Reply 40 of 54, by myne
Do that after a wash.
It's pretty dirty.
I built:
Reply 41 of 54, by myne
Looked more closely at the pic.
You have tried both DVI ports, yes?
They appear to both be VGA converted by SI chips.
Wouldn't be the first time one was a dud and the other was fine.
I built:
Reply 42 of 54, by zuldan
myne wrote on 2025-06-01, 08:46:
Looked more closely at the pic. You have tried both DVI ports, yes? They appear to both be VGA converted by SI chips. Wouldn't b […]
Issue occurs on both DVI ports 🙁
Reply 43 of 54, by myne
ok.
C112 by the back of the connector doesn't look like other empty pads.
Factory or missing?
U819 top left looks odd. I get that its a factory option but it still looks hand soldered.
You did notice the test points... yes?
TP## mostly near the right.
Worth a multimeter on those one by one see if anything stands out.
flux on C1293. yours?
I built:
Reply 44 of 54, by zuldan
myne wrote on 2025-06-01, 08:58:
ok.
Factory or missing?
Sorry I'm not sure where this is located on the PCB. Can you give me more hints 😀
The attachment U819.JPG is no longer available
You did notice the test points... yes? TP## mostly near the right. Worth a multimeter on those one by one see if anything stands […]
Sorry, again I'm not sure where these locations are. I removed C1406, C1552 and C1550 to test caps.
Reply 45 of 54, by myne
Just above the back of the connector on the front.
They're labelled TP. There are heaps of them. But the ones on the right bear the main caps are the most likely to show voltage drops.
I built:
Reply 46 of 54, by zuldan
myne wrote on 2025-06-01, 09:42:
Ahh yes sorry I see them now. I was looking at the DVI connector section.
BUT....I think you're onto something. This card has been recapped previously, ARRRG. Well it's weird. The capacitors are still factory original, but they've been removed and installed back again by hand. I've marked them in green. Maybe someone else found the same issue and tested caps to see if they were bad.
The attachment Hmm.png is no longer available
The attachment Oh no.png is no longer available
Reply 48 of 54, by agent_x007
zuldan wrote on 2025-05-31, 23:11:
Do you tried VGA (on both ports) ? -> There are no VGA ports
There are, you simply need passive DVI-A to VGA adapter (since ALL ports on your card are DVI-I).
I don't like to use HDMI adapter on GF4, it may not work on boot (black screen/no signal), and/or only work after Nvidia driver kicks in at around Windows loading mark (depends on monitor/capture card).
They are also quite finicky on 1080p support (720p via HDMI works best).
In short : VGA is A LOT better option than HDMI on this old cards (assuming you have VGA capable monitor).
Reply 49 of 54, by zuldan
tehsiggi wrote on 2025-06-01, 10:18:
They look clearly hand soldered. When I saw those i thought it was you when testing ESR.
I tested different capacitors. My soldering is not that nasty 🤣
Reply 50 of 54, by zuldan
agent_x007 wrote on 2025-06-01, 10:30:
There are, you simply need passive DVI-A to VGA adapter (since ALL ports on your card are DVI-I). […]
I’m using a DVI cable to connect the card to the DVI port on the monitor. There is no HDMI in the connection.
Reply 51 of 54, by zuldan
Ok so next things to try…
1. Wash card
2. Heat card
3. Replace caps
Reply 52 of 54, by zuldan
tehsiggi wrote on 2025-06-01, 06:57:
Good. […]
zuldan wrote on 2025-06-01, 06:29:
Modifying the BIOS (and confirming with Z-GPU and Everest), I reverted the cards memory back to 650MHz (from 350MHz) and Windows XP booted up perfectly in 800x600. I then changed the GPU back to 300MHz (from 250MHz) and the video loss problem returned, I couldn't boot into Windows XP. I was able to go into VGA mode (640x480) and get to the desktop.
Now that I have the schematics, I'm going to order caps from Mouser closer to the actual specs. If the capacitors were causing the problem, which ones do you suggest I replace first?
Only just got my oscilloscope. It's a cheapo FNIRSI 1014D. I need to figure out if it has the capability to do what you're asking 😉
Good.
If you are considering changing caps, go with anything around NVVDD, as this is the GPU core voltage. Meaning C1302 and C1304 on the output side of things. Input would be C1264 and C1267.
