First post, by G40
Initially this worked OK although it did hang once or twice towards the end of speech sections. Luckily I was able to get into the save menu, and reloading the save file allowed play to continue.
Since messing about with my soundcard installation - but ultimately going back to the original setup - it has started to hang as soon as any speech occurs - now no audio is played apart from OPL3 music (Re: SB Live + ESS Solo 1 under Windows 98SE?)
It has also always reported a low memory error at launch - see attached images.
Machine is an Athlon XP with SBLive, windows 98se and 512mb. I know it's way too modern for the game, but it did work OK before!
Incidentally, no issues with Sam and Max hit the Road from the same CD...
Reply 2 of 2, by G40
G40 wrote on Yesterday, 00:00:
Cured this by setting the card to use DMA1 (SB Live + ESS Solo 1 under Windows 98SE?)
