Sound Blaster X-FI Fatal1ty - Sounds craks and pops
First post, by Mondodimotori
Hello there,
Just got myself a decently cheap Sound Blaster X-FI Fatal1ty PCI with the 64mb of dedicated memory and even the front control panel, just 30€. (SB0460)
I installed it in my XP Retrobox, got some trouble understanding why I wasn't getting sound out of it (first i put the connector in the wrong jack, then I discovered that the left speaker in my 2.1 system is very low volume compared to the right one, but I digress) and, didn't wanting to loose time troubleshooting my speaker system, I just plugged in my headphones in the audio mixer I have hoocked up to all my retro PCs and played some music and games.
And here I noticed something: The sounde pops and cracks when there's a high dinamic range playing (like gunshots and explosions), even the "chopper" 3D audio test in the creative labs software does appear to crack sometimes.
I thought it was the mixer, so I popped my headphones directly into the jack at the back of the sound card.
No change. Playing GTA Vice City I can see the game recognizing the sound card (it detects creative labs EAX 3 as audio device), and it appears to be working. Only... The cracking and popping is quite distracting. Also sometimes I swear I could hear some sound effects cutting earlier, but that may just be GTA Vice CIty being a Rockstar PC port.
Currently I'm running Daniel_K latest driver pack, I still have to test it with official drivers, but I wanted to know: Is it a known issue with these aging sound cards? Can it be solved somehow?
Or should I just see if I can return it to the ebay seller, since it came with buyer protection? I have yet to install the front panel, so I don't know how's the sound If I were to connect the headphones to it.
The headphones work flawlessly in any other computer I plug them, if you were to ask.
EDIT: The cracking and popping is not ever present. I can listen to music and play random games like most wanted and carbon no issue.
Except when I play games that support EAX acceleration like vice city and San Andreas. The popping and cracking sound appears every time a new audio effect starts playing. And only at the beginning.
The in game radio works perfectly. But a car passes by my side, or I shot a gun, the instant that sound starts to play, it cracks a little.
Reply 1 of 75, by PD2JK
Try another PCI slot, preferably the one above or below.
You could try and remove or disable any other PCI devices.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 75, by Mondodimotori
PD2JK wrote on 2025-07-01, 21:06:
I have two PCI slot, both of them were free. Tomorrow I'll try the most bottom one. The airflow there isn't great, that's why I went for the first one available after the PCIe ones... I didn't know the PCI slot could cause these kind of audio issues.
Reply 3 of 75, by luckybob
the X-FI has a bug where the sound card isnt setup correctly with windows.
Go into windows sound settings, you are looking for the bitrate/khz settings and you need to change it to the maximum. Once that gets set, windows and the sound card "get on the same page" in terms of timings and that has always solved the crackling issue for me.
example:
The attachment settings.png is no longer available
Reply 4 of 75, by shevalier
X-Fi can have 2 problems that lead to such a result
- drying of the biggest capacitor near the DSP chip (replacement)
- damage to the switching MOSFETs near the connectors. (replacement with 0 Ohm jumpers, on some cards they are initially soldered)
Better to return.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 5 of 75, by Mondodimotori
luckybob wrote on 2025-07-01, 23:12:
the X-FI has a bug where the sound card isnt setup correctly with windows. […]
example:
Ok, I'll try and check these settings under Windows XP.
shevalier wrote on 2025-07-02, 04:21:
X-Fi can have 2 problems that lead to such a result - drying of the biggest capacitor near the DSP chip (replacement) - damage t […]
Better to return.
If the settings suggested before won't fix the issue, I'll think about returning it. It did came with the front panel that, on ebay, also goes for around 30€.
Reply 6 of 75, by ott
Mondodimotori wrote on 2025-07-01, 20:51:
Be sure to check the front panel - turning headphones/line-in knob may reveal a rustling sound. This may be another possible reason for return. Repair will require replacing potentiometers - they are cheap, but require soldering skills.
Also, the X-Fi I/O Drive panel uses its own DAC for headphones (Audigy 2ZS front panel is same), perhaps there will be no crackling sound through it.
