First post, by DustyShinigami
So I've been looking through this thread - Old floppy disk restoration - and need some guidance on how best to rescue data from a floppy disk. I tried installing the floppy disk version of Rise of the Triad I bought back in May, but sadly the first disk looks to be dodgy. And I think, possibly, disk 3 or 4. I checked out the video linked in that thread, on how to clean the floppy drive and the disk, which wound up being a big mistake. It proved quite stressful disassembling and re-assembling it, and as I feared, putting it back together and connecting it up, I discovered... I'd knackered it. 🙁 God only knows how. So I've had to order another one. Also, I fear cleaning the contents of the floppy disk has only made it worse.
If I'm able to use some sort of utility to extract the contents, is it possible to reformat a licensed game floppy? It's been a while since I tried. ^^; I was just wondering if reformatting it afterwards and then putting the rescued files back would work...?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 1 of 9, by DaveDDS
A lot will depend on if/what copy protection was used on the master disks.
This is usually on the form of intentionally "bad" sectors - sometimes the
installer just looks for certain sectors known sectors to be "bad" and others
"good" - better schemes used sector formats that the PC's Nec765 Floppy Disk
Controller chip could technically read, but were not implemented in PC BIOS or
OS drivers - this would involve the installer talking "directly" to the FDC.
The best schmemes used formats/bat sectors that the 765 could detect/read, but
not write...
Many such schemes ran into problems with "clones" and later original PC as they
would have their FDC in "system chips" which didn't always implement Nec765
functionality that was never officially used in the PC world.
Such schemes can limit your ability to read/recover the disk.
I strongly recommend using my "ImageDisk" tool to try reading the disks .. IMD
was originally designed to be able to archive/recover disks from as many non-PC
systems as it could (usually older pre-PC systems), and for this reason it is
able to read/write any FD format the the PC hardware is capable of doing, even
if the standard PC software can not.
IMD can also read as many sectors as it can from a diskette, and later recombine
many such reads into as complete an image as could be recovered.
Things to keep in mind:
Disk failure with age is most often caused by the magnetic material on the
disk deterioating, usually "flaking" off ... and every time the disk media
passes under a drive head, it can flake more... so you want to limit how
much you try to read the disk ... and use CLEAN drive heads - any contamination
on the heads can lead to increased deterioation.
Drives are different! - head pressure and alignment can differ slightly between
drives - normally with a good/strong media this isn't noticable, but as disks
get worse, one drive may be able to read what another could not.
Sometimes you can recover sectors/tracks by slghtly misaligning a drive - media
may be slightly better on one side of a track - moving the head slightly to
cause that side to be stronger can make a difference.
Also note that for 5.25" drives, if you are trying to recover DD disk, a HD
drive might help - HD heads are thinner and can focus more on a part of a track.
Original disks can be bulk-erased, reformatted and rewritten (once you have been
able to make a working copy on "other" disks) --- but be aware that if the
problem was caused by age deterioation, the newly written disk won't last!
Sometimes it's best to keep the originals to prove that you have a legit copy,
but use an "unofficial" set as a working copy.
Recovering damaged media is sometimes possible, but can take a LOT of work/time.
If you can find an undamaged copy of the game, it might be easier
to restore your disks.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 2 of 9, by chinny22
Are you sure ROTT had any form of disk protection in the first place? I don't own ROTT but don't think any of my Apogee games had any.
I could be wrong but I'd bet it's just a standard disk thats gone bad and if you could find a good image of the disk it would write on the disk without error and work just fine.
Assuming if the original disk itself is still good which it probably isn't and was the cause of the issue all along.
Reply 3 of 9, by DustyShinigami
DaveDDS wrote on 2025-10-14, 02:42:
A lot will depend on if/what copy protection was used on the master disks. […]
not write...
Thanks for the informative advice, guys. Much appreciated. One question I did forget to ask - if the floppy disk can be reformatted and written to etc, is it possible to replace the interior of the diskette with that of another? I did notice, after I'd cleaned it, that one side did have some markings. I wouldn't be surprised if I added those. >_< But then, I only used a q-tip with some warm soapy water and lighty dried it with paper towelling. If those markings were there from the start, that's probably why it's failing. So with that in mind, surely I could replace it with a workable one and then transfer the files to it?
But thanks for the suggestion. I'll give ImageDisk a try and report back. 😁 It doesn't look like there are many UK/European copies on eBay at the moment, so I could be waiting a while. Plus, it'll be quite pricey just to replace 1-2 disks if they come complete. ^^;
OS: Windows 98 SE
Reply 4 of 9, by DustyShinigami
chinny22 wrote on 2025-10-14, 03:58:
Ooh. Let's hope not then.
OS: Windows 98 SE
Reply 5 of 9, by DustyShinigami
not write...
You wouldn't happen to have the latest version of ImageDisk? Google isn't coming up with much and the link for 1.20 on your site gives me two errors when I try to extract:
Incorrect reparse stream : Unspecified error : IMDA.COM
Incorrect reparse stream : Unspecified error : IMDCMT.BAT
OS: Windows 98 SE
Reply 6 of 9, by DaveDDS
DustyShinigami wrote on 2025-10-14, 09:06:
... One question I did forget to ask - if the floppy disk can be reformatted and written to etc, is it possible to replace the interior of the diskette with that of another? ...
I have done this in the past - it really depends on the type of disk and how hard it is to open without causing excessive damage.
3.5s usually break, if you are careful you might only break the internal bindings ... In these cases, I use a "soft" glue (like a drop of caulking) to make
it work - and be able to take it apart more easily in the future.
5.25s can be slightly easier - it's sometimes possible to open the end away from the "slot" with a thin sharp knife.
(I've also had cases where I just cut off the far edge, swapped the media and either used a touch of glue on the very edge, or tape to reseal the edge.
It really depends on how "like new" you need it to be)
Reply 7 of 9, by DaveDDS
DustyShinigami wrote on 2025-10-14, 09:18:
You wouldn't happen to have the latest version of ImageDisk? ...
The latest IMD is always available on my "Daves Old Computers" website, look under "Software/Images" (near bottom of main page)
I don't recognize these error messages, and I've just scanned my IMD source tree, and they don't exist in any of my code.
Two possibilities come to mind:
- You are using an unofficial (ie: hacked) copy of IMD
- Whatever way you are loading/running them is unable to do so and reporting these errors....
note that IMD must run under DOS as it has to directly access PC hardware.
Reply 8 of 9, by DustyShinigami
DaveDDS wrote on 2025-10-14, 14:41:
The latest IMD is always available on my "Daves Old Computers" website, look under "Software/Images" (near bottom of main page) […]
It was from Dave's Old Computers under Software/Images. I tend to use 7Zip for extracting. I can try extracting them on my 98 PC and see if that helps.
OS: Windows 98 SE
Reply 9 of 9, by DustyShinigami
DaveDDS wrote on 2025-10-14, 14:30:
I have done this in the past - it really depends on the type of disk and how hard it is to open without causing excessive damage […]
Well, it definitely doesn't need to be super new. None of the other diskettes are. I managed to open disk 1 without issues yesterday. I have small plectrum tools to pry them open. I've never had or used 5.25s before. ^^
OS: Windows 98 SE
