see if it's even doing anything in that department.
Daily Units:
Reply 111 of 239, by Major Jackyl
I want to get the RTC module I modified out of the danger zone and back to it's board. It's a DS1220Y-200 and has another chip under it that I needed to bore into to grab the correct leg to replace the battery.
Major Jackyl wrote on 2025-05-22, 01:22:
The attachment Screenshot 2025-05-21 200426.png is no longer available
The attachment Screenshot 2025-05-21 200412.png is no longer available
Major Jackyl wrote on 2025-05-22, 23:21:
The attachment 20250522_181016.jpg is no longer available
The attachment 20250522_181112.jpg is no longer available
The attachment 20250522_181028.jpg is no longer available
Now I got the changer apart, and its pretty cool. The back came off and the board was in a slot with card-edge connectors. I'm glad it was so easy. This thing looks like a nightmare to take apart, SO many different screws.
The attachment 20250606_174829.jpg is no longer available
The attachment 20250606_174819.jpg is no longer available
The attachment 20250606_174757.jpg is no longer available
I'll try testing it later, after it's all cleaned and reassembled.
Daily Units:
Reply 112 of 239, by Major Jackyl
I acquired a 486 board today, in the box. It was "tested" as bad. Yay, a broken board, finally (or so I thought...)
The attachment 20250607_130105.jpg is no longer available
The attachment 20250607_135413.jpg is no longer available
I first removed the battery and replaced it. I wasn't going to leave that battery for even a second longer.
The attachment 20250607_135257.jpg is no longer available
I went to test it and it was very much alive and beeping. Memory beeps. Video beeps, sometime no beeps and nothing.
The attachment 20250607_134930.jpg is no longer available
Not surprising, since the stick in it looked like this:
The attachment 20250607_135605.jpg is no longer available
I got a few sticks working in it and it booted right up!
I was able to boot DOS on a floppy and run speedsys and got 8.67. Something going on, because that seems pretty low for 66Mhz...(didn't save result, crashed after removing turbo jumper).
I'm going to clean the board since all that problems it keeps having are intermittent and go away when I plug/replug VGA/memory. Very much symptoms of dirty board (even though it looks pretty clean)
Daily Units:
Reply 113 of 239, by Major Jackyl
I cleaned the board and added the RAM and ISA video card and powered it up. It POST'd normally and failed floppy. I added a card with a floppy header, so I could try booting. Booted just fine.
The attachment 20250608_153245.jpg is no longer available
The attachment 20250608_153250.jpg is no longer available
Huzzah! It seems to work just fine after a cleaning. I tried plugging in my ST1280 to the Seagate controller, but showed me a very unusual prompt about no installer software on the drive and wanted to format. I told it NO, powered off, and grabbed good ol' 1542CF, installed THAT and it booted (after I reconfigured, it wasn't set to boot device).
During one of the reboots, I switched in my Trident TGUI9400CXi VLB and tested that. Hell yeah, it works!
The attachment 20250608_154940.jpg is no longer available
The attachment 20250608_165341.jpg is no longer available
I haven't ran a lot on it yet, but what I have opened, works just fine. I wanted to start a fresh DOS drive for the thing, but I don't have the proper drive(s). My IDE drives are too large and confused it. Smallest I have is 1.6G right now and that was too large. System just locks up at POST, but responds to "del".
If I grab a CD drive, I can load some more stuff on the Seagate, or even use my SyQuest drive (which I previously loaded with games) since I'm using the SCSI controller and the Seagate is already set-up for it.
It has an error when loading SpeedSys and only runs the CPU test. Sounds like there is not enough memory. Could be the DOS 7.1, too.
The attachment ML486.Png is no longer available
Also, it seems to be happy with the 2032 battery. Something else to note, there is no Multi I/O controller or ANYTHING on this board. Nothing but unknown jumpers. Can't find any information about this board. The closest thing I've found is here:
https://theretroweb.com/motherboards/s/matra-486slc2-vesa
I'll have to box this back up for a bit, though, because I have a sh*tbox to work on and a mystery machine that needs re-organizing (and cleaning). When the table is clear, I want to try running Doom.
Daily Units:
Reply 114 of 239, by Major Jackyl
I'll try to deal with these quickly, so I don't change generations again again. The first is another Micron Millenia Pentium computer.
The attachment 20250608_121023.jpg is no longer available
THIS one says it doesn't work, as well. Will it work?
I started with gutting it and giving the board a good wash.
The attachment 20250608_195338.jpg is no longer available
Same Micronics M54Hi, but this one has BIOS version 10PM, the other one I have is 09PM. The socket for the BIOS was also damaged already when I removed it for cleaning. It had a single 16M stick of memory and a P150, with an unusual-looking top (at least, compared to the other ones I've been handling lately). It had a screw-type cooler with a fan on it. I will use a passive cooler for the testing.
