SBVGM (DOS) VGM Player
Reply 560 of 563, by OPLx
BlackVega wrote on 2025-07-04, 17:31:
Please see Cosmo Police Galivan: https://vgmrips.net/packs/pack/cosmo-police-g … -police-galivan […]
OPLx wrote on 2025-07-04, 14:34:
Could you point me to the VGM data does it not work correctly on? That way I'll have something to validate against when I have a large block of time to look into the issue. Thank you.
All tracks sound a little off at times. I suspect other tracks from games from the same developer will do the same. Also some tracks from Duke Nukem 2 hang the system completely
I can use the Cosmo Police to figure improve things. Since there are twenty of them, do you mind telling me which Duke Nukem 2 tracks cause your system to hang? I'll try to look at these as soon as I can. Thank you.
Reply 561 of 563, by SuperDeadite
OPLx wrote on 2025-07-04, 22:16:
Some OPL2 rips, including Duke II and Alone in the Dark are known to hang on certain VGM players as the rips use the "opl2 wait" command. I don't know technical details, but this was fixed in MAmidiMEmo by simply adding a function to ignore it.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 562 of 563, by OPLx
SuperDeadite wrote on 2025-07-04, 23:00:
I played through all the VGMs in Duke Nukem II and there was no crash. Sadly, I won't be able to analyze what the source of the problem is.
Reply 563 of 563, by BlackVega
OPLx wrote on 2025-07-05, 13:42:
Oh darn it does in fact work but I need to bypass DOS=HIGH,UMB and after that track 05 from DN2 plays fine! 😮 But once I enter a filer (FILMTN) and play it from there then it plays a single note and crashes with EMM386 saying "EMM386 has detected error #12 in an application at memory address 7DE9:EB43.". Darn how I hate using MS-DOS sometimes...
