First post, by mbguy1
I am anything but computer savy so I apologize for some of the questions. THanks in advance for the help.
I have a Dell Optiplex GX 270. I have managed to get DOS 6.22 on it with the extra disk of files, the mouse and the cd rom drivers to work. I can't get the sound. I have a Soundblaster CT 4780 card. I've tried the livedos.zip files from a few sites with no luck at all. It says run liveset.bat but nothing but errors. I disabled the onboard sound on the machine, thought that might help. THere was a blue cable going from the cd rom to the motherboard (I assume a sound cable?) I moved it so it now goes from the cd rom to the CD-in port on the sound card. THat is about as far as I am. Any info you need for my setup that I did not include I would be glad to give. I just don't know what driver to use or how to get the sound.
Reply 1 of 4, by mbguy1
Plan is to make a separate partition for Windows 98 after which I can do and have all the drivers for that. If it would be easier to find the sound drivers for the windows 98 dos, I'd be totally fine with that. Don't know which ones to use for that application either. Stuck on the sound portion in either case.
Reply 3 of 4, by chinny22
mbguy1 wrote on 2025-09-19, 20:40:
This would definitely be the easiest way, no need for the separate partition either.
Install Windows 98
Then follow this guide by Joseph_Joestar and you'll get sound in both windows and dos mode
Guide: Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1)
Reply 4 of 4, by RetroBus
That may be the Dell OEM card, which from what I recall is hard to get going in DOS, either way all the best, getting any PCI card in Pure DOS is a bit challenging
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
