Ti4200 x8 (Ti4800) - ASUS V9280S Broken
Reply 40 of 70, by zuldan
tehsiggi wrote on 2025-11-03, 09:44:
No, all right. You've measured directly at the ISL, so that's good.. Let my grind my gears for a little while and I'll come back to you 😁
No worries 😁 Do you think there would be any point in replacing the ISL? My replacement chips are arriving any day now.
Reply 41 of 70, by tehsiggi
If you have them at hand, just give it a shot. I'm a bit out of ideas on this one right now..
Here a couple things just to make sure:
  • FB (pin 5) is 0V as well?
  • PHASE (pin 8 ) is connected to MID_FET12 (the one side of the inductor)?
  • Can you check that the COMP network C1622, C1623 and R1265 look okay and are connected how they should?
  • Voltage at COMP (ping 4) when the card is running?
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 42 of 70, by zuldan
tehsiggi wrote on 2025-11-03, 17:21:
If you have them at hand, just give it a shot. I'm a bit out of ideas on this one right now.. […]
You're on the right track tehsiggi. The ISL6525 replacement chip arrived today. WHAT AN IMPROVEMENT!!
I powered on the card and as soon as I saw the core starting warming up I jumped 😉 I then saw this on the screen....
The attachment IMG_9437.JPG is no longer available
Here are the new voltage readings.
The attachment Front - Voltages after IC replacement.jpg is no longer available
What are your thoughts?
Reply 43 of 70, by tehsiggi
Hey, things start moving again!
So good to know, the ISL6525 was a goner. Alright. NVVDD is 1.6V, should be 1.66V, so good enough I'd say. We're clearly missing the memory voltages.
FBVDD (main memory voltage) should be 2.8V.
VTT (derived from main memory voltage) should by around 1.2V.
Let's check a couple of things (perhaps even in that order).
  • State of NVVDD_PWRGD - pin 7 of the NVVDD regulator ISL6525 (during operation) - if that one is not high, the memory regulator will stay offline.
  • Resistance of FBVDD against ground (not installed into a system)
  • Resistance of VTT against ground (not installed into a system)
  • Voltage on R1285 (both sides) should be around 5V - (during operation)
  • Signals on R1291 (low FET gate for FBVDD) as well as for R1292 (high FET gate for FBVDD) - (during operation)
We're looking at the ISL6225 now, which is a dual output buck converter built for memory power supply applications:
The attachment isl6225.pdf is no longer available
We'll figure it out.
I've noticed that your riser cable introduces a significant drop on the 3.3V apparently, if only 2.4V remain at the card. 😉
Reply 44 of 70, by zuldan
Awesome ! Will go through the list tomorrow. It gets a little tricky now…with the core online, it heats up pretty quick without a heatsink so I only have a very short time to do any testing. I’m not too keen on trying to balance a heatsink on the core in case it slips off and shorts something 😗
Reply 45 of 70, by tehsiggi
Got no cooler handy? I take those 40x40mm coolers, put a nice load of paste onto them and then firmly push them onto the core.. The paste will keep it in place most of the time.. for everything else during testing there are cable ties 😁
Looking forward to your results.. my ISL6525 arrived as well.. let's see if I find some time to get my eval boards done..
Reply 46 of 70, by zuldan
tehsiggi wrote on 2025-11-10, 10:46:
I’ve got some little coolers sitting around. I have some Noctua paste that is pretty sticky. I’ll give it a try.
Reply 48 of 70, by zuldan
tehsiggi wrote on 2025-11-10, 10:29:
Let's check a couple of things (perhaps even in that order). […]
Here we go! Apologies for the delay.
  • State of NVVDD_PWRGD - pin 7 of the NVVDD regulator ISL6525 (during operation) - if that one is not high, the memory regulator will stay offline. - 4.6v so high
  • Resistance of FBVDD against ground (not installed into a system) - 1.6 ohms - used TP30
  • Resistance of VTT against ground (not installed into a system) - 6.8k omhs - used TP29
  • Voltage on R1285 (both sides) should be around 5V - (during operation) - 4.7v both sides
The attachment R1291.png is no longer available
The attachment R1292.jpg is no longer available
Reply 49 of 70, by tehsiggi
Hmm..
Could you measure R1291 and R1292 against ground (no operation)? The high side signal looks weird. Almost like stuck to the 0.8V you measured at FBVDD.
The resistance of FBVDD to ground concerns me. 1.6 Ohms is not a lot. Not sure I've measured anything like that on any mem rail of BGA memory cards.
If it's true, it would mean 1.75A of current at 2.8V, nothing too crazy, the regulator should be able to provide that (even into a resistive load). So not bothering too much about it - for now. The FET singal looks more interesting to me right now.
Reply 50 of 70, by zuldan
tehsiggi wrote on 2025-11-12, 12:05:
Hmm.. […]
Hmm..
