Dothan Burger wrote on 2025-09-04, 10:21:
WangYouGX wrote on 2025-09-04, 04:22:
Dothan Burger wrote on 2025-09-04, 01:01:
So it's not a physical modification? I was picturing a stick off DDR3 with most of the modules de-soldered. Hats off to you for taking it to the next level.
They are accessed in parallel, and removing some particles will affect performance, and the particles may not meet the number of channels. At this time, modifying SPD is useless. I always stick to the physical memory control within 1Gb to run win98, and do not rely too much on large memory patches.
Is it like reprogramming the module to only think it's a 512mb stick?
Modded 512MB DDR3 memory module?
PS
Typhoon Burner is a very useful, but at the same time very "muddy" utility.
I recommend running it in a virtual machine.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
