First post, by KiasuKing
I am going crazy with over analysis paralysis as I am trying to work out the best sound card and set up for the following machine.
AMD K6 2/450Mhz (Not a plus version)
128MB RAM
VOODOO3 PCI
I want to run windows 98 AND speed sensitive DOS games on it. Games I want to play are:
Privateer 1 & 2 (1992 + 1996)
Wing Commander 1 & 2 (1990/1991) - VERY speed sensitive
Wing Commander 3 & 4 (1994/1996/97)
No one lives forever 1 + 2 (2000)
Myth 1 + 2 (1997)
FIRST issue. I have no idea how to slow it down. Everything I have seen online looks like you need a "+" CPU to use the utilities to slow it. Is this the case?
SECOND Issue: SOUND choices.
The system has 2x ISA slots and I am trying to figure out what the ideal sound options would be. I have the following available
1. Creative AWE64 VALUE CT4500 512k RAM - it is an unknown quantity to me as I have had it in my stash for a while but never used it
2. SB32 CT3600 with 2MB RAM in the SIMM sockets aka AWE32 Budget edition - also completely unknown quantity to me. I know it works as I did install on a system many years ago but I never kept it in it. Is it better, worse or a coin flip choice when compared to the AWE64 value?
3. Ensoniq Soundscape 2000 - Good GM, average MT32, TERRIBLE FM. It is FULLY MPU-401 compatible but I have no external MT32/Sound Canvas or other modules so its irrelevant
4. SB Pro 2 - Noisy compared to the other cards I am listing but genuine OPL3.
5. AvanceLogic ALS100 PRO16PNP with GM daughter board, a WaveMagic DREAM GMS 940800. This card is astoundingly compatible with SB Pr0 and much quieter while the GM daughter board is certainly better than FM eve if not audiophile standards
I have some other interesting cards but they are already in other completed projects. I am doing this so I can hopefully sell off a 496, Pentium 100 and a Pentium Pro 150 which my family think are excessive (I will miss them - the computers that is)
My thoughts:
1. Use the AWE64 or SB32 in one slot for Windows 98, and put the Avancelogic with GM daughter board in the other for DOS. So is the AWE64 or the 32 a better card for Windows?
or
2. Put the SBPro in one slot and the Soundscape in the other, linking the 2 externally with an audio jack in and out of their line ports. Use like this in DOS, and only enable the Soundscape in Win98, disabling the SBPro in Windows. I have used this set up previously in my Pentium Pro and it works well enough. In which case selloff the AWE64 value and SB32
Much thanks for your help
Reply 1 of 18, by SScorpio
If the only DOS you are looking at is the Wingcommander series. Then you need great SB Pro support. The music is down to Adlib or MT32. The Soundscape 2000 isn't an MT32, it can sound OK for some games that don't remap instruments. But Wingcommander requires an MT32 with an intelligent mode MPU401. If Adlib sounds great for the AvanceLogic ALS100, then that would be my pick. The GM support would also be nice for game that made the jump to GM MIDI support.
For the Windows games, get a Sound Blaster Live or Audigy. EAX can add a lot to the experience of Win9X games. And with the good ISA card you don't need to worry about DOS compatibility issues.
I don't have experience with the card, but that AvanceLogic is after the move to the Adlib support being bundled into a single chip. So it's not an exact OPL clone. Only you can decide if you are fine with how it sounds.
Reply 2 of 18, by onethirdxcubed
You can turn off the L1 with SetMul for slowdown but that's about the only option you've got with that CPU so no chance for fine tuning the speed.
For Wing Commander you're better off playing either the Kilrathi Saga version for Win95 or the fan patch which adds a proper speed limiter.
For the sound card, I would go with the Sound Blaster 32 unless CQM is a huge turn-off, and if it is you can use the SB Pro or ALS card in the other slot.
Reply 3 of 18, by SScorpio
onethirdxcubed wrote on 2025-11-07, 16:01:
There's a recent patch that adds the speed limiter from the Secret Missions 2 pack to the base game.
You still need to do some speed limiting for briefings and cutscenes. But the actual flight is no longer speed sensitive and impossible to perfectly dial in.
New Patch - Wing Commander 1 (1990) speed throttling for 486+ CPUs
Reply 4 of 18, by mockingbird
Go with the ALS100 Pro. The cards have a separate (unlicensed) OPL3 clone chip which are 100% accurate. This is contrary to mainstream thought which claims that there is some sort of proprietary FM integrated into the IC. The IC itself has zero FM capability.
(Decommissioned:)
Reply 5 of 18, by KiasuKing
SScorpio wrote on 2025-11-07, 15:48:
Much thanks. WC 1&2 will be SBPro, WC3 and 4 detect use the Soundscape directly. I am leaning in the direction of the SB64 or SB32 in one slot and the AL/GM daughter in the other. I do have an early Audigy and a couple of SB Lives in other more modern projects and know they are great for Win98.
Reply 6 of 18, by KiasuKing
TQ for your reply. Indeed, testing and failing with SetMul the last couple of days made me consider hunting down a K6+ which may become an option I take. CQM is not as bad as most people make out so I think this has me weighing up the merits of either the AWE64 value against the SB32 now for Win98
Reply 7 of 18, by KiasuKing
SScorpio wrote on 2025-11-07, 16:14:
There's a recent patch that adds the speed limiter from the Secret Missions 2 pack to the base game. […]
Excellent. I did no know about this patch.
Reply 8 of 18, by KiasuKing
mockingbird wrote on 2025-11-07, 19:40:
I agree. It is a very under rated card. I prefer it to my SB Pro 2 cards as it sounds the same and has less noise.
This now leaves me with the SB32 or AWE64 question...which to use for Windows? The AWE64 is in the system currently and Win98 drivers are installed for it.
Reply 9 of 18, by dr_st
KiasuKing wrote on 2025-11-08, 06:29:
Do you really need a separate card for Windows? If the ALS100 Pro has working Windows drivers including General Midi support via the daughterboard - just use that.
Reply 10 of 18, by midicollector
ALS100, that's the sweet spot of the cards you listed here in terms of wanting both DOS and windows, and the variety of games listed. It'll be compatible with WC1 and other DOS games while still making games from 2000 sound good.
Reply 11 of 18, by NeoG_
Playing games like NOLF on a K6/2 is going to be a slog, you will need all the CPU power you can get and the best bet is something like an SB Live or Audigy. But I still think you will be disappointed, my K6/2+ 550 with higher speed, on die L2 and V3 2000 AGP is not really really fast enough. I think NOLF2 is out of the question.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6800, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 12 of 18, by cyclone3d
There are quite a few slowdown programs for DOS that either eat CPU cycles or flood the system with IRQ requests.
These were in use long before the programs that control the CPU clock speed were around.
It just takes a bit to figure out the proper settings and some even have hot keys that allow you to adjust the speed real-time.
As for Wing Commander 1&2, they re-releases them for Win9x and they didn't have the speed issues. I don't remember how the music was done in the Windows version... If is was pre-recorded or not.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 14 of 18, by KiasuKing
dr_st wrote on 2025-11-08, 10:16:
Good point. I have a socket 370 system (Pentium 3) with a SB live 5.1 card in it. That would simplify things. Maybe I am trying to do too much with it.
Reply 15 of 18, by KiasuKing
NeoG_ wrote on 2025-11-09, 11:46:
Yes, I do have a Pentium 2 on a socket 370 which runs it fine. That said...it actually runs and looks best on a P4 I have. I need to segment the games to the hardware.
BTW the whole reason i started down this route is my wife of 30+ years is keen for me to lighten the "sorting out dads junk after he expires" argument. Maybe I should just ignore the stress, enjoy the systems and let the kids sort it out when I will no longer be here to care hahahah...sorry if thats morbid.
Reply 16 of 18, by KiasuKing
dr_st wrote on 2025-11-09, 21:05:
cyclone3d wrote on 2025-11-09, 20:30:
I recall MoSlo and Bret Johnson's Slowdown were quite popular back in the day.
oh my!!! Moslo!
I had that once upon a time. Likely still on one of my HDDs. I need to find it and report back!
Reply 17 of 18, by dionb
Double-check: is that ALS100 really an ALS100 or an ALS100+? If no plus you're in luck, as the non-ALS100 isn't just SBPro2-compatible but also SB16 compatible including high DMA, just without Creative's MIDI and clicking bugs. Also if it's not paired with a real OPL3, it will have a 1:1 clone, so perfect FM as well. If you want a single card that does it all, this one is definitely the way to go.
But you have two slots and it would be a shame not to use both. Given the era you're looking at, you'll want good FM. Out of that list, that means the SBPro2 or the ALS100 - the SB32 and AWE have less highly regarded CQM and the less said about the Soundscape's "FM" the better. For Windows any of them will give sound, but ideally you want hardware WSS support up to 48kHz to avoid resampling mess. The ALS100 also ticks that box (unlike the Creative cards that cap out at 44kHz), as does the Soundscape.
So basically the ALS100 does everything you need - and it has a GM wavetable daughterboard too. So the only added value for the other slot would be a different MIDI synth. In that case it's a subjective question of whether you prefer the AWE64's EMU8k with soundfonts, or the Soundscape's native MIDI. I'd check those games again and see what they natively support.
Reply 18 of 18, by KiasuKing
dionb wrote on 2025-11-11, 07:31:
Thank you Dionb. I suspect you are right. I did some testing last night and the ALS100 sounds almost identical to my SB Pro CT1600s in Wing Commander 1. I have 2 of them - one being my original card from back in 1991 - and yes i still have the box 😀 I also tried Wing Commander with the AWE Value (CT4500) and while I am hardly a sound snob, there was a very noticeable difference. I will include some photos of the card below which may assist with identifying it, as well as post an update on this system which went through a dramatic update yesterday.
Incidentally the GM board was originally attached to a Samsung SAB 2000 Audio Magic 2. I no longer have it - lost it mysteriously which is hard to believe. The SAB 2000 looked like a soundscape, big long board which makes misplacing it even more of a mystery to me as I am incredibly careful and meticulous with old equipment. In digging up its providence I discovered it had a genuine OPL3 chip on it and in testing it worked and sounded like an SB Pro. Someone posted a video of it on youtube and he posted me the drivers. https://youtu.be/2vVfZA6rKLQ?si=_Tm9HoqDx0mZ-mcn
I still have the drivers so maybe I should post on Vogons.
The Samsung GM chip is nothing extraordinary but it is a noticeable step up from FM. The haunting guitar in Privateer on some of the planets is BEAUTIFUL.
