First post, by Danger Manfred
I was looking up TDPs for graphics cards from the AGP era, and to my great frustration, cards from the Voodoo to Radeon Xx00 era have apparently never been properly measured.
Example: Wikipedia lists a Radeon 9500 Pro with 50W TDP, 9700 with 42W.
This czech size I found (https://www.svethardware.cz/prehled-desktopov … h-cipu/23045-21) claims they would draw 12 and 15W respectively.
Now obviously this can't both be true, but I have found wrong data on both sites already, so who whould I trust here?
Unfortunately, I do not have a device for measuring this.
All I know is I have a very poorly ventilated case with only a single 60x25mm Noctua case fan, and a 32W TDP CPU.
A 10-20W graphics card would be MUCH better for the case temperature than a 30-50W card.
In the most extreme case, it would make the difference between having to dissipate 40 vs 80 Watts of heat from the case!
Do we have any reliable sources on graphics cards' power draw from about the Geforce 2 to FX and Radeon 9000 series cards?