Reply 7 of 75, by Mondodimotori
ott wrote on 2025-07-02, 10:05:
Yeah, I have a similar issue on the Logitech 2.1 system: Turning the volume knob causes rustling sound, so I should be able to spot it immediately if the front panel does the same. This afternoon I'll install it and connect the headphones through it.
Reply 8 of 75, by Sombrero
Do you have more information about this? Has this happened with every driver version, including the latest ones and with what has this crackling shown up?
It's just I've never had any crackling issues with the two PCI and one PCIe X-Fi card I've had.
Reply 9 of 75, by Boohyaka
Mondodimotori wrote on 2025-07-02, 10:44:
On Logitech speakers this rustling when turning the volume knob is due to the lubricant used that dries up. Turn the speakers off, then quickly turn the volume knob from 0 to max volume several times, which will spread the lubricant and (at least temporarily) diminish or even completely fix the problem. Just do it again when it comes back. I've been doing that for years with my own Logitech 2.1 set and it still completely cancels the issue when I do it....only for it to come back if I don't use it for some time.
Reply 10 of 75, by Mondodimotori
Boohyaka wrote on 2025-07-02, 12:02:
Good to know. Shame that yesterday I discovered that the left speaker is barely audible... I though the sound card was completely broken, instead it was the speakers that were acting wonky.
Reply 11 of 75, by shevalier
Sombrero wrote on 2025-07-02, 11:16:
I doubt that such a problem exists at all with Creative cards.
They have always been positioned as cards with hardware (not software) DSP, which itself performs signal resampling.
And this is how the advertising of X-Fi and its Crystalizer was built - "even the most vile samples with a frequency of 11 kHz we convert to the best quality. And now you are a super gamer - bang-bang"
Reply 12 of 75, by luckybob
No - I never looked into it once I found a solution.
I only ever had to do it whenever I re-installed windows or the card into an existing setup. It didn't happen EVERY time, but it happened often enough that I have the solution memoried. However it was always something I needed to do to get the full 192k/24-bit out of the card. And to be honest, I had to do with with ALL of my Creative cards since the Audigy 1.
Reply 13 of 75, by shevalier
luckybob wrote on 2025-07-02, 14:28:
I'm terribly sorry, but this is an attempt to put the dog back together. From the hot dog.
Once a recording is digitized at a certain sampling rate, information above the sampling rate is simply lost.
Completely.
Increasing the sampling rate is a "fantasy" of a digital filter, when (at best) - not much nastiness is introduced.
It's like trying to stretch DVD to FullHD.
Reply 14 of 75, by shevalier
Mondodimotori wrote on 2025-07-02, 12:05:
If the main board and the line-out on it are fully functional, then I recommend just throwing away this 5.25 I/O bay.
Completely useless thing, needed only for a collection.
X-Fi is a very special card for the heyday of EAX games, exclusively for playing with headphones.
Everything else in it is very mediocre.
Reply 15 of 75, by Mondodimotori
shevalier wrote on 2025-07-02, 15:00:
If the main board and the line-out on it are fully functional, then I recommend just throwing away this 5.25 I/O bay. Completely […]
Problem is... The crackling sound comes directly from the 3.5 card output. So if it cannot be a software issue, it must be hardware.
But, even then... This setup is gonna be used with speakers mostly so... Is it pointless to try and get true EAX from a sound card? Should I just use the realtek on board audio?
Reply 16 of 75, by Mondodimotori
example:
I may be dumb but... Where do I find these settings on windows XP?
Reply 17 of 75, by luckybob
I dont have it memorized - I'd start in the settings and check under "sound" and go from there.
Reply 18 of 75, by Mondodimotori
luckybob wrote on 2025-07-02, 16:43:
Erh... I can't seem to find it. Is it even present on Windows XP?
Reply 19 of 75, by shevalier
Mondodimotori wrote on 2025-07-02, 16:57:
NOPE. Nowhere.
In XP just slider "hardware acceleration"
Which is responsible for everything at once and for nothing (in fact, for the level of compatibility with DirectX)
