Reply 30400 of 30409, by sunkindly
PC@LIVE wrote on Yesterday, 18:19:
Looking at the images, I can tell you that the CPU is blocked, you can only use two multi, 2.5X and 3X, the 2.5X one definitely […]
sunkindly wrote on Yesterday, 17:51:
Photos below, but in doing some more testing...it seems like the jumpers don't do anything at all to change it from 2.5x. […]
PC@LIVE wrote on Yesterday, 09:51:
Hello, if I understand correctly you have an S.7, but the CPU goes to a maximum of 166 MHz, so first of all 😨 I would check what is written on the CPU, for example Pentium XXX MMX SXXXX (the X's indicate what you will find written, they are important), already from there it would be possible to better understand the problem.
Then if maybe 🤔 you can take some photos, and attach them here, possibly motherboard and CPU, or if you can jumper zone (multiX), it would be possible to compare your settings with those of the manual (if you have one), but in any case even in the absence of the manual, it is possible to do some tests, to see to set the jumpers on 3X, currently it should be on 2.5X, if instead it is on 3X and does not go to 200, speaking of Intel CPU, you could have a 166 MHz CPU with multiplier blocked to go up.
If so, the only way to increase the frequency is to raise the FSB, if that board allows it, you can switch to 75 MHz, you get 188 MHz that the BIOS could interpret as 180 or 200 MHz, maybe that's how they showed you the 200 MHz.
The attachment r529multjp.png is no longer available
So JP16 and JP17 seem to set the fsb, but for JP19, JP20, and JP22 no matter what I set them to...it didn't change from 2.5x at 166MHz. Even setting it to something "normal" like 133MHz at 2x, nothing changed. The only thing that seemed to affect change was changing the FSB through JP16-17. But unfortunately, it doesn't support more than 66MHz.
The attachment IMG_7685.jpg is no longer available
The attachment IMG_7682.jpg is no longer available
The attachment IMG_7683.jpg is no longer available
The attachment IMG_7684.JPG is no longer available
The silkscreen doesn't mention anything about P55C or a 3x multiplier, but it has the jumpers to set dual voltage (which I did) and since it's POSTing I'm assuming that's actually working. So I'm not sure...
Looking at the images, I can tell you that the CPU is blocked, you can only use two multi, 2.5X and 3X, the 2.5X one definitely works, while the 3X one doesn't seem to.
But it could be something else, first, you can use a software to see the actual frequency, it could for example be a dated BIOS that makes you see only 166 MHz, when in reality it is 200.
One that you can easily find is CHKCPU, it works with DOS, or if you have Windows 95-98 you can try CPU-Z, both can show the actual frequency.
For the rest it's a motherboard that's fine, if you don't need to update it, that is, you want to use it as it is, and according to what it says, the jumpers are set up in the right way.
Perhaps the BIOS version is the factory version, and it is not accurate in reading the frequency (?).
I was hoping that might be the case but sadly CHKCPU and Speedsys both report 166ish...maybe I have some kind of early revision or is it the CPU?
BIOS is updated to the latest I found.
Either way I have a QDI Titanium 1E on the way so we'll what happens with that one 😮‍💨
SUN85-87: NEC PC-8801mkIIMR
SUN88-92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN94-96: BEK-P407 | Cyrix 5x86 120MHz | Tseng Labs ET6000 | SB 16
SUN98-01: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 30401 of 30409, by PC@LIVE
sunkindly wrote on Yesterday, 18:27:
I was hoping that might be the case but sadly CHKCPU and Speedsys both report 166ish...maybe I have some kind of early revision […]
Well you can always make some attempts, try selecting the other multi, if you haven't done it before, that is, the 1.5X/3.5X and 2.0X, I don't think the CPU doesn't work with the 3X multi, but by trying it in the QDI you should have confirmation, whether it works at 200 MHz (or not).
The only thing that could be there, is a hw failure, I noticed some SMDs near the jumper of the multi, maybe if it is broken, it could deceive the board, making you believe that the jumper is open, instead of closed.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 30402 of 30409, by tehsiggi
So I got back to that Hercules 9600 Pro. Had a bit of time the last days.
I now swapped / reballed all memory ICs on memory channel A, both ranks - the error does not really disappear nor change, even when mixing the memory chips.
The attachment h96mempcb.jpg is no longer available
The attachment h96reball.jpg is no longer available
The card sometimes posts, sometimes doesn't. When it posts, we get a pretty picture:
The attachment h96err.jpg is no longer available
R3MEMID isn't happy either:
Failing bits in test [1] Fill
errcount: 17616237
MDA0: 5 7 11 12 14
MDB0: 11
MDA1: 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Failing bits in test [2] Data line toggle (GUI)
errcount: 5772202
MDA0: 5 7 11 12 14
MDB0: 11
Failing bits in test [3] RW page (GUI)
errcount: 8663668
MDA0: 5 7 11 12 14 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
MDB0: 11
Failing bits in test [4] RW channel (GUI)
errcount: 5672858
MDA0: 5 7 11 12 14
MDB0: 11
So I checked the data lines to check the bits with the scope.. I just wanted to see if there's activity or not.
