Cool, I didn't know about this tool, I'll have to try it.
And what difference would you guess between 1/2-cycle EDO? It seems there are some other video memory timings CRs...
UPDATE:
good tool, changing EDO from 2 cycle to 1 cycle makes a huge difference in VESATEST, 15 -> 22 MB/s (RAM->FB)!
default MCLK=59,96MHz m=65, n=2, r=2 (well BIOS set it but I cannot see it in DASM)
In 2-cycle mode transfer speed scaled with increasing MCLK up to cca 73MHz where it capped to 22MB/s and even change to 1-cycle EDO didn't push more. I could push MCLK insanely high at 100MHz, over 104MHz I saw some snowing artifact and at ~110MHz it messed up textmode and hanged.
In Doom the MCLK effect is zero.
In Quake 320x200 and 640x480 also the same...
