Maj.Jackyl's Computer Lab
Reply 100 of 110, by Major Jackyl
Random, but I find it satisfying to have just the right thing when doing a job. In this case:
The attachment 20250531_131215.jpg is no longer available
For Distribution ONLY with a new COMPAQ. Good stuff.
It's still installing. I think I'm on the final reboot.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 101 of 110, by Major Jackyl
I've just realized another interesting thing about this Compaq: the power supply. It has +5VSB. It's pretty much ATX but with the AT P8/P9. My Deskpro is weird like this as well, but it doesn't have this strange green one. I checked them and they are all 3.3V
The attachment 20250531_122823_B.jpg is no longer available
Reply 102 of 110, by Major Jackyl
The Compaq passes and will now be added to the collection. I spent the rest of the day playing on it yesterday and it worked perfectly. Even ran the VCR through it and it works good.
The attachment 20250531_151431.jpg is no longer available
The attachment 20250531_145428.jpg is no longer available
The attachment 20250531_153526.jpg is no longer available
This last "issue" is actually a "sh*tty disc" problem. EVERY computer I've ever tried to install ROTT DW on, it does this. I can copy the game off the disc and play it, but the installer is corrupt.
The attachment 20250531_154039.jpg is no longer available
Reply 103 of 110, by Major Jackyl
Now, I'm pulling apart a few computers to correct some issues. I jumbled together a computer with ASUS P5QPL-AM and P4 650 and it needs work. It will randomly slow down to the point where I would normally expect a blue-screen, but it troops through it and returns to normal. More frequent in CPU intensive areas. NOT do-able, so I'm going to try replacing/upgrading the CPU to either Core2Duo E6750 or Core2Quad Q6600. Not sure how I want to do it yet, but I think I'm leaning towards the Duo, since I only really need single core performance on that machine.
The attachment 20250601_115554.jpg is no longer available
THIS issue was brought to you by this OTHER issue. My P5N-D computer "DiskWizard 2" crashed while gaming a while back and crashes randomly now. I know it's the motherboard, because it's been on it's last leg for YEARS and it just keeps trooping along. The Pentium D 960 is running at 4.2, so that's probably not helping, but this thing was always doggy and slow without an overclock. The P5QPL was supposed to be the back-up!
The attachment 20250601_115827.jpg is no longer available
What I'm going to do, is steal the GPU out of "DW2" and put it into the P5QPL system along with the CPU upgrade. The P5QPL is running a XFX 9800GT that WAS on ITS last leg, too, but seems to be working normally after I upgraded the cooler, as a test. Since the chipset is actually "modern" I can pair the C2D or C2Q with the GTX 460 and have a decent match. The P4 was indeed a hard bottleneck.
The attachment 20250601_120115.jpg is no longer available
Reply 104 of 110, by Major Jackyl
The upgrade to the P5QPL went smoothly. I decided to go with the Core2Duo(E6750).
The attachment 20250601_152742.jpg is no longer available
Started right up after the BIOS was done reconfiguring. I did "de-tune" the memory, so I could have 1:1 DRAM/FSB ratio. The difference in latency was nil between 667 and 800. I tightened the timings a little, too; 4-4-4-12. Got 5ns faster. I feel like I should be able to do better, but this is good.
The attachment Screenshot 2025-06-02 174217.png is no longer available
I had to install windows XPx64, since I had 32-bit on it. Pretty much unnecessary, but I wanted to properly gauge performance vs. the AMD counter-part it will be playing with/against and didn't want the OS to be a variable.
I was gaming for hours and it didn't do "the thing" once. It's not belching out hell's inferno, either. The GPU is hot, but it was doing that already; normal. Ready for LAN party again!
Reply 105 of 110, by Major Jackyl
Wow, so I decided to race these two real quick, since they're both plugged in. VISUALLY 3dmark 2001 took almost the same amount of time. Maybe 5 seconds off. I was expecting the faster computer to go faster, but it was essentially the SAME. The "FPS" readout on the AMD was almost double the other the whole time. Probably going to try racing 03 and 05 next.