The attachment h96data.png is no longer available
So here we have it.. some data lines are just plain "dead" - for everything from bits 32-63 I assume it has to do with a clock signal missing or strobe signal missing. Hard to check, since these traces go directly to the memory ICs. The upper picture is a good data line, the lower is a bad one just floating at VTT.
Hmm.. I put pressure on the GPU where the data lines are - no change. Yikes...
Then I cleaned up the GPU to check it and whoops.. someone crumbled the cookie corners? I checked an older picture I had from the card: Same.. And I didn't notice since I just repasted it quickly before testing. Ouch..
The attachment h96dead.jpg is no longer available
I've ordered some RV350s now.. let's see how it goes when they arrive.
If I get this card to run again, I've got stories to tell I guess..
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30403 of 30409, by PurpleOzone
Restored an AT&T Globalist 200 Laptop to near factory.
Mostly yellowed keyboard melted floppy belt and missing battery latch. Got lucky with a 30 EUR ebay well rusted 200S donor and upgraded RAM from 4MB to 8MB plus took its keycaps, and the 486 DX4 100MHZ in it also worked but out of concern for thermals I left it out of this build.
Only thing that remained is the battery which I gutted, and I am wondering if I should rebuild?
Reply 30404 of 30409, by PC@LIVE
Today I worked on a couple of 486 motherboards, first on a 4FLUD-1.0, then on an ATC-1411B, both have problems due to corrosion, due to the loss of acid from the battery.
On the first one the damage is quite limited, but today investigating, I found three interrupted tracks, I'll see if tomorrow I can reconnect them, currently the card does not start, and the post card marks — —, probably it will be one of the broken tracks 😑, a track brings to quartz, so I imagine it can be back in operation, after reconnecting them, I will do a boot test, and I hope to see both the post codes and the BIOS screen.
The other one, on the other hand, has several oxidized points, tonight I scraped the green oxide from the copper, tomorrow I'll try, if I have enough time, to see if I find any interrupted, one is surely broken 😑, and in the back there are two or four, which I suspect are interrupted.
Reply 30405 of 30409, by Dan386DX
I played Fade to Black from 1995! The less famous sequel to Flashback.
Started it as a kid, unfinished business.
Not sure if poorly optimised early 3D engine, or hardware limitations but saw some pretty nasty slowdowns at times. First tried with the 6x86L clocked @ 190MHz, then switched to Pentium 100 and the performance got worse - so probably not an FPU issue. My GPU on that system is just the onboard Rage Pro 3D, wondering if that's the culprit? Univbe and custom DOS don't help much.
On paper, the system should make light work of the game, it was designed to run on P75 and DX2-66 systems after all!
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 30406 of 30409, by bjwil1991
Getting the 5155 close to being complete. Just waiting for the power adapter to arrive for the 3.5" floppy drive so it'll be fully set since I usually use 1.44MB diskettes to transfer files from my systems to machines like this since I don't have an enclosure to do 360K diskettes at the moment.
Anyhow, here is Planet X3 in 16 shades of amber:
The attachment 20251101_030653.jpg is no longer available
Another thing I need to do is wire the internal speaker correctly by soldering a male header onto the wiring and go from there. That and fix the geometry on the display since it's a bit off on the top right corner. And once I get all of that done, I'll upgrade the BIOS to the GLaBIOS and add GLaTICK to the U19 side once I triple the BASIC ROM contents and add go from there.
I still haven't worked on the 5150 since I have the Macintosh 512K project that I'll be working on (full recap and battery holder cleaning/repairs).
Reply 30407 of 30409, by RetroBus
Back to the Beige part 2, I pulled apart an LCD monitor to try and make it a retro style beige for my setup, still not sure how I feel about how it turned out, video below
https://youtu.be/RjFtzkFAsOI
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30408 of 30409, by PC@LIVE
Finished resurrecting the 486DX2-66, on Modula Tech 4FLUD-1.0 motherboards, I made three bridges to as many tracks, reassembled everything and added the minimum for a startup test.
It works!!!
Reply 30409 of 30409, by Rav
"Fixed" My Acer 486... Again
There is some cold join on the motherboard. I probably have to reflow the whole thing or something.
Surprisingly it did like 4 months without issue till last time I played Fallout for half a day then it did the usual "flashing cursor problem" next time I booted it (Next day, when I wanted to continue said Fallout game.
Now doing the usual batteries of tests because there is more than one cold join.
