Reply 80 of 116, by BobocoCZ
- Newbie
bertrammatrix wrote on 2025-07-09, 15:45:I will have to check the bios revision to be certain, but, I never updated either of these boards so it should be whatever came […]
I will have to check the bios revision to be certain, but, I never updated either of these boards so it should be whatever came with them originally. I don't remember an issue with 3x/4x, however I mainly used the board with Cyrix so if it had an issue with AMD I may have not noticed it. Could it be a jumper configuration issue?
Yes, CPU-Z also displayed only half of the cache I had installed.
One more thing I remember- I think the jumper directly below the multiplier jumper did something strange with cyrix CPUs, like enable a fractional multiplier of 1.5 or something. It wasn't useful to me at the time, but definitely interesting.
Is that voltage regulator you used an adjustable DC-DC "buck converter"?
I have never been able to use the 4x multiplier on AMD with this board successfully. After activation, the L2 cache did not work at all or with a different BIOS version it was many times slower. Many users do not even notice it, because if there is EDO memory and the L2 is turned off, the speed is still very good. I have tried various combinations of jumpers and without success. But with the 3x multiplier everything always worked great.
I think there could have been more BIOSes, because some report cache even though there is none on the board (because some boards were manufactured with fake cache). Only benchmarks will reveal the truth.
I have now tried the jumper under the multiplier and unfortunately it does nothing for me. A 2.5x multiplier would be great for me, because I would try 2.5x60 or 2.5x66MHz 😜
and yes, it's a regular adjustable stepdown module with an attached LCD. The regulator on the board was not stable when overclocked to 150MHz. The voltage had big drops under load. I don't have an oscilloscope, but it was easy to see even with a multimeter.
