Reply 20 of 33, by tehsiggi
- Oldbie
Archer57 wrote on 2025-09-01, 12:42:gmaverick2k wrote on 2025-09-01, 12:35:doesn't do harm as all you're doing is increasing the surface area for heat transfer
The harm is in messing with the PCB and all the tiny SMD stuff on it. I've seen way, way too many results of doing such things.
As for heat transfer - it will be negligible through that 2mm thermal pad and all the components on the back. There is no proper contact between this heatsink and the chip. Trying to cool the chip through all that stuff instead of doing it directly from the other side just does not make sense.
I'd like to second this, you'll gain much more from having a good cooler on the front of the card. Cooling the GPU mainly and, if the cooler style permits, the surrounding area with some airflow as well. We're talking about 38W tops for the whole card. The GPU being a part of it, but not all of it. The VRMs as well as the memory produce a fair amount of heat as well, all of them profit from airflow and better cooling. Give those BGAs some passive heatsinks. Get a nice big cooler for the front of the card, like a Zalman VF700, if you really want to get the card cooled properly.
If you want to stick with the stock fan: Give the card some good surrounding airflow.
I'd always advise against frankenstein solutions to cool a card. Putting the cooler on the back applies pressure to the PCB from the opposite direction as the usual fan mounts. This is not accounted for by the designers.
