SBVGM (DOS) VGM Player
Reply 560 of 580, by OPLx
BlackVega wrote on 2025-07-04, 17:31:
Please see Cosmo Police Galivan: https://vgmrips.net/packs/pack/cosmo-police-g … -police-galivan […]
OPLx wrote on 2025-07-04, 14:34:
Could you point me to the VGM data does it not work correctly on? That way I'll have something to validate against when I have a large block of time to look into the issue. Thank you.
All tracks sound a little off at times. I suspect other tracks from games from the same developer will do the same. Also some tracks from Duke Nukem 2 hang the system completely
I can use the Cosmo Police to figure improve things. Since there are twenty of them, do you mind telling me which Duke Nukem 2 tracks cause your system to hang? I'll try to look at these as soon as I can. Thank you.
Reply 561 of 580, by SuperDeadite
OPLx wrote on 2025-07-04, 22:16:
Some OPL2 rips, including Duke II and Alone in the Dark are known to hang on certain VGM players as the rips use the "opl2 wait" command. I don't know technical details, but this was fixed in MAmidiMEmo by simply adding a function to ignore it.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 562 of 580, by OPLx
SuperDeadite wrote on 2025-07-04, 23:00:
I played through all the VGMs in Duke Nukem II and there was no crash. Sadly, I won't be able to analyze what the source of the problem is.
Reply 563 of 580, by BlackVega
OPLx wrote on 2025-07-05, 13:42:
Oh darn it does in fact work but I need to bypass DOS=HIGH,UMB and after that track 05 from DN2 plays fine! 😮 But once I enter a filer (FILMTN) and play it from there then it plays a single note and crashes with EMM386 saying "EMM386 has detected error #12 in an application at memory address 7DE9:EB43.". Darn how I hate using MS-DOS sometimes...
Reply 564 of 580, by ElBrunzy
I was doing some computer maintenance when I noticed that SBVGM would say that the YM2151 of the Golden Axe VGM dump was at 4mhz. Then I checked on the SAAYM and the jumper was to 3.58mhz so I set it to 4mhz. Now I'm not sure if it's the placebo effect but the sound seem less muddy. I then wanted to make sure the SAA1099 CLK where correct too and noticed SBVGM reported something about 3.79540 which is more in par with the 7.16 settings on the card. I set it to 8mhz setting out of curiosity and was in the impression that some instruments in the music where maybe out of pitch, but again, is it just an impression ?
It is not very convenient for me to record and compare now so if someone could please advise on correct settings, this wold be much appreciated. Thank
Reply 565 of 580, by OPLx
ElBrunzy wrote on 2026-03-16, 21:31:
While it is possible to detect the clock that the SAAYM is using, SBVGM just assumes that it's set to 3.579545 MHz and handles the internal frequency conversions. Unlike the other OPLx chips, the way to set the frequency on YM2151 is an indexed value that corresponds to the desired note to play (not the actual frequency value) so there is a change that things won't sound as correct. While it's not official, generally for "PC" settings 3.579545 MHz for the YM2151 and 7.15909 MHz for the SAA1099 are the correct defaults. Especially in the case of the SAA1099 since the GameBlaster uses a 7.15909 MHz clock.
I believe the SAAYM was a result of the early work TexElec did while designing what would end up becoming the Commander X16's sound system. Initial designs were going to use the SAA1099 chips, but that was superseded by VERA's PSG core which has features the SAA1099 lacks.
I should probably find some time to support the SAAYM at different clock settings and use an environment variable to determine what they are.
Reply 566 of 580, by ElBrunzy
Thank you OPLx for your quick and precise answer ! There goes my career as a piano tuner with that post 😅 So now I blame placebo effect and those cheap small monitors I use to test if audio work. I'm not sure I understand correctly the implication of changing the frequency of the YM2151 and SAA1099, I assumed it would change the speed at which they operate hence change their pitch. But apparently it is not the case, maybe it change the speed at which they pickup and treat data, a bit like a bus speed thing. Oh well, dont feel the obligation to explain anything, I would not want to be of any burden. Maybe when it will be more convenient I could do comparison recording and hopefully understand it better. In the meantime I appreciate you told me about the correct setting to use.
Honestly, I think your time could be more well spent than adding support for different speed of the YM2151. I'm not aware of any other PC implementation of the YM2151 and I'm not even sure why there is a jumper to change speed of those chip on the SAAYM now. It just puzzled my mind to see that 4mhz tag info in SBVGM for those VGM files and that the SAAYM was set at 3.579545mhz. Maybe supporting 4mhz would mean less timing conversion handling for SBVGM and maybe a more precise playback for 4mhz .VGM ?
Reply 567 of 580, by bakemono
The FM chip clock effects basically everything, including pitches. You can transpose the pitches in software to correct for a different clock. There are 12 note numbers and a 6-bit key fraction, which means 768 steps per octave (better than OPL's 512 steps, but worse than OPN's 1024 steps). You can't fine tune the envelope timing though, because one step is a factor of 2 or square-root-of-2.
X68000 has a YM2151 at 4MHz, but eg. CPS1 games use 3.58MHz. So both are common.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 568 of 580, by SuperDeadite
ElBrunzy wrote on 2026-03-18, 03:22:
Typically arcade games (Capcom, Irem, Konami) used 3.57mhz for YM2151, while computers (X68000, X1, X1 Turbo) used 4mhz. If you are ever confused, the vgm2txt tool lets you see exactly whats happening.
Personally, I like to use vgm-conv so all my vgm files match the clock of my hardware.
https://github.com/digital-sound-antiques/vgm-conv
AY-3-8910 (YM2149) is another chip that was commonly run at either 1.79mhz or 2.0mhz, and using the correct speed makes a big difference in how it sounds.
Reply 569 of 580, by OPLx
It can be hard to tell sometimes since some may not be able to immediately pick up on the pitch difference between 4 MHz and 3.579545 MHz. As bakemono said, the clock frequency that drives the YM2151 is the heart of everything. I left off supporting the other SAAYM clock speeds mainly because I wasn't sure how many people would actually change them as that would (at least) cause the Gameblaster pitch to not be correct. I found it extremely handy since that allows me to test out different things 😄
By the way, you might find these VGMs interesting:
I won't go into the details of the game itself, but the pitch of the music sounds different on the Sharp X68000 than the original arcade. I'm not sure if Capcom just took the arcade music data and used it as-is on the X68000 port, but it's interesting. I wonder if the X680000 music would sound be the same pitch if the YM2151 was clocked at 3.579545 MHz (it's clocked at 4MHz on the X68000).
Reply 570 of 580, by SuperDeadite
OPLx wrote on 2026-03-22, 12:43:
It can be hard to tell sometimes since some may not be able to immediately pick up on the pitch difference between 4 MHz and 3.5 […]
You are correct. Capcom ported the music the lazy way. This was common though. Irem did the same thing with the X68K port of R-Type. At least Final Fight does have a banging MT32 option as well.
Reply 571 of 580, by ElBrunzy
I was having some though about the Sonic 1 soundtrack on the Genesis/MegaDrive. I know that Green Zone use the YM2612 as well as the SN76489. It seem the rhythmic "chords" and the ride hihat during the music as well as the arpeggio and bass line in the intro segment are provided by the SN76489. Using VGM Input plugin for winamp is an easy way to appreciate that (muting channel and using the immediate mode help do it).
I'm glad to that the SAAYM can provide both chips to SBVGM and allow me to enjoy the excellent Sonic 1 soundtrack on a single soundcard. But I was wondering if there is another way to listen to SN76489 + YM2162 music. I know that many time you can force OPL3 to play on OPL2 so maybe an SB1.5+C/MS could play Genesis/Megadrive music, but I think SBVGM might just refuse to do it. So I dont think there would be a way to force SBVGM to play the YM2612 on the SB1.5's OPL2. Could a second soundcard with an OPL3 could be used ? AFAIK SBVGM only support one soundcard as an input. But maybe in auto mode it can detect more ? Then again, how to know which OPL it will use as they all are on 388...
I'm not asking for any modification to the software, I can listen to the music on the SAAYM already and I also have an genesis/megadrive with ideal sound chip (with an everdrive x7 filled with rom soundtrack). So I just though it would be a nice topic of discussion if anyone feel like sharing his input about it.
Reply 572 of 580, by SuperDeadite
ElBrunzy wrote on 2026-09-03, 07:06:
You should probably take a look at the various conversion tools out there. Korean youtube user "ToughKidCST" has released some fun tools. Among others, I believe his 2612+SN7 to 2608 convertor is just about finished. VGM-CONV can also do some cool stuff.
Reply 573 of 580, by OPLx
As SuperDeadite pointed out, there are conversion tools out there that could do what you are thinking about. The fundamental difference between the OPM and OPL family is the algorithms. There is some overlap though. So if one wanted to play YM2612 VGMs approximately on the YMF262 (OPL3), then the approach I would take is:
  1. Put the OPL3 channels 4 operator mode (there are 6 4-operator channels for this).
  2. Use from the remaining channels to emulate the SN76489 square wave channels.
With the above configuration the challenge would then be figuring out which OPL3 algorithms closely approximate the YM2612's. One caveat with the above set up is that it won't be possible to emulate the SN76489's noise channel. At least from my experiments, 4 operators are needed. Though there might be a way to achieve this with 2 operators.
Another configuration could be:
  1. Layer two 2-operator channels to emulate a 4 operator channel
  2. Set up 1 channel to be 4 operator and use this for the SN76489's noise.
  3. Use from the remaining channels to emulate the SN76489 square wave channels.
This configuration would also require figuring out which layering and 2-operator algorithms to use to approximate the YM2612's.
Reply 574 of 580, by ElBrunzy
oh I think I did an unfortunate oversight and I am sorry for wasting your time. I though SBVGM could play YM2612 music on the OPL3 and that you would need to pair it with an SAA1099 or other SN76489 to be able to listen to Genesis/Megadrive music. The YM2612 would be dispatched on an OPL3 and the SN76489 could be dispatched on another SN76489 or an SAA1099 chip. I didn't want to steer us toward the complex layering estimation route, even though I appreciate you sketching out how it could work. I assumed SBVGM could play YM2612 on OPL3, but I now think it simply can't.
While I agree the SBVGM should keep conversion minimal and focus on seeking compatibility between recorded and playback chip, I think it make sense to offload that job to an external converter. But I was able to find that vgmtoolbox on github, the tools on the website vgmrips and other on sms power but nothing comes close to chip-to-chip conversion, aside from that new OPL2/OPL3 converter. There is that git page https://github.com/ToughkidDev but I cant seem to find any conversion utility. Could you please help me find those conversion tools ?
Reply 575 of 580, by OPLx
ElBrunzy wrote on 2026-09-11, 02:47:
You didn't waste my time at all; it was a great question and something nice to think through. I didn't see any tools on that link specifically for OPL3; the closest to the OPL3 the MSX had (to my knowledge) was the OPL4-based sound cartridges. Maybe SuperDeadite knows where to find the tools.
Reply 576 of 580, by theelf
Hi if you want i did a ym2612>OPL3 converter for my vgm dos player, psg is in software or hardware if you have
sound very good in most tunes
Reply 577 of 580, by ElBrunzy
Thanks for the headsup theelf ! I'm interested in everything FM so I was happy to try out your program. I will go fill your thread with my many feature request and give OPLx a break 🤣
Reply 578 of 580, by dr.zeissler
Sorry for bothering you. I tested sbvgm today on my EuroPC with PicoVoxin Tandymode.
The chip is found, music is loaded but the speakers stay silent. I have my Picovox on a secondary LPT (378H). (LPT2 @278! LPT is set to 3$BC)
I am not sure what went wrong. Music is played in patched AGI games though.
Reply 579 of 580, by OPLx
dr.zeissler wrote on 2026-10-25, 22:02:
No worries at all. I've been a bit busy lately and have been slow in keeping up. How are you running the program? You should be able to do: sbvgm -tndlpt filename.vgm
If the picovox is on a different LPT port, you could just do: sbvgm -tndlpt278 filename.vgm
If you still have trouble, please do let me know.
