First post, by Kouwes
I wanted to transfer a bunch of files to my 486 using my zip drive. Copied all the desired stuff to a disk using a Win98 PC, so the zip drive is working.
The 486 however doesn’t seem to like that drive. It’s an 5x86 133 with Soyo PCI board (and even 1 VLB slot 🙂). Its has an onboard controller, 32MB RAM and DOS6.22
I checked the config.sys and Lastdrive=G should be good for the 3 drives, including a CD-ROM drive, I am using in that machine.
The iomega did work well the last time I used it with a Pentium 233MMX that only has DOS6.22 on it - no Windows.
It’s a parallel port zip drive, that port is also active in the 486 BIOS and shows up while booting. Since it uses IRQ7, just like the installed GUS Classic, I booted the PC bypassing autoexec and config but that didn’t change anything, I still get: No drive letter assigned.
Any ideas?
Reply 1 of 2, by Nexxen
Have you installed the drivers?
https://archive.org/details/zip_disk_dos_install
Vogons drivers should have the archive as well.
https://www.vogonsdrivers.com/index.php?catid … menustate=74,70
IIRC you have to use the combo DOS tools and DOS drivers.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 2 of 2, by Kouwes
I got the DOS drivers but I didn’t know which one to use so I tried the included GUEST.EXE first and yeah, that worked.
Probably another version than I used before…weird but hey, it works now so all good.
