adding free space to z:
First post, by jamos
Is there anyway how? I am trying to install a game that doesnt like z: having no space available (it scans all harddrives).
Thanks..
Reply 1 of 14, by lightmaster
more space can be added in configfile me guess..
Reply 2 of 14, by jamos
The Z: drive is automatically added by dosbox for its files. There is no entry in the config file.
Reply 3 of 14, by lightmaster
if you mount another drive dosbox will not explode 😀
Reply 4 of 14, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, and how you did the install.
_________________
Reply 5 of 14, by jamos
I am sorry but I know how to run dosbox. I know how to mount drives etc.
My problem is the game installation sees the Z: drive as well as my mounted c: and d: drive and the Z: drive has 0 freespace. I was hoping there was a way to set z to more freespace just so the game would install.
Reply 6 of 14, by Miki Maus
The name of the game?
Reply 7 of 14, by MiniMax
Rank Moderator
Moderator
Maybe try setting LASTDRIVE before running the game?
C:> set LASTDRIVE=D
_________________
Reply 8 of 14, by MiniMax
Rank Moderator
Moderator
Crazy thought.... Could this kind of detection problem be avoided if the Z-drive was somehw "marked" as a diskette drive, or a CD-ROM?
_________________
Reply 9 of 14, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I don't think adding space to Z: would help even if you could, because then it might think it could actually write to it. Why it wants Z: to have free space when C: is available is the clue I would start with. Perhaps it doesn't think C: has adequate space, so using the -freesize mount option to make it larger might help. Also, it's possible that because it can see another HD, it wants to use it as a swap location or something; so assuming the D: drive is a CD, mounting an E: drive as another HD might satisfy it... not likely, but maybe.
BTW, I believe LASTDRIVE= is set in CONFIG.SYS, and is not an environment variable.
Reply 10 of 14, by Freddo
I bet it's the cracked version of Z he's having problem with. Others had a similiar problem with it in DOSBox in the past here.
Possibly I'm wrong, though 😜
Reply 11 of 14, by leileilol
Z does not ever seek Z: for any reason
Debian's fucked
Reply 12 of 14, by Freddo
Not the normal version, no. But there has been discussions about the cracked Z in the past. In more threads than that too, but it was the first I found.
Reply 13 of 14, by leileilol
Wow, that's retarded.
Buy the game btw! The game's main charm is in its humorous cutscenes.
Debian's fucked
Reply 14 of 14, by Enigmar
Ive had issues with Z on dosbox before (but using the actual Z disk) Z runs fine on my desktop, but on my laptop it thinks its a pirated copy, even though both are using the actual CD. Even when mounting the same network share for the C drive.
Must run dosbox on windows 3.1 within dosbox......