The attachment 20250608_195352.jpg is no longer available
Nothing else in the Case. Case is in good condition, but I'll chuck it if the board is bad. Probably rebuild it if it's O.K.
Time to test!
Daily Units:
Reply 115 of 239, by Major Jackyl
Aaaaaaand, damn it. I have to get the case from the garage, 🤣 That's a tomorrow problem.
Here's my scrap collection, some unprocessed cases, too. As long as it's not in the way, I don't toss anything until the very last second. They just sit around, looking like some kind of retro graveyard.
The attachment 20250609_161553.jpg is no longer available
The board POST'd first try and wanted some CMOS settings.
The attachment 20250608_194618.jpg is no longer available
The attachment 20250608_194706.jpg is no longer available
I'll rebuild this thing later, I want to clean and test the next one, then get back to slow-town.
Daily Units:
Reply 116 of 239, by Major Jackyl
I already have that apart, but not clean yet.
The attachment 20250608_140542.jpg is no longer available
MMkay, We have PCChips M848A, single 512M stick of DDR400. Hmm, this is a PCI video card, a TNT2 16M...
The attachment 20250609_175449.jpg is no longer available
And hiding under this heatsink we have THIS guy:
The attachment 20250609_175653.jpg is no longer available
Got another 1Ghz Thunderbird!! Totally made my day.
But... I wiped the heatsink and was disappointed with the results, so I scratched harder:
The attachment 20250608_203550.jpg is no longer available
I think I'll put it aside, for when I work on the other 462 boards. I'll just get it all cleaned for now.
I had no idea what was hiding in this one! So fun!
Daily Units:
Reply 117 of 239, by Major Jackyl
Duuuude! What the f%^?! I was getting ready to power on that 486 board again. I'm shook. I was going to try testing one of the WDPFCARD cards, since I had the screen in the room, too. I plugged the monitor in and was working on plugging the drives when I powered it on to check a fan, heard the drive spin up, like whoops, BUT what the HECK! The screen powered on and the motherboard was POSTing!! It's getting all it's power through that interface?!? So cool.
The attachment 20250610_172836.jpg is no longer available
The attachment 20250610_172845.jpg is no longer available
Daily Units:
Reply 118 of 239, by Major Jackyl
So for my testing, I 'm using this "WDFPCARD" which has Western Digital WD90C24LC-ZZ with 1MB memory for video. The card is also a multi I/O card, which is perfect for a bare board like this one. There appears to be a VGA hearer on the board as well. The video output is going through a proprietary SCSI cable to the monitor(regular cables don't work). The problem, is I haven't been able to find any information on the card, so I'm not sure what can be set. I have three of these cards, three screens, but only two cables...
The attachment 20250610_190205.jpg is no longer available
I have a floppy power plugged into the back of the "WDFPTERM" (the screen) and nothing happens if it is plugged into any of the other plugs (it has 3xfloppy headers and a molex, unsure of anything). Somehow the motherboard gets its power through the 5V going into the monitor, through that cable.
The attachment 20250610_191445.jpg is no longer available
I blasted through keen1 before loading the CD and copying some more stuff over. I started with DOOM and got this fun message:
The attachment 20250610_184047.jpg is no longer available
Doom Aborted!! Noooo, 🤣 I have four more megabytes of RAM, but it's mismatched, which is what was causing problems in my ZEOS and it is no different here. I tried them, but it was crashing over every little thing. Some times it would make it do DOS, but crash in a few minutes, even just sitting at the prompt. Removing them returned normal functionality.
I'll bypass autoexec/config and just run unisound for the ESS 1869F then open Doom. I added the sound card when I opened keen4 to test the sound and there was none. Because there was no sound card... 🤣
The attachment 20250610_185943.jpg is no longer available
I finally opened Doom and it ran, just a bit small. Sound was good, so I played mostly through the first episode before wondering why I was doing this to myself, 🤣
The attachment 20250610_184352.jpg is no longer available
Very authentic, I feel. I had Pentium or better since I first found Doom and never had an issue running it. Until I got my ZEOS. Now I get to see it AGAIN! The ZEOS is definitely faster than this thing, because I can at least DOOM in fullscreen, 🤣
Daily Units:
Reply 119 of 239, by Major Jackyl
Holy sh*t!! I was playing Cosmo2 when "POP" and sparks shot across my desk and I immediately turned off AC. Tant blew up on the WDFPCARD
The attachment 20250610_195217.jpg is no longer available
I put another WDFPCARD in and it started just fine, booted and worked just as it was. I'll swap back to the Trident again for now, don't want to use the WD card until I get all the tants replaced.
That was my first exploding tant. Scared the sh*t out of me. Thing was loud! And because it was more or less pointed right at me, I got to see the fireworks.
Daily Units:
