First post, by flux1270
I've been looking for a CPU upgrade for my Dell XPS T500, which currently has a PIII 500/512Kb. I've read varying reports that it will or won't take anything faster than a P3 600E.
It's a 100MhZ FSB board so that does limit my options pretty heavily. I would love to track down a 1Ghz 100MhZ Slot 1 P3 for it, but they seem nearly impossible to find online.
Does anyone have experience/suggestions for a CPU upgrade on Dell's SE440BX-2? Even a P3 700 would be a huge upgrade, as I'm running Bryce 3D and it's struggling hard with just the 500.
Thanks!
Toshiba Tecra 510CDT (P133MhZ, 48MB RAM, W98SE)
Compaq Armada E700 (P3 500MhZ, ~512MB RAM, W2K)
Dell XPS T500 (P3 500MhZ, ~512MB RAM, FX 5200, Audigy 2ZS, W2K)
Macintosh Classic II (68030 16MhZ, 4MB RAM, System 7.something)
Reply 1 of 21, by keenmaster486
I've put an 800 MHz Coppermine in my R500 for whatever that's worth.
World's foremost 486 enjoyer.
Reply 2 of 21, by flux1270
Hmmm alright. I guess I'll start watching eBay for either an 800 or 1.0 that isn't $250.
Reply 3 of 21, by Grem Five
I have a T600r Dell board and it took a 1.0 Ghz processor on a slotket. Is it a BX-2 board (2 ISA slots) or a BX-3 board (1 ISA slot)... Mine is a BX-3 and it works.
Reply 4 of 21, by flux1270
Grem Five wrote on 2025-07-26, 22:49:
It must be a BX-3, there's only one ISA slot.
Reply 6 of 21, by Errius
These things were super common circa Y2K and several came to me for upgrade early 2000s. They all got bigger hard disks, Windows 2000/XP, 768 MB RAM, GeForce 4 MX, and 1.2-1.4 GHz Tualatin Celerons on PowerLeap PL-iP3/T adaptors.
Unfortunately the PowerLeaps are stupid expensive now. Plus they need recapping.
Is this too much voodoo?
Reply 7 of 21, by chinny22
It'll work fine, I've got a 1Ghz in my T500 for good few years now.
Dell makes surprisingly good retro PC's
Only "issue" you get is cosmetic where post screen will display the model as @00
As you've noticed Slot 1 prices increase dramatically once you reach 600Mhz, S370 CPU's are a bit cheaper and an option if you can find a good price on a slocket adapter.
Reply 8 of 21, by Jasin Natael
Yes it should.
I had one in mine. It's currently running a Nehemiah.
Reply 9 of 21, by H3nrik V!
IIRC, my Intel SE440BX-2 is too old to run Coppermines - the VRM doesn't have the right voltages for it. Might be an issue on the Dell board too ..?
Reply 10 of 21, by flux1270
H3nrik V! wrote on 2025-07-30, 04:10:
Yeah that's what I had been seeing too. I need to get the case lid off and see if it's 100% a BX-2 or not. Everything I had read up until I made this post suggested it was only compatible with up to the Katmai 600 chips.
Reply 11 of 21, by shevalier
Usually, Intel's motherboards (oem for intel/ by intel) can't work with nothing, which no in CPU support list
It's only bios protection feature ( or issue)
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 12 of 21, by H3nrik V!
flux1270 wrote on 2025-07-30, 04:20:
Yeah, and maybe get a look on the VRM chip to see if it's even <2.0 Volt capable
Reply 13 of 21, by shevalier
Coppermines voltage incompatibility can be solved either by moving the jumper on the adapter (if there is one), or by one wire wound around the two processor pins.
Yes, 1.8 V differs from 1.7 V by the VID1 signal, which needs to be grounded.
Wow, 6% overvoltage...
Most likely, in AMI (which no one has really learned how to modify) in the BIOS from Intel there is a frequency/family ID detection by the processor and a forced halt of system.
Even if this is not the case, the lack of microcodes and the initialization cache errors for unknown processor have also not been fixed by anyone for AMI.
There are no public automatic BIOS modding tools for Pentium 2/3 motherboards with AMI BIOS.
Only if someone disassembled and made changes, which is extremely unlikely.
Reply 14 of 21, by Jasin Natael
I have a SE440BX-2 and mine works with Coppermines just fine. I did have to upgrade the BIOS though and the post screen doesn't always pick up the correct clock speed.
Also works with Tualatin and Nehemiah chips with the appropriate slocket/modded pins.
Reply 15 of 21, by flux1270
Ironically this thread pretty much sums up what I had seen online about the SE440BX CPU compatibility beforehand - a mix of yes and nos.
Reply 16 of 21, by old school gamer man
Errius wrote on 2025-07-28, 11:21:
the solder on ones are supper cheap and still for sale.
Reason: derailing
Reply 17 of 21, by shevalier
flux1270 wrote on 2025-07-30, 18:02:
Intel and Siemens-futjitsu made great boards - simple and stable.
But you couldn't get anything out of them that wasn't in the specification.
But the boards are just magical.
Reply 18 of 21, by Cbb
The issue with non-working CPUs higher 600MHz may be related to BIOS version. On my DELL GX1 I was forced to flash A07 (not latest) BIOS in order to run 800+ MHz CPU.
I think that it is connected with TDP rising along the frequency and the platform was not able to run VRM at that power or heatsink/airflow was not enough to manage that increased heat amount. So producer decided not to get compains from the end-users about instability issues adn in new BIOS versions there's a check if CPU installed is certified for the system.
Also on GX1 I was not able to downclock any P-III to run at 66MHz FSB. System just doesn't POST. P-IIs do downclock no problem.
Reply 19 of 21, by shevalier
This is Intel as it was.
But the motherboards themselves are is a standard.