The attachment Screenshot 2025-06-02 181457.png is no longer available
Reply 106 of 110, by Major Jackyl
I ran 2003 and it was pretty much like 2001. Both ran different speeds, but the tests were about the same.
The AMD scored 73381 and the C2D got 47652. I'm guessing this is mostly a difference in GPUs.
And now I ran 3Dmark2005 and woah! Such excitement! The AMD started off good, a few seconds lead with a quicker load time. They also went about the same until it got to the CPU test. The Core2Duo left the AMD in the dust! It was clearly going faster. The Intel finished first with a 21 second lead!
The attachment Screenshot 2025-06-02 195433.png is no longer available
The attachment Screenshot 2025-06-02 195418.png is no longer available
Reply 108 of 110, by Major Jackyl
I decided to benchmark my ZEOS today and had a few problems.
The attachment 20250604_173145.jpg is no longer available
I just wanted to run SpeedSys and get scores for turbo ON and turbo OFF. It slows it down so hard, I'd like to see the numbers on that. It can "run" duke3d and quake with turbo ON, 🤣 Pretty hilarious turning it OFF while duke is running.
First issue, was needing to bypass my config.sys/autoexec.bat. I think this was the least of my problems...
The attachment 20250604_162042.jpg is no longer available
When I opened speedsys, it reminded me and then crashed anyway. I tried it again, but it crashed again, and then gave me some of THIS sh*t...
The attachment 20250604_163920.jpg is no longer available
Why does it have to give me such guff?! What happened to my memory?! I powered off and back on and it was normal again. I tried opening speedsys again, and it got hung in loading speedsys: "Determining System Contents... ATA/ATAPI device 0 at port 01f0". Ctrl+Alt+Del was dead, Reset is good.
I tried a few different things, but it kept getting stuck there. I disabled the HDD in the BIOS, as I don't really want to open it right now. This time, it actually opened and started running. Did the non-turbo test first and it took a very long time...
The attachment ZEOS_VAN.png is no longer available
Only about 7 minutes with turbo. Probably 20+ without...
The attachment ZEOS_TUR.Png is no longer available
Interesting that the HDD is shown is speedsys still. Not sure why the drive causes it to lock-up. I was checking everything and it runs just fine.
Reply 109 of 110, by Major Jackyl
🤣 I booted my work computer from floppy and ran speedsys after I changed the .pcx to .png. Astounding, 🤣
The attachment AX2_4600.png is no longer available
In other news, I went back to the ZEOS to enable the HDD and it consistently gives me the memory error and POSTs no memory. Booo. I'll open it, it suppose. It has two different sets of four in it now.
The attachment 20250412_165533.jpg is no longer available
I'll try reseating them. I have a few sticks that need testing, too, so I can do that, since this is my only computer that takes 30-pin SIMMs
The attachment 20250604_184710.jpg is no longer available
Reply 110 of 110, by Major Jackyl
I opened the ZEOS and turned it on and it did absolutely nothing. I pulled all the memory out and powered it on to more nothing. Not even a beep. I tried the memory I had laying around and it beeped to life again. It just gave me this warning:
The attachment 20250605_200910.jpg is no longer available
The amount of memory has to be set in the BIOS:
The attachment 20250605_203002.jpg is no longer available
Luckily, during the memory check, it counts the memory that is installed, so I just put that in and it was fine again.
This time it ran SpeedSys just fine. Same result. Loading DOS seems a bit faster, though.
The attachment ZEOS_16M.Png is no longer available
If I can find four more of the 4MB modules, I could have a whopping 32MB. I've been wanting to try upgrading the CPU, but it's fun just being a slowpoke. Testing these CPUs, though, would be nice. They all probably work.
The attachment 20250605_220401.jpg is no longer available
My concern is if I would have to take the co-processor out. Would these faster CPUs even need the co-processor, or would that still help? I should run speedsys without it, see if it's even doing anything in that department.
