First post, by egbertjan
I have an asus p2b rev 1.12. I see in the manual that there is an asus p2t cable to measure the cpu temperature, unfortunately I can't find it anywhere (Does anyone know where you can buy the cable?). My modern asus motherboard has a temperature sensor cable, see picture
This is the product number ASUS 14011-00020100
Can I also put this cable on the 2 pin connection on the motherboard and measure the cpu temperature?
If I can use this, what is the best way to stick it to the cpu and where on the cpu can I do that best?
