First post, by jamos
Is there anyway how? I am trying to install a game that doesnt like z: having no space available (it scans all harddrives).
Thanks..
Thanks..
more space can be added in configfile me guess..
The Z: drive is automatically added by dosbox for its files. There is no entry in the config file.
if you mount another drive dosbox will not explode 😀
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, and how you did the install.
_________________
I am sorry but I know how to run dosbox. I know how to mount drives etc.
My problem is the game installation sees the Z: drive as well as my mounted c: and d: drive and the Z: drive has 0 freespace. I was hoping there was a way to set z to more freespace just so the game would install.
The name of the game?
Maybe try setting LASTDRIVE before running the game?
C:> set LASTDRIVE=D
_________________
Crazy thought.... Could this kind of detection problem be avoided if the Z-drive was somehw "marked" as a diskette drive, or a CD-ROM?
_________________
I don't think adding space to Z: would help even if you could, because then it might think it could actually write to it. Why it wants Z: to have free space when C: is available is the clue I would start with. Perhaps it doesn't think C: has adequate space, so using the -freesize mount option to make it larger might help. Also, it's possible that because it can see another HD, it wants to use it as a swap location or something; so assuming the D: drive is a CD, mounting an E: drive as another HD might satisfy it... not likely, but maybe.
BTW, I believe LASTDRIVE= is set in CONFIG.SYS, and is not an environment variable.
I bet it's the cracked version of Z he's having problem with. Others had a similiar problem with it in DOSBox in the past here.
Possibly I'm wrong, though 😜
Z does not ever seek Z: for any reason
wrote:Z does not ever seek Z: for any reason
Not the normal version, no. But there has been discussions about the cracked Z in the past. In more threads than that too, but it was the first I found.
Wow, that's retarded.
Buy the game btw! The game's main charm is in its humorous cutscenes.
Ive had issues with Z on dosbox before (but using the actual Z disk) Z runs fine on my desktop, but on my laptop it thinks its a pirated copy, even though both are using the actual CD. Even when mounting the same network share for the C drive.
Must run dosbox on windows 3.1 within dosbox......