Yeah it does look a bit low. I was surprised.
R1291 = 7.6 mega ohms
R1292 = 8.3 mega ohms
Should I order a new ISL6225 as a precaution? (2 weeks delivery usually)
Reply 51 of 70, by tehsiggi
zuldan wrote on 2025-11-12, 21:23:
Yeah it does look a bit low. I was surprised. […]
Ha, sounds you are stacking up 2006 finest voltage regulators. Not sure what killed the ISL6525, perhaps it also took down the ISL6225. I'll leave it to you, don't want you to spend money you might not want to 😉
I have a couple of things to look at:
  • Voltage over C1641 (10nF) during operation - it should be above 1.5V to start (see datasheet threshold on page 3)
  • Resistance of R1277 - should be 49.9kOhms
I just read that you measured the rail resistance of FBVDD on TP30, but that one is the feedback network testpoint for VTT, the correct one would be TP31. Can you re-check TP31 to ground?
For VTT, you measured using TP29, but that is the feedback network testpoint for FBVDD. I haven't found a proper testpoint for it, you might just wanna measure any pin of L814 against ground for that.
However, 1.6Ohms of TP30 against ground is concerning. How do R1276 and R1279 look?
Reply 52 of 70, by zuldan
tehsiggi wrote on 2025-11-13, 10:19:
I have a big collection now from other cards 😉 New ISL6225 is on it's way!
  • Voltage over C1641 (10nF) during operation - it should be above 1.5V to start (see datasheet threshold on page 3) = 0.5v
  • Resistance of R1277 - should be 49.9kOhms = 50k ohms
  • Re-check TP31 to ground = 340 ohms
  • Any pin of L814 against ground = 280k ohms
  • R1276 = 490 ohms (490 ohms to ground)
  • R1279 = 535 ohms (490 ohms to ground)
The attachment C1641.JPG is no longer available
Reply 53 of 70, by tehsiggi
zuldan wrote on 2025-11-14, 09:15:
I have a big collection now from other cards ;-) New ISL6225 is on it's way! […]
Alright.. so that TP31 measurement gives me hope. 340Ohms for the FBVDD rail is good. And the 280kOhms for the VTT rail is good as well.
So C1641 is the soft start. I wonder, can you get a scope reading of it (continuous trigger, trigger at 0.3V) against ground? I would like to see if the signal is ramping or not.
Perhaps this card starts setting a track record for randomly dead switching regulators..
Reply 54 of 70, by zuldan
tehsiggi wrote on 2025-11-14, 14:22:
Ok here you go. It didn't really capture anything on C1641 but I think that's because I don't have the scope configured correctly? or SS isn't going at all.
Reply 55 of 70, by tehsiggi
Hmm.. unless the connection of the scope isn't working properly (what I don't expect) you should see the signal nicely with your settings. Trigger is at 300mV, coupling is DC. So that looks all good and well.
The ISL6225 has an under-voltage protection as well (same as for over-current etc.) which latches the regulator off, until a full EN cycle has happened. I wonder if we trigger that, given that the 5V rail is already only 4.6V on your measurements.
Just to check that the SOFT1 pin is not shorted or something, can you measure its resistance to ground.
Test2: What happens if you put the card into the slot directly, without riser? I'd expect the 5V inputs to be way more 5V. Any change in behavior?
Reply 56 of 70, by zuldan
tehsiggi wrote on 2025-11-16, 06:57:
Hmm.. unless the connection of the scope isn't working properly (what I don't expect) you should see the signal nicely with your […]
When I get rid of the riser, the voltage jumps to 5.1v but no change in the cards behavior. I was being an dumb dumb with C1641. I was measuring the ground side of cap. It has a resistance of 1.7 mega ohms. There is a signal rise when powering the machine on. I couldn't go back enough with horizontal positioning, so I'll have to figure that one out. I took a video and then grabbed a screenshot of that. Sorry for the quality.
The attachment Screenshot_20251116_182040_com.huawei.himovie.overseas.jpg is no longer available
Reply 57 of 70, by zuldan
tehsiggi, the new ISL6225's chips are arriving in a couple of days. Let me swap the chip out and then see what happens. We might get lucky again and save a lot of diagnosing time.
Reply 59 of 70, by zuldan
tehsiggi wrote on 2025-11-19, 08:00:
I just got stuck in the daily routine 😉
Okay, let's go that route. If that doesn't change anything, I'm still up for the debugging game!
Progress! ISL chip arrived. I can see text on the screen now. Woohoo.
So something took out the ISL6525 and the ISL6225. Hopefully just some memory chips are broken now. Do you think it’s worth trying to run MATS v3.41 at this point?
The attachment 149497C9-F0CD-4B3A-B477-80B15F630583.jpeg is no longer available
