First post, by Kouwes
- Member
I wanted to transfer a bunch of files to my 486 using my zip drive. Copied all the desired stuff to a disk using a Win98 PC, so the zip drive is working.
The 486 however doesn’t seem to like that drive. It’s an 5x86 133 with Soyo PCI board (and even 1 VLB slot 🙂). Its has an onboard controller, 32MB RAM and DOS6.22
I checked the config.sys and Lastdrive=G should be good for the 3 drives, including a CD-ROM drive, I am using in that machine.
The iomega did work well the last time I used it with a Pentium 233MMX that only has DOS6.22 on it - no Windows.
It’s a parallel port zip drive, that port is also active in the 486 BIOS and shows up while booting. Since it uses IRQ7, just like the installed GUS Classic, I booted the PC bypassing autoexec and config but that didn’t change anything, I still get: No drive letter assigned.
Any ideas?