C1302: 510µF - 4V - 14mOhms ESR - 4.08A Ripple current rating
C1304: 510µF - 4V - 14mOhms ESR - 4.08A Ripple current rating
C1264: 510µF - 4V - 14mOhms ESR - 4.08A Ripple current rating
C1267: 510µF - 4V - 14mOhms ESR - 4.08A Ripple current rating
There are alternate variants as well, which appear to be used on the input side of your card:
470µF - 6.3V - 25mOhms ESR - 2.09A Ripple current rating
On the input side there's also C1371, which is more of a general bulk capacitor and not as critical for the switcher as the other ones.
C1371: 1000µF - 6.3V - 170mOhm ESR - 0.45A Ripple current rating.
Just from a quick look your scope might actually be able to do some basic analysis. If you do so, don't do it "free hand", ideally solder some test point to the PCB that you can remove later, where you can attach the probe securely to. That prevents shorting something out by accident.
myne wrote on 2025-06-01, 06:32:
Again, it can just as easily be the mosfets or drivers.
In all seriousness, give it a wash.
Yes. Wash. In the sink.
I agree with the cleaning, that's always part one. However make sure to have it properly dried and any residue removed.
Flaky FETs or drivers haven't come around for me a lot the last years, so they wouldn't be my first concern.
Again, without tracing the GPU voltage in time of error, it's hard to say if it's even the issue, same for caps.
zuldan wrote on 2025-06-01, 06:43:
A small update....GPU at 250Mhz and memory at 650MHz works for a minute or so but then the no signal problem returns. So, it app […]
A small update....GPU at 250Mhz and memory at 650MHz works for a minute or so but then the no signal problem returns. So, it appears reducing the memory speed is also required to make it stable.
Just to recap...
- GPU 300, Memory 650 = Cannot boot into Windows XP at 800x600
- GPU 250, Memory 650 = Can boot into Windows XP at 800x600 but after a while video signal is lost
- GPU 250, Memory 350 = Can boot into Windows XP at 800x600
* In all situations, as soon as DirectX is initialized (EG 3dMark or Quake 3 is run), I get video signal loss.
Interesting. Especially that it is a "time related issue". Does the time vary between "runs" and "no signal" with memory at normal clock, if you perform many 2D draw actions? Like opening files, refreshing the desktop etc?
If the timing is fairly consistent and unrelated to that, it doesn't sound to me like it is "traffic" induced, but could be environmental.
Are you able to apply heat or cold (like serious heat ~100°C or -20°C cold) to certain components to see if it has an influence?
For starters going with the easiest: Extreme airflow on both sides of the card to see if that prolongs the "happy phase".
Cheers!
EDIT: In general, you scope should be good enough to have a simple look at ripple on NVVDD, that gives a good indication how "stable" everything is. You can find NVVDD at TP25 if you want to add a test-pin.
I decided to revisit this card again. I've had the new capacitors sitting in a draw for a while now. Was a bit hesitant changing the caps as they are part of what makes the card look so good, but I'd rather have a working card than a pretty dead card.
THE CARD IS WORKING 100% WOOHOO.
The attachment 3DMark.jpg is no longer available
The attachment Quake 3.jpg is no longer available
One of the three ELNA 470uf 10v caps were out of spec (low capacitance). I replaced the ELNA's with these Wurth caps https://au.mouser.com/ProductDetail/Wurth-Ele … MrvjrgR1LVc5gT3
They are the closest spec I could find to the ELNA's with a color that matches the card best.
The attachment Out of spec.png is no longer available
The attachment Card.jpg is no longer available
I could reinstall the purple OSCON caps back in to get rid of the new blue/silver caps (which I didn't need to replace) but maybe I'll leave that for another day.
Thank you to everyone who contributed to this post, especially tehsiggi (and yes you can add this post to your repair list).
Reply 53 of 54, by myne
Win
I built:
Reply 54 of 54, by tehsiggi
Lovely! Glad to hear back from that card!
C1263 and C1267 are for the 3.3V input coming into the card and are the input bulk caps for NVVDD (GPU Core voltage).
C1271 is the input bulk cap for VTT (directly connected to FBVDD).
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
