Choice of sound card in a 486DX2
Reply 80 of 96, by SScorpio
ElectroSoldier wrote on 2025-06-23, 02:05:
I want to buy it.
I obtained it in the manner everybody else did, but I want to have a genuine copy of it this time round 😀
In fact I wouldnt mind finding it on a 5.25" floppy.
And you're free to do that. But you already have all of the necessary files since you have a newer version of the ctmouse driver. You just need to setup proper startup config files which does not require a fresh installation. You can wait and do a clean installation if you really want, but you could always work on fixing the problem now so that when you do a clean install you know how to setup things correctly from the get go.
Reply 81 of 96, by ElectroSoldier
SScorpio wrote on 2025-06-23, 12:01:
I want to buy it.
Sounds like a plan.
I need to start by moving ctmouse.exe into its own folder. I only have the ctmouse.exe file, no other "supporting" files. Is that all I need?
Then I can add it to the autoexec.bat so it starts on boot.
I "need" other sound drivers? I am using the ones from retroweb. I believe they are the Creative drivers.
nb I do like the sound they are producing now.
Reply 82 of 96, by SScorpio
ElectroSoldier wrote on 2025-06-23, 18:10:
I need to start by moving ctmouse.exe into its own folder. I only have the ctmouse.exe file, no other "supporting" files. Is tha […]
The config files use himem.sys and emm386.exe which are included with DOS. The only other file referenced is a different CD-ROM driver.
You probably don't need a sound driver at all, just Unisound is enough. UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
Reply 83 of 96, by Grzyb
You can replace the Creative drivers with UNISOUND.
But it's not really necessary.
I like to use UNISOUND instead of the original drivers because:
1. UNISOUND is easier to install - but you already have the drivers installed...
2. UNISOUND isn't memory-resident, while many other drivers are.
You can list memory-resident stuff with the following command:
mem /c /p
...and then get rid of whatever you find unnecessary.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 84 of 96, by theelf
Creative drivers are not residentm exept aweutil if want emulation, not case here, but yes, unisound work much better with creative pnp cards
Reply 85 of 96, by Shponglefan
ElectroSoldier wrote on 2025-06-23, 01:23:
Yes I did read you can elevate drivers into the upper memory space but I didnt know how. From where do I get EMM386? […]
I will have to get it and have a look at it.
Would that work with the Microsoft mouse driver and Creative drivers I have or do they need to stay in the first 640k?
EMM386 comes with DOS. If you have a look at the link SScorpio posted (Phil's Computer Lab), it lists out some configurations for CONFIG.SYS and AUTOEXEC.BAT.
The easiest is to start by loading EMM386 with "DEVICE=C:\DOS\EMM386.EXE NOEMS" in the CONFIG.SYS, and then using DEVICEHIGH and LH to load other device drivers / programs into upper memory.
Typically you would use it for things like mouse and CD-ROM drivers. Sound card programs during startup are usually used to initialize the card, but don't necessarily remain in memory. The exception might be if there is some sort of emulation program or mixer that stays resident in memory, but I don't think that's the case with SB16 drivers. DOS games typically include and load their own sound card drivers.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 86 of 96, by ElectroSoldier
I tried to play Sega Outrun on it and it has the same problem as HeroQuest had, it only plays through the onboard speaker.
Is this normal for games that use the Sound Blaster for sound or is there a config file in every game you have to edit?
Reply 87 of 96, by Shponglefan
ElectroSoldier wrote on 2025-07-01, 15:28:
IIRC, Outrun for DOS only supports PC Speaker and Tandy sound. No Sound Blaster support.
For games that do support Sound Blaster, usually it will either be a config file, setup program, or command line switches. And some games just autodetect sound options.
Reply 88 of 96, by theelf
For outrun the easy way to have better music is to build a cheap parallel dac, aka covox, and use temu and a tandy patched outrun
Heroquest have sb and even mt32 support, not only speaker
Reply 89 of 96, by ElectroSoldier
So it is working normally then?
Is there a way to use a game pad with this sound card? It has the game port on it.
Reply 90 of 96, by ElectroSoldier
Can somebody help me remove the driver vibra16 I got from retroweb?
I would like to try a smaller driver.
Reply 91 of 96, by fosterwj03
ElectroSoldier wrote on 2025-07-03, 14:57:
Yes, you can use the game port on the sound card with pretty much any joystick or game pad. I think the joystick port defaults to address 201. Most games look to that address by default.
Just plug in your joystick / game pad, and setup the game to look for a joystick. That's it.
Reply 92 of 96, by fosterwj03
I don't know if you have your heart set on a particular optical drive solution, but I would recommend a PicoGUS (version 2.0) here again.
The PicoGUS is a software defined sound card with an ISA interface. The current firmware allows it to behave like multiple sound devices. In fact, the latest firmware just added optical drive emulation via a thumb drive plugged into the card's USB port. It's literally a game changer! Period drivers can't tell the difference.
Sure, it's not period correct by age of the component, but the PicoGUS behaves like a vast amount of period hardware. Absolutely great project. I have one in my 486-class computer.
Reply 93 of 96, by Shponglefan
ElectroSoldier wrote on 2025-07-05, 08:01:
Easiest way to remove a DOS driver is to simply REM out the lines it added to your AUTOEXEC.BAT and CONFIG.SYS files.
Basically you just add "REM " (excluding quotes) in front of any of those lines and they'll be ignored during start up.
Reply 94 of 96, by ElectroSoldier
Shponglefan wrote on 2025-07-07, 18:02:
Will that stop it from running so I can install a smaller driver?
I an trying to play Cannon fodder but it seems that it wont run as the lower memory usage is to high.
Reply 95 of 96, by matze79
Can you show your config.sys / autoexec.bat ? maybe we can help you optimize that.
Reply 96 of 96, by Shponglefan
ElectroSoldier wrote on 2025-07-09, 18:23:
Yes, anything with REM in front of it in your CONFIG.SYS and AUTOEXEC.BAT won't run.
The reason it's often preferred to REM lines rather than delete them, is that way you can always remove the REM should you want to reinstate the previous driver.
