First post, by keeper5511
Hello everyone,
I have found my old Socket 370 motherboard QDI Advance 10f and I am trying to get it back to life. Unfortunately system doesh 't post and I used Post analyzer card. It seems that Reset is stuck and I don't have clock led on ISA slot!!!!
I have used oscillator and check CPU bus clock (66MHz with Celeron) and PCI clock (33 MHz) which is correct too. As far as ISA I have 14,3 MHz on High-speed Clock (70 ns, 14.31818 MHz, 50% duty cycle) but I can not count system clock on B20 pin. I think that I must have System Clock 8-8.33 MHz according to ISA datasheet. I have also have checked crystals and they seem to work fine.
So, does anyone know if system clock on ISA can prevent system from posting (Stay Reset stuck)???? And if so, What can I do to save this motherboard?????
